Old 04-13-2018, 12:23 PM   #2773
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I have a stock known working throttle body sitting in my house. It came off my car when replaced it with one I modified.
B T is offline   Reply With Quote
Old 04-16-2018, 01:00 PM   #2774
taiguy
Drives: 2013 Black BRZ Limited
So when my shop went to swap out my throttle body with a "control" throttle body, they found the back side of my throttle plate "completely covered in carbon grime". After cleaning the throttle plate off, the discrepancy between the accelerator and throttle position sensor went away. So they think they have figured out the symptom, but still working on the root cause.
I only have maybe 4-5k miles on this edelbrock setup, while others have many times more than that with seemingly no issues. I asked the shop to see if they can figure out a root cause anywhere.
taiguy is offline   Reply With Quote
The Following User Says Thank You to taiguy For This Useful Post:
CSG Mike (04-16-2018)
Old 04-16-2018, 01:32 PM   #2775
B T
Why would only the backside be covered in carbon buildup? Also, I'm pretty sure the throttle body position works as a potentiometer, it's not like it's an optical sensor. Why would carbon throw that off? Do you have an air/oil separator?
Old 04-16-2018, 02:53 PM   #2776
taiguy
No clue as to why only the backside would be covered in buildup. I asked about the rest of the intake, as that would be dirty as well if I was suffering from blow-by right? Nothing noted on the ticket, but they said they'd ask the tech again.
I do not have catch cans yet.
Old 04-17-2018, 08:21 AM   #2777
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
Definitely recommend catch can(s). I ran N/A with a Radium Dual setup, and for the most part was pretty dry. First oil change after the super charger install (approx. 2500 miles) and it was half full.
It may not be the answer to your problem, but it couldn't hurt you any.
-Carlos
Carlos_M is offline   Reply With Quote
The Following User Says Thank You to Carlos_M For This Useful Post:
taiguy (04-17-2018)
Old 04-17-2018, 02:17 PM   #2778
johan
Drives: '14 981CS, '99 NB1
I would recommend swapping your PCV for a WRX one. The stock PCV allows a LOT of blow by. I've had them side by side, it's quite dramatic in comparison.
johan is offline   Reply With Quote
The Following User Says Thank You to johan For This Useful Post:
sato (04-24-2018)
Old 04-24-2018, 07:03 PM   #2779
Greenbean
Drives: 2017 series yellow BRZ
Originally Posted by AZ94 View Post
Are there any updates regarding the release of the kit for the 2017+? I remember reading in this thread sometime last year that a kit for the 2017 cars was coming soon.
It's just that I will be in CA in a couple months or so near some of the reputable dealers/installers and I was hoping I could have the kit installed for the warranty...After that I probably won't be near any of the installers in the foreseeable future and I'd probably have to either do it myself or take it to a dealership or ASE tech who probably have less experience with superchargers than the installers.
I just called edelbrock and they said that the blower has been retrofitted so it fits the 17+ models. they said the best dealer to buy from is jegs so you know that you will get a newer model blower.
Greenbean is offline   Reply With Quote
Old 04-24-2018, 07:52 PM   #2780
Amyang19
Drives: Brz
Smaller Pulley's
Does anyone have a link or know where I could buy a smaller pulley? Also, if i buy a smaller pulley would I have to buy a smaller belt as well or will the one that came with the supercharger work fine?
Car noob here.
Amyang19 is offline   Reply With Quote
Old 04-24-2018, 07:53 PM   #2781
CSG Mike
CSG Mike's Avatar
Car noob here.
PM @CounterSpace Garage
Old 04-25-2018, 06:42 PM   #2782
Proseph
Drives: Supercharged 2016 CBS BRZ
What's this best header for the Edelbrcok Supercharger?
Proseph is offline   Reply With Quote
Old 04-25-2018, 07:11 PM   #2783
CSG Mike
CSG Mike's Avatar
Ace A350 or Anaconda
funwheeldrive (06-22-2018), Proseph (04-25-2018)
Old 04-25-2018, 07:40 PM   #2784
Proseph
thanks, you rock!
Old 04-26-2018, 02:51 AM   #2785
taiguy
so after getting my throttle body cleaned, the lower end of the RPMs feel smoother, and I'm seeing the highest mpg since before the kit. I was averaging 22.9 before the cleaning. It was 17 mpg right after the e-force install with the CARB tune. after adding some addition clamps to hoses in the system, and going to the delicious tune, it creeped up to 21 mpg. I could never break past 23 mpg per tank, so this is encouraging. I will monitor after a few more fill ups.
CSG Mike (04-26-2018)
Old 04-26-2018, 11:00 AM   #2786
gtengr
Drives: 2017 BRZ
Nice! I didn't see the new blower on their website. Anyone else heard anything?
gtengr is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
