#2773 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I have a stock known working throttle body sitting in my house. It came off my car when replaced it with one I modified.
#2774 |
Drives: 2013 Black BRZ Limited
So when my shop went to swap out my throttle body with a "control" throttle body, they found the back side of my throttle plate "completely covered in carbon grime". After cleaning the throttle plate off, the discrepancy between the accelerator and throttle position sensor went away. So they think they have figured out the symptom, but still working on the root cause.
I only have maybe 4-5k miles on this edelbrock setup, while others have many times more than that with seemingly no issues. I asked the shop to see if they can figure out a root cause anywhere. |
| The Following User Says Thank You to taiguy For This Useful Post: | CSG Mike (04-16-2018) |
#2775 |
Why would only the backside be covered in carbon buildup? Also, I'm pretty sure the throttle body position works as a potentiometer, it's not like it's an optical sensor. Why would carbon throw that off? Do you have an air/oil separator?
#2776 | |
I do not have catch cans yet. |
#2777 | |
Drives: 2014 BRZ Limited
It may not be the answer to your problem, but it couldn't hurt you any. -Carlos |
| The Following User Says Thank You to Carlos_M For This Useful Post: | taiguy (04-17-2018) |
#2778 | |
Drives: '14 981CS, '99 NB1
| The Following User Says Thank You to johan For This Useful Post: | sato (04-24-2018) |
#2779 | |
Drives: 2017 series yellow BRZ
#2780 |
Drives: Brz
Smaller Pulley's
Does anyone have a link or know where I could buy a smaller pulley? Also, if i buy a smaller pulley would I have to buy a smaller belt as well or will the one that came with the supercharger work fine?
Car noob here.
#2781 | |
#2782 |
Drives: Supercharged 2016 CBS BRZ
What's this best header for the Edelbrcok Supercharger?
#2783 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | funwheeldrive (06-22-2018), Proseph (04-25-2018) |
#2784 |
#2785 |
so after getting my throttle body cleaned, the lower end of the RPMs feel smoother, and I'm seeing the highest mpg since before the kit. I was averaging 22.9 before the cleaning. It was 17 mpg right after the e-force install with the CARB tune. after adding some addition clamps to hoses in the system, and going to the delicious tune, it creeped up to 21 mpg. I could never break past 23 mpg per tank, so this is encouraging. I will monitor after a few more fill ups.
| The Following User Says Thank You to taiguy For This Useful Post: | CSG Mike (04-26-2018) |
#2786 |
Drives: 2017 BRZ
Nice! I didn't see the new blower on their website. Anyone else heard anything?
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
