Old 04-24-2018, 10:53 AM   #15
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Originally Posted by Qwimby1 View Post
I really like the car, but rear visibility isn't great, IMO. It's worse for me because my neck has been fused and I can't turn my head as far as most people. I have the parabolic extra mirrors outside, and I'm trying to put a much larger one on the windshield mount. It's so heavy, though, that the original mirror it attaches to sags. I'll have to find a way to tighten it up. I'm also going to add a backup camera but that won't help any when the car is moving. Does anyone else have a problem with blind spots?
I have a 2014 BRZ with all the factory mirrors and have no blind spots because I set up my mirror angles correctly. The setup is that as soon as a car cannot be seen in my rear view mirror, it starts appearing in my side view mirror, which is also where the blind spot would be if not setup correctly.
The down side is that it's difficult to parallel park and reverse with the mirrors setup that way, because you can't see the lane/curb through the mirrors without moving them again.
Keep calm and drive safe
housecat is offline   Reply With Quote
The Following User Says Thank You to housecat For This Useful Post:
funwheeldrive (04-24-2018)
Old 04-24-2018, 11:07 AM   #16
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by navanodd View Post
No problem with blind spots at all, I adjust my mirrors like this:
https://www.caranddriver.com/feature...id-blind-spots
This is all very helpful. I've used that wide outside position for a long time, but the FRS presents some fairly unique problems for me with my fused neck, especially cars passing from right to left behind. I keep the passenger seat positioned so I can see through the small quarter window.
I'm very glad to learn about Rexspeed. I'll order a set today. We Miata owners use a similar system made by Modiction, but I wound up using just the one on the passenger side, and the regular mirror on the driver side. I don't much care for the blue, but I'll try to get used to it. There once was a company called Multivex which made a very different and very effective mirror, but I think they've been out of business for a long time. The first 2/3 them were were flat, but the outer third curved forward, displaying a very wide angle behind without distortion. I had them on one of my motorcycles and they were terrific, but I was never able to get another set.
Qwimby1 is offline   Reply With Quote
The Following User Says Thank You to Qwimby1 For This Useful Post:
Tcoat (04-24-2018)
Old 04-24-2018, 01:48 PM   #17
NOHOME
Drives: RAVEN
After 40 plus years of driving, I never really learned to set the side mirrors properly until I started driving this car. Takes a while to get them set juuuuussssttt right, but once you do you wont let anyone else drive the car.
Now, backing up at night down a dark narrow laneway is still an issue. If ever there was a car that needed a rear camera, this is it.
NOHOME is offline   Reply With Quote
Old 04-24-2018, 01:53 PM   #18
A rear camera and back up lights that have a few more lumens than Dollar Store solar garden lights.
Old 04-24-2018, 01:54 PM   #19
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Agreed; upgrading the reverse lights to brighter LEDs was one of my favorite things I've done to the car.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
funwheeldrive (04-24-2018), Tcoat (04-24-2018)
Old 04-24-2018, 02:30 PM   #20
Firecruiser
Drives: 2014 brz
The rexspeed i do believe come in clear if you would prefer that.
Another option are these. https://www.ebay.com/itm/POLARIZED-B...-/192209873847 They have a split section on the edge.
Firecruiser is offline   Reply With Quote
The Following User Says Thank You to Firecruiser For This Useful Post:
Qwimby1 (04-24-2018)
Old 04-24-2018, 02:43 PM   #21
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
LET THERE BE LIGHT lol everyone needs these when backing up
JustSomeGuy is offline   Reply With Quote
The Following User Says Thank You to JustSomeGuy For This Useful Post:
Old 04-24-2018, 03:25 PM   #22
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
I had trouble with blind spots when I first got the car. I fixed it with a header, stage 2 tune, CAI, and FI. You can't run into anything if you're way far out in front of it!!!1
#360hp
bkharmony is offline   Reply With Quote
The Following User Says Thank You to bkharmony For This Useful Post:
housecat (04-24-2018)
Old 04-24-2018, 03:30 PM   #23
Qwimby1
I just ordered the split mirrors. Now I gonna get those lights! Anyone have part numbers?
Old 04-24-2018, 03:49 PM   #24
Qwimby1
OK. I got all the info from from Diode Dynamics. I see that all applies to the upper lights. Are the lower lights in the picture still the stock ones?
Old 04-24-2018, 03:55 PM   #25
8RZ
The Gunshine State
8RZ's Avatar
I don't think so but the lower reverse lights are the ones I upgraded. The lights in the tails will need a special wiring kit (turn as tail) and will need clear bulbs.
Current DD: M235i
Old 04-24-2018, 04:12 PM   #26
Qwimby1
Yes, Diode Dynamics has a video showing how to convert all the upper. Total for that kit is $230. I'll look for a replacement for the lower lights first.
Old 04-25-2018, 10:09 AM   #27
Azyael
Drives: Toyota 86
Convex side mirrors set correctly and a Broadway 270mm rear view mirrior snap on fixed everything for me!
Azyael is offline   Reply With Quote
Old 04-25-2018, 10:41 AM   #28
Jordanwolf
Rice King
Jordanwolf's Avatar
This ^ Word for word.
my wife still will not swing the mirrors out enough to see what is beside her. About 40% of what she sees in the mirror is just the side of the car. At least her new car yells at her if there is somebody in the blind spot.
Such a hazard. I know enough people who rely on the little blind spot indicator and beeping for changing lanes... It's maddening to think that these same people at some point drove without these technologies. I feel the same about people who exclusively use reverse camera's to reverse, I've actually watched someone back into a car while actively looking at the reverse cam............. ????
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Blind Spot Fix? Stewie BRZ First-Gen (2012+) — General Topics 57 04-09-2015 09:01 PM
Blind Spot Detection? Reggaeboyz Electronics | Audio | NAV | Infotainment 25 02-03-2014 03:33 PM
Blind spot? euroshowoff Scion FR-S / Toyota 86 GT86 General Forum 47 12-28-2013 04:38 PM
Blind spot check on BRZ. qqzj BRZ First-Gen (2012+) — General Topics 44 11-21-2013 02:44 AM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 03:17 PM
