Old 04-21-2018, 10:45 PM   #421
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Teseo View Post
Why you will drive like an asshat for just to keep on boost?
? Makes no sense.
Sent from my SM-G960U using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-21-2018, 10:46 PM   #422
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Lakitu View Post
Can you still blow an engine driving under 4.5K RPMs while boosted (non-spirited daily driving), or is blowing an engine entirely because people are redlining boosted cars that haven't had the bottom rebuilt?
You can blow a motor both on and off boost.
Old 04-21-2018, 11:09 PM   #423
Teseo
Drives: frs
Originally Posted by SPCorBUST View Post
? Makes no sense.
People with boosted cars drive like an asshat just making blow of sounds for letting know everyone they are boosted
Old 04-21-2018, 11:23 PM   #424
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
My thought process is that torque breaks parts as one type of force on a motor. Rpms can break parts because inertial forces dramatically increase with rpms. Oil starvation will lead to parts breaking. Heat can cause parts to break, oil to thin. Timing problems with air and fuel or timing belt slips can lead to stuff breaking. I can go on, but everything is exacerbated with more power and with boost or more boost and with pushing a motor beyond its OEM manufacturing.
At low rpms engine load and torque can still be high, heat can be higher because the engine isn’t circulating as well or efficiently, and oil pressure can be lower on rpm dependent pumps, so bearings can fail easier, maybe.
Old 04-22-2018, 03:45 PM   #425
CSG Mike
CSG Mike's Avatar
TIL Mike drives like an asshat.
Side note: I don't have a BOV.
AFRichZC6 (04-25-2018)
Old 04-22-2018, 08:07 PM   #426
Lantanafrs2
Drives: 2013 frs red
I would imagine that compared to stock, 4500 to 5000 rpms is rather "spirited " in a boosted twin.
Lantanafrs2 is offline   Reply With Quote
Old 04-23-2018, 07:57 AM   #427
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Yes it is!!
I rarely ever need to go to my peak of 300whp which is weirdly available at 6500 rpms. At 4500-5000 my power is 205-230whp while torque is 237wtq at those rpms.
SUB-FT86 is offline   Reply With Quote
Old 04-25-2018, 02:59 AM   #428
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
When someone asks you "how much horsepower your car has", do you respond with
B. braking hp
C. crank hp
W. wheel hp
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-25-2018, 10:38 AM   #429
Pat
Pat's Avatar
Drives: 2023 BRZ
B. braking hp
C. crank hp
W. wheel hp
N. Not much
The Following 6 Users Say Thank You to Pat For This Useful Post:
Code Monkey (04-25-2018), CSG Mike (04-25-2018), ichitaka05 (04-25-2018), JazzleSAURUS (04-25-2018), Phantobe (05-07-2018), strat61caster (04-25-2018)
Old 04-25-2018, 12:58 PM   #430
Lakitu
Lakitu's Avatar
Originally Posted by Pat View Post
N. Not much
LOL
Old 04-25-2018, 04:00 PM   #431
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Awww all the good comments were deleted
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
strat61caster (04-25-2018), totopo (04-25-2018)
Old 04-25-2018, 05:25 PM   #432
FRS Justin
Drives: 2013 Asphalt FRS
So what did I miss
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 04-25-2018, 09:33 PM   #433
totopo
Drives: 370z
Originally Posted by FRS Justin View Post
So what did I miss
Not much, I think after your reply I only made one more post this morning, then the whole chain got nuked. If you didn't see it I can PM it, I was pretty proud of that one. I didn't check the board till hours later so I don't know if any more drama was stirred.
You know, reading this nostalgic post just kind of annoys me. When it was necro'd I went back and started reading again from the beginning. All these people attacking OP. I feel like I tried to give even, thoughtful responses which were being met with nothing but sarcasm, memes, and obfuscation.
The amusing thing to me, is now basically everyone agrees with OP. They way he talks may have rubbed people the wrong way, but you see what other tuners and testers say, you see all across this forum, it seems like everyone has picked up that rods are the weakest with significant boost, and there is a significant risk of failure at 300hp.
I kind of feel vindicated, even though there is no acknowledgement, got annoyed at one necro circlejerk post in particular, and I got annoyed and incredulous that people want to keep arguing 2 years later.
I feel sorry for the moderators. I got too angry and slung some mud, probably went farther than I should and probably crossed some board lines, but I still feel like my posts and words were justified and I feel my anger at the particular action is especially justified given the real world consequences.
Especially at this stage when the platform isn't new anymore, and there are probably a lot of people jumping in who can only afford used cars, who can't afford new engines.
But I am sorry I put the moderators in a bad place. I don't completely agree with the deletions, but I am glad that at least the thread wasn't locked.
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
bcj (04-25-2018)
Old 04-25-2018, 10:42 PM   #434
FRS Justin
eventually people that boost will learn the truth. I stopped sharing along time ago, and in that time i have stopped the dreaded blow by issues rod failures and head gasket failures, running 700+ at the wheels for 2+ years. so when you decide on LA Sleeves, your welcome, when you decide on the new improved mls headgsks, your welcome, 1/2 inch studs your welcome closed deck fa20 your welcome, and the list goes on.
now people just have to figure out what machine work is needed and what specs.
710whp
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
bcj (04-25-2018), Irace86.2.0 (03-16-2020)
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 05:28 AM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 06:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 10:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 04:05 PM
