Old 04-29-2018, 05:31 PM   #1
DeltaEcho
DeltaEcho's Avatar
Drives: 17BRZ Limited TS
MAF Sensor Comparison
Hi there;
The idea is this; bare with me...
My build so far I am slowly building up my car for a turbo kit.
The idea is to go piece by piece so the day I acquire the kit. There shouldn't be issues the day the kit installed.
That being said; MAP sensor..
Perrin has a 2.5BAR and there are a few other companies that sell 3BAR and 4BAR.
For a DD turbo kit and building up to it. Is there a difference between the 2.5BAR or 3BAR MAP?
When should I get a 4BAR MAP?
DeltaEcho is offline   Reply With Quote
Old 04-29-2018, 06:49 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
MAP not MAF. You only "need" as high as the max boost pressure you expect to see. Don't forget that 0 Bar boost is 1 Bar MAP. The smallest you need is preferable.
.: Stealth 86 :.
Kodename 47 DJ:
DeltaEcho (04-29-2018)
Old 04-29-2018, 09:43 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
2.5 bar is plenty for the boost these car take unless built motor.
Old 04-29-2018, 10:21 PM   #4
coxxoc
Most MAP sensors are going to output a 0-5v signal. You will want the lowest pressure sensor possible to provide the most granular signal in that range based on the target boost you plan to run. If you don't plan on running 20+ lbs of boost, stick with a 2.5 bar (about 21 psi) sensor
coxxoc is offline   Reply With Quote
Old 04-30-2018, 08:17 AM   #5
Fred E
Drives: WRB BRZ
The Omni 3 bar MAP sensor is most commonly used and is good to about 29 psi of boost (have to account for atmospheric pressure), which is more than enough for a daily driver. A 4 bar sensor is therefore highly unnecessary. Whichever one you pick, just let your tuner know so they can enter the scaling value into the tuning table.
http://omnipowerusa.com/store/Subaru...nsor-c11282089
Fred E is offline   Reply With Quote
Old 05-01-2018, 05:36 PM   #6
Hags86
Drives: Toyota GTS 86
Agreed. I have the omni 4 bar and regret it. Error on a sensor is measured as a percentage of full scale reading so you end up with larger errors in the reading than you would on a 3 bar.
Hags86 is offline   Reply With Quote
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
