Old 04-13-2018, 01:57 PM   #71
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Low beam high beam mechanism and auto off question
1. On the 2017 86, is it correct that there's no such thing as a separate led bulb for the low beam and high beam. It's just a piece of plastic that block part of a single headlight LED beam that's above a certain angle?
2. Is there a way to program the computer to allow for the headlights to be on but auto shut off when the key is pulled from the ignition? I think the small LED driving lights are fine, but at dusk, I find myself manually turning on the headlights, then have to remember to turn it back to auto so that they turn off when I pull the key out of the ignition.
pcguru2000 is offline   Reply With Quote
Old 04-17-2018, 10:58 PM   #72
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
1) correct, the projector has 1 light source. the shield on the inside flips down when you turn on the highbeam allowing light above the cutoff.
2) not that I know of.
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
pcguru2000 (04-19-2018)
Old 04-17-2018, 11:00 PM   #73
HeresMyMind
Originally Posted by tobin View Post
Hey I'm in CT too
Rear fog light on my dash- no I don't care about that. I would like the rear fog bulb to turn on/off with my front fogs using the stalk switch. No separate switch needed. I rarely use my fogs unless it's necessary. A diagram would be great. I've run wires to my backup camera so I'm comfortable doing that. Thanks!
Here you go.
-B
tobin (04-18-2018)
Old 04-18-2018, 10:30 AM   #74
tobin
tobin's Avatar
Drives: '13 BRZ
Originally Posted by HeresMyMind View Post
Here you go.
-B
Thanks very much for this. Can you please give your opinion on this method? Is one preferred (safer?) than the other?
tobin is offline   Reply With Quote
Old 04-19-2018, 05:43 PM   #75
HeresMyMind
either way will work. I prefer my setup because it has a separate power source and only uses the oem fog wire as a trigger to turn it on as opposed to that person's single fog is now powering 2 bulbs, or double the wattage.
-B
tobin (04-20-2018)
Old 04-20-2018, 09:59 AM   #76
tobin
tobin's Avatar
Drives: '13 BRZ
-B
Good point, thanks!
Old 04-24-2018, 08:48 AM   #77
ZDan
ZDan's Avatar
Drives: '23 BRZ
'17 BRZ, coupla questions:
1. Any way to turn off the DRLs?
2. Any way to have the DRLs only be on the dimmer of the two brightness levels when they are on?
Old 04-24-2018, 08:59 AM   #78
HeresMyMind
Besides manually putting in a toggle.
Otherwards it may involve ecu programming (Toyota should be able to do it) Subaru doesn’t do that stuff so they don’t know how to.
Check the DRL input wires. There may be 1 wire for low power 1 for high power. If that is the case. Cut the high power wire. And hook up the low power toboth the inputs from the headlight making sure to install a diode to not allow backflow.
-B
Old 05-22-2018, 11:23 PM   #79
VanLurker
Drives: 2015 FRS
Hi there,
I just purchased some used 17' 86 headlights, but it turns out that 2 of the mounting points on the passenger side's headlight is broken.. Does anyone know where I can get a replacement back piece and/or the procedure in replacing it?
I assume I will have to bake it open and re-bake it closed.
TIA!
VanLurker is offline   Reply With Quote
Old 05-23-2018, 11:00 PM   #80
NRXRaptor
Originally Posted by VanLurker View Post
Hi there,
TIA!
a toyota dealership. pics help too
NRXRaptor is offline   Reply With Quote
Old 05-24-2018, 01:50 AM   #81
VanLurker
Drives: 2015 FRS
I even checked the Toyota Parts page and wasn't able to find just the housing
Old 05-25-2018, 09:56 PM   #82
HeresMyMind
Unfort you cant buy just that part. you'd have to source a used headlight, maybe you can find one with a busted lens and you can just swap the lenses.
-B
Old 05-27-2018, 01:38 PM   #83
dgschmidt01
dgschmidt01's Avatar
Drives: 2013 Hot Lava FR-S
I need some help with a pair of Spyder headlights for a 2013 FRS. I bought some Spyder headlights to swap out the factory ones. After getting the bumper off and everything ready I looked at the connection on the spyder headlights and on my car. They were the same size....has this happened to anyone before or was I suppose to find an adaptor for these? I thought it was all plug and play in this case. I wasn't sure if this was the proper forum or not. Any help would be appreciated thanks!
Sent from my SM-G950U using Tapatalk
dgschmidt01 is offline   Reply With Quote
Old 05-27-2018, 10:35 PM   #84
HeresMyMind
It looks like you got headlights with the wrong plugs, probably a poor vendor or Chinese replica of those headlights. contact the seller for more help.
-B
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
