Old 04-27-2018, 08:41 PM   #1
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Gruppe S header install question
Hi guys,, I just bought a used Gruppe s ceramic coated header and will be installing with new OEM gaskets in a week or so. Question is do I need the reflective heat shield that goes on the oil pan ? Car is street driven only and not abused. I don't think I will get the oil too hot but will the header blister the paint on the oil pan ? If so I will get one. Any advice appreciated.
22R
22R is offline   Reply With Quote
The Following User Says Thank You to 22R For This Useful Post:
Teseo (04-27-2018)
Old 04-27-2018, 08:53 PM   #2
coxxoc
22R
Plenty of people installed the header both without ceramic coating and before the heat shield was available. You should be just fine for street driving the car.
coxxoc is offline   Reply With Quote
Old 04-27-2018, 09:33 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Although I think the Gruppe-S header is shaped slightly different than the Tomei UEL, it still comes pretty close to the oil pan and the thermostat housing. I'd say if you have it and are under there...put it on. I don't think minimizing heat transfer would be a bad thing.
BirdTRD is offline   Reply With Quote
Old 04-27-2018, 10:43 PM   #4
StraightOuttaCanadaEh
Wes
Since it's ceramic coated, I'd say nah
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Teseo (04-27-2018)
Old 04-28-2018, 07:35 AM   #5
22R
22R
22R's Avatar
Thanks guys. I may just put a piece of insulation wrap on it where it passes near the pan with a SS band.
22R
Old 04-28-2018, 07:40 AM   #6
Bkdshadow
Drives: 2013 Scion FRS
I have a Gruppe-S with the heat shield (uncoated), and oil temps stay around 210 degrees F just driving normally. When I do spirited driving on backroads for a little bit though, it’s not hard for it to reach 240 degrees F
If you don’t drive hard too often I’d say you’d be fine without it, but the less heat the better.
Bkdshadow is offline   Reply With Quote
The Following User Says Thank You to Bkdshadow For This Useful Post:
22R (04-28-2018)
Old 04-28-2018, 11:49 AM   #7
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
You don't have to use their insulated piece. You can buy a stick-on roll of the stuff for like $15 and have plenty left over. Its worth the piece of mind
SuperTom is offline   Reply With Quote
Old 04-28-2018, 02:15 PM   #8
Impureclient
Drives: 2015 FR-S
I have the heat shield on but I had mine ceramic coated too. My average temp is closer to 203 degrees F and when driving it really hard I get to 220 degrees F.
Old 04-28-2018, 06:46 PM   #9
22R
22R
22R's Avatar
Thanks ! Where did you buy the roll ?
22R
Old 04-28-2018, 07:53 PM   #10
SuperTom
SuperTom's Avatar
22R
A little more expensive then I remembered but plenty to work with. Has a weave layer and a reflective layer
https://www.ebay.com/itm/Thermo-Tec-...item33e7f024a4
The Following User Says Thank You to SuperTom For This Useful Post:
22R (04-28-2018)
Offical Gruppe-S UEL Header Install & Review Thread continuecrushing Engine, Exhaust, Transmission 313 06-11-2023 03:54 PM
Gruppe-S Header rtalich Engine, Exhaust, Bolt-Ons 5 01-21-2018 08:31 PM
Openflash header 2 install question. SubieRumble Engine, Exhaust, Transmission 5 12-25-2016 10:34 PM
LF: Gruppe-S Header or FT86SF Catted UEL Header b11lee Canada Classifieds 6 12-14-2016 04:03 PM
WTB: Gruppe-S UEL Header ThornhillSubaruOwner Canada Classifieds 1 09-01-2016 11:16 PM
