Drives: 2014 Subaru BRZ Limited 6MT
Can't always shift into 1st?
I've been having a problem over the last couple of weeks where when I'm at a stop I sometimes can't get into 1st. Every time this happens, if I go back down, and then try again, it always works (clutch down the entire time). Double clutching has no effect.
Is this likely a synchro issue? I'd be a bit surprised since I'm pretty gentle with 1st, meaning I never engage it unless I'm going 5MPH or less. It has 62K miles on it. edit: Also forgot to mention that for the last 10K or so miles I've had an aftermarket ACT XT Clutch/Flywheel. |
#2 |
The Gunshine State
Drives: '14 BRZ Limited
Was the engine/trans warmed up? People have complained about that in colder climates. Many have also switched trans and diff fluids; a quick search will give you better answers.
![]() Current DD: M235i |
#3 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Yea happens to me sometimes. I have to go into 2nd then first.
#4 |
Yeah, it's happened both after long drives and at cold start. I'm in Florida, and it's been pretty hot lately (85F+).
#5 |
Drives: 2013 satin white brz limited
When was the last time you changed your trans fluid?
#6 |
#7 |
OEM fluid or?
#8 |
#9 |
What variant do you know? Just curious as I switched to redline mt-90 this spring and hope to see how it drives. I was running motul trans fluid and was not a fan of it at cold temps/start up temps for the very issue your dealing with now.
#10 |
Not sure, but I doubt it's the same issue, as mine will happen at any temperature, it just isn't consistent.
#11 |
#12 |
Drives: 2017 Halo 86
I've noticed that if the RPMs are above a certain limit, it will not let you shift into 2nd or 1st. I always just thought of it as a safety mechanism. Its like it locks you out. "Access Denied...until you slow the fuck down". So I never downshift below 3rd when coming to a stop before a light, but I do only when I'm already going at a steady crawling pace around stores.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#13 | |
At 62K miles, this is a new occurrence, and definitely isn't something I would consider normal. |
#14 | |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
As for OP it is tough to diagnose these hard shifting problems over text and a video probably wouldn't really help either..best to get a buddy who is experienced with MTs and have him feel it. Dealership could help if ya don't know anyone.. |
| Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit | zohaib | Transmission and Driveline | 5 | 03-08-2017 11:51 PM |
| SOLD: Whiteline Positive Shift Kit Bushing, Moddiction Shift Knob | immaculate | Transmission and Driveline | 4 | 12-30-2016 06:52 PM |
| Auto to manual shift bezel (shift boot) | oh96s | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 05-23-2016 02:24 PM |
| SOLD: carbing shift knob infocus shift boot digital camo | toby714 | Interior Parts (Incl. Lighting) | 6 | 07-02-2015 09:33 PM |
| FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) | wgnzlz | Interior Parts (Incl. Lighting) | 8 | 06-09-2014 09:36 PM |
