Old 04-23-2018, 11:25 PM   #18775
Originally Posted by Raven86Project View Post
I come to share car stuff and get this LOL
Will think twice before posting here next time.
Oh,.... pay me no never mind ....... it was a slow day in Puyallup today .....
Raven86Project (04-23-2018)
Old 04-24-2018, 08:50 AM   #18776
Roth
Roth's Avatar
Drives: 2013 Gt86
Originally Posted by Roth View Post
Today I finally (maybe not) got rid of the driver door rattle. Sounds waaay better now
Originally Posted by notout86 View Post
Are you going to tell us the source of the rattle?
There was a loosen white plastic cover, inside the door, and some of the screws needed to be retightened. I put some duct tape around all the connectors and cables too, and now it's finally quite.
Roth is offline   Reply With Quote
The Following User Says Thank You to Roth For This Useful Post:
notout86 (04-26-2018)
Old 04-24-2018, 10:37 AM   #18777
assbox
assbox's Avatar
Drives: Whiteout FRS
Originally Posted by Decep View Post
oh man, that is gonna hurt your eyes at night.
It doesn't strain my eyes in the slightest. On the contrary i find it very soothing to me. A good change from the mismatched OEM colors.
IG: ft86carbon
assbox is offline   Reply With Quote
Old 04-24-2018, 04:21 PM   #18778
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
That's every day.
(originally from equally slow Aberdeen)
(and on subject) Bought some LEDs. +5 hp each, right?
BigHugeFatGuy is offline   Reply With Quote
The Following User Says Thank You to BigHugeFatGuy For This Useful Post:
humfrz (04-24-2018)
Old 04-24-2018, 07:07 PM   #18779
Originally Posted by BigHugeFatGuy View Post
That's every day.
Nope Aberdeen ain't changed much ......
That depends whether or not you got the sticker(s) ......
BigHugeFatGuy (04-24-2018), Tcoat (04-24-2018)
Old 04-25-2018, 04:46 PM   #18780
Roth
Roth's Avatar
Drives: 2013 Gt86
Removed the sound generator and replaced the original intake hose. Sounds definitely better now
MJones_RB (04-25-2018)
Old 04-25-2018, 04:47 PM   #18781
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Boy, that sure blends in.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Roth (04-26-2018), SuperTom (04-26-2018), Wise (04-26-2018)
Old 04-25-2018, 05:17 PM   #18782
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
It's not dusty enough.
fx1mark is offline   Reply With Quote
The Following 2 Users Say Thank You to fx1mark For This Useful Post:
Jordanwolf (04-26-2018), Roth (04-26-2018)
Old 04-26-2018, 01:20 AM   #18783
notout86
Drives: GTS 86 auto
Originally Posted by Quentin View Post
Why do you think they made it through the filter? You pulled them out upstream of the filter. When the engines are first run, the moving parts bed in and those tiny specs of metal have to go somewhere. The sump is where they go and the filter prevents them from routing back to the bearings.
The anti drain back filter valve should stop them from draining back to the sump from the outside of the filter medium. Then my understanding was that with a "full flow filter system" the oil goes direct from the sump to and through the filter so if any specs went down into the sump they would very quickly be strained out on the way back by the filter next time round, unless extremely fine. I thought the bulk of visible particles including machining shards would only have been shed in the first few kilometers and they were what I was aiming to remove by changing the oil. I was surprised that the sparkly particles were large enough to be visible too. I am missing something so please explain.
Here's what I got when I googled oil path in engine
"tube with a loose-weave metal screen at the bottom of the pan. The screen is attached to a pickup tube, which leads directly to the oil pump.
From the pump, it goes to the outside of the oil filter, and there it is forced through the filter media to the center, where it exits into the oil galleries inside the engine. "
GTS86 Auto (Australia)
Old 04-26-2018, 03:26 AM   #18784
Roth
Roth's Avatar
Drives: 2013 Gt86
You're both absolutely right
Let's say that I'm not into detailing In my defense, I drive every day 2 miles on a dusty-gravel road. So the car and the engine bay are not -and won't be- clean (we are finally getting tarmac during the summer). Got the hose very cheap, so i couldn't let it go
Old 04-26-2018, 02:23 PM   #18785
Well, Roth ....... to make everyone happy, I suggest you spray paint that piece flat black ..... then drive down your dusty road before the paint dries .....
The Following 3 Users Say Thank You to humfrz For This Useful Post:
DarkPira7e (04-27-2018), fx1mark (04-26-2018), Roth (04-28-2018)
Old 04-26-2018, 08:52 PM   #18786
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Went from this spoiler...
To This one...
el-guapin is offline   Reply With Quote
The Following 3 Users Say Thank You to el-guapin For This Useful Post:
ERA (04-26-2018), humfrz (04-27-2018), MJones_RB (04-30-2018)
Old 04-26-2018, 09:59 PM   #18787
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Installed Kenwood DDX917ws head unit and 2017 suede style one piece dash
Also installed OEM Audio Reference CF kit (6.5" door speakers, tweeters, subbox and amp)
Wise is offline   Reply With Quote
Old 04-27-2018, 04:18 AM   #18788
ctmandu
ctmandu's Avatar
Drives: 2017 860
Installed the FT86 Speedfactory 2017/18 axel back muffler delete on my 860 and i like it.
2017 Toyota 860
ctmandu is offline   Reply With Quote
