Old 04-22-2018, 08:07 PM   #18761
notout86
Drives: GTS 86 auto
In our 70's we like our comfort and dislike the jarring and jiggly ride. After riding in a Skoda Aptiva I realised it is possible to have comfort and good handling with minimal body roll so investigated. I was thinking of different springs +/or dampers. Someone suggested a gel-cushion.
I trialled a couple of gel cushions and one does exactly what I wanted. The jarring and jiggly ride now feels nicely damped so much so that I think everyone could give it a try. All it cost was $20 Australian and I know I could have spent a heap on spring/damper experimentation and maybe never have got it to feel right. I reckon the o.e. seats could have been tuned by the makers to much better match the suspension. The feeling I get is that the wheels are more stuck on the road (even though the suspension is the same) and I am inclined to throw the car around more.
The tradeoff is a feeling of being perched up on the seat rather than down in it and not located by it as much resulting in a a slight feeling of wallowing and body roll which you would expect. I have lowered the seat to the max to compensate and got used to it quickly. Previously I had the seat raised about 40mm.
The cushion is 430 X 330 X 60 mm and quite heavy due to a generous bag of gel inside a cover of quite soft 30 mm foam both top and bottom and around the sides. It is not memory foam. My feeling is that is the gel that is doing most of the work. Maybe using just the bag in the seat would do the trick. Widthwise it is a perfect snug fit between the side bolsters but I have trimmed the foam to fit back between the seat-back bolsters. I made an hollow for the wedding tackle too and trimmed foam off the front as it pressed on the back of my thighs up by the knees. At $20 I can afford experimenting.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
humfrz (04-22-2018)
Old 04-22-2018, 08:17 PM   #18762
notout86
Drives: GTS 86 auto
Originally Posted by Roth View Post
Today I finally (maybe not) got rid of the driver door rattle. Sounds waaay better now
Are you going to tell us the source of the rattle?
Old 04-22-2018, 09:57 PM   #18763
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Originally Posted by notout86 View Post
I did mine at 300Km and the oil looked like diluted silverfrost paint (only gold not silver). There were thousands of tiny particles suspended in it and it streaked when I dragged a screwdriver through it. I dipped a magnet in it and the particles were not attracted to it. I had the oil out in bright sunlight when I noticed it. It did not show on the dipstick. The particles did not clump or settle out in the drain pan. I was surprised how they got through the filter.
What the particles were remains a mystery to this day. I sought answers at the time and no-one on the forums could explain.
That was 5 years ago and at 50,000Km the car uses no oil between changes.
If this has prompted you to check your oil at a very low mileage too I'd love to hear if you get the same result and especially if you inspect under a microscope or have a sample analysed. I regret that I did not do that.
I read how the torsen diff oil gets lots of crap on the magnetic drain plug so I changed it at low mileage twice. Once to flush and left the second in. "Cleanliness is next to Godliness" as the saying goes.
Why do you think they made it through the filter? You pulled them out upstream of the filter. When the engines are first run, the moving parts bed in and those tiny specs of metal have to go somewhere. The sump is where they go and the filter prevents them from routing back to the bearings.
Quentin is offline   Reply With Quote
Old 04-23-2018, 12:05 PM   #18764
assbox
assbox's Avatar
Drives: Whiteout FRS
Finished my interior project this weekend. did some foot-well illumination for when im night drifting on the track.
IG: ft86carbon
assbox is offline   Reply With Quote
The Following 8 Users Say Thank You to assbox For This Useful Post:
BRZyJ (04-23-2018), MJones_RB (04-24-2018), new2subaru (04-23-2018), oso_25 (04-23-2018), Raven86Project (04-23-2018), RToyo86 (04-24-2018), SuperTom (04-23-2018), zeal86 (04-23-2018)
Old 04-23-2018, 12:41 PM   #18765
zeal86
zeal86's Avatar
Drives:
Originally Posted by Southcbishop View Post
Anybody got a stock OEM frs headlight laying around? only need a pic of the underside of one, either side.
Still need the pic? My headlights are not installed right now... they are Monogram headlights though... I can take a pic this afternoon... let me know.
IG @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 04-23-2018, 04:46 PM   #18766
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Swapped out the snow shoes yesterday, back in stock "summer" form.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 04-23-2018, 08:47 PM   #18767
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
Getting ready for my next mod
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
Old 04-23-2018, 08:52 PM   #18768
new2subaru
Weight Weenie
Drives: 15 FR-S
We finally got a warm day here. I took it for a long drive after work and then retorqued all the nuts I messed with, including the lug nuts.
I found a top strut mount nut completely loose! I guess I missed one...
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
Jordanwolf (04-24-2018), Tcoat (04-23-2018)
Old 04-23-2018, 08:53 PM   #18769
The road/driveway needs resealing, first ......
humfrz is online now   Reply With Quote
Tcoat (04-23-2018)
Old 04-23-2018, 10:31 PM   #18770
Raven86Project
I come to share car stuff and get this LOL
Will think twice before posting here next time.
IG: raven86project
Build Thread HERE
The Following User Says Thank You to Raven86Project For This Useful Post:
humfrz (04-23-2018)
Old 04-23-2018, 10:47 PM   #18771
Ashikabi
Ashikabi's Avatar
Why are you putting a white lip on a black car?
Old 04-23-2018, 10:49 PM   #18772
Raven86Project
The parts are unpainted
IG: raven86project
Build Thread HERE
Old 04-23-2018, 10:56 PM   #18773
Ashikabi
Ashikabi's Avatar
Well just spray your driveway at the same time then
The Following 4 Users Say Thank You to Ashikabi For This Useful Post:
arxm (04-25-2018), humfrz (04-23-2018), oso_25 (04-24-2018), Raven86Project (04-23-2018)
Old 04-23-2018, 11:05 PM   #18774
Decep
Drives: 2013 FR-S Series 10
oh man, that is gonna hurt your eyes at night.
