Old 04-23-2018, 12:16 PM   #491
wparsons
wparsons's Avatar
Originally Posted by Shark_Bait88 View Post
My point being of going to significantly softer rates, not necessarily the relation of front to rear rates. And I mistakenly used German when I really meant Euro, basically just in contrast to the various Asian suspension companies, or US rebox/custom adaptation setups, which seem to keep stiffer setups overall.
The KW clubsports are 6kgF/7kgR though... beyond that, overly stiff springs are a bandaid for not enough bump travel in an application, so a lot of the "stance" setups run rates WAY higher than ideal.
flickr
Old 04-23-2018, 12:27 PM   #492
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
The KW V3s are much closer in spring rates to the SACHS, Bilsteins, and R&Ts though. And yeah, I don't disagree about stiffness being a bandaid to travel/proper valving.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-23-2018, 12:39 PM   #493
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Ah I like that perspective.
I'd be a lot more interested in the Ohlins if they just flipped the springs F/R and I had good confidence in their adjustment range to get the springs I'm thinking of, that would have been the case if they were the same valving as the MI20 but with different valving and the rear so soft I'm not sure.
buying coilovers is hard if you overanalyze things
ineedyourdiddly
Old 04-23-2018, 02:01 PM   #494
Shark_Bait88
I'm on the 4th suspension setup on my car... But that's more because I'm indecisive and likely have undiagnosed car modification adhd.
Old 04-23-2018, 05:26 PM   #495
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Scracho View Post
I suppose there is only one way to find out... I'll keep you posted
I would love ride if you install them! I'll buy you a coffee
Old 04-23-2018, 11:33 PM   #496
oppiee
Drives: 2014 Scion FRS (Red)
Hey guys another question. How do you fully tighten the centre nut and at what torque?
oppiee is offline   Reply With Quote
Old 04-24-2018, 11:16 AM   #497
Scracho
Drives: 2018 Subaru BRZ
I'm likely going to run higher spring rates than the kit comes with and Vorshlag front upper camber plate and rear plate with radial bearing upgrade.
I'm excited to see how this all plays out
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 04-24-2018, 12:47 PM   #498
wparsons
wparsons's Avatar
Strap wrench on the shaft and normal socket on the nut, and not sure about the torque spec off the top of my head.
flickr
Old 04-24-2018, 07:22 PM   #499
new2subaru
Weight Weenie
Drives: 15 FR-S
What spring rates are you thinking about? I'm curious as to how the car would feel.
Old 04-25-2018, 01:07 PM   #500
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If I had the BRZ tS, then I would definitely change the suspension. I cannot stand the wheel gap.
Give us an update when you have the Ohlins installed.
Old 04-25-2018, 05:14 PM   #501
oppiee
My coilovers are already mounted. Not sure if that will work
I am trying to tighten the top nut, but every time to hit the torque spec of 30 nm, it seems to turn back its weird.
Any idea why? IS it because Iam turning the shaft?
Old 04-25-2018, 05:37 PM   #502
churchx
churchx's Avatar
Drives: 2014 GT86
oppiee: maybe this might be of help?
Old 04-25-2018, 06:42 PM   #503
oppiee
I'll give this a try. Lol hope it doesn't snap anything lol
Old 04-25-2018, 09:20 PM   #504
wparsons
wparsons's Avatar
Turn back instantly, or works loose over time?
You should be able to get a strap wrench in even with the coilovers in the car, might need a helper to hold it (or use the torque wrench at the top).
I've got this set, worked great for me on the v3's (off the car).
http://www.canadiantire.ca/en//pdp/m...-0588335p.html
flickr
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
