Old 04-26-2018, 11:37 AM   #15
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Dam. Just when I think I'm ahead.
You can get an AT and remove an arm and a leg. That would give you the upper hand.
HKz (04-26-2018)
Old 04-26-2018, 11:55 AM   #16
Gunman
Drives: 2019 Mazda Miata RF
Weight reduction, along with the physical fitness improvements should help make gains. Many pro drivers are also triathletes now too.
Old 04-26-2018, 02:58 PM   #17
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by gtpvette View Post
I've always heard 7lb,,, but close enough either way. 3-4 HP for 30 lb
Ive always heard 1lb of rotating mass is equal to 7lbs of dead weight. 10lbs of dead weight equals 1hp. 100lbs =10hp= tenth in quarter mile.
So for the OP you've just gained yourself 3hp and .003 secs in the a quarter mile! Take a laxative and a big squat and you could be even faster
SuperTom is offline   Reply With Quote
Old 04-26-2018, 03:01 PM   #18
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Lakitu View Post
If you go to the gym and lose 30 lbs, how much hp/torque does that add to your car? :P
About the same as if you took out the spare tire and associated jack.
nikitopo (04-27-2018)
Old 04-26-2018, 04:07 PM   #19
Azzudien
Drives: 2017 Series Yellow BRZ
Tossing your wife out of the car gains significant power. Weight reduction and when she kicks the ass end of your car as you drive away is a nice push boost.
Azzudien is offline   Reply With Quote
The Following User Says Thank You to Azzudien For This Useful Post:
Spuds (04-26-2018)
Old 04-26-2018, 04:10 PM   #20
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
[ame="https://www.youtube.com/watch?v=LazUZz3K6IY"]Captain Freedom's Workout Commercial - YouTube[/ame]
krayzie is offline   Reply With Quote
Old 04-26-2018, 04:42 PM   #21
Get's rid of that annoying whining noise from the passenger side as well.
86kahl (04-26-2018), Spuds (04-26-2018)
Old 04-26-2018, 04:45 PM   #22
Does all this math everybody is throwing around work in reverse. If I have my 250 pound son in law and two 150 pound grandsons in the car will it even move? Will my HP go into the negatives?
Old 04-26-2018, 06:21 PM   #23
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, there is a weight limit the suspension can handle, but other than that my math works just fine. Power to weight ratio approaches 0 but can't actually go negative unless either mass is negative or power is negative.
But that makes too much sense for this crowd, so let's see what else we come up with.
Old 04-26-2018, 07:16 PM   #24
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Better start working out fatty!
MS, CSCS, TSAC-F, CPT
Old 04-26-2018, 07:28 PM   #25
Damnit. I was hoping to get enough weight in there that it would drive backwards and create fuel.
And yes speed bumps become very challenging when they are all in the car!
Spuds (04-26-2018)
Old 04-27-2018, 11:22 AM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Try this formula Weight/Power and you'll never get negatives.
It is never too late to learn
Old 04-27-2018, 11:39 AM   #27
Also never to late to figure out when somebody is obviously making a joke. If anybody truly believed that I felt that adding more weight would make the car go negative or not move they need to re examine their world outlook.
Old 04-27-2018, 11:46 AM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You get torque hump.
Tcoat (04-27-2018)
mr. slim's whiteout FR-S thread! mr. slim Member's Car Journals 72 05-01-2015 09:34 PM
PS3 Slim 160 GB- 12 gms - 3 cntrls Vesalera Miscellaneous 0 11-06-2014 05:33 AM
Ps3 Slim with games Guzic Miscellaneous 1 08-15-2014 12:24 AM
FS: FR-S/BRZ Rain Visors (Slim) taimysho0 Exterior Parts (Aero, Lighting, Etc.) 6 06-06-2013 07:29 PM
HID slim ballast Kit for 86 ? TRD_86 Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 03:50 AM
