#491 | |
#492 |
Drives: 2013 Firestorm FR-S
The KW V3s are much closer in spring rates to the SACHS, Bilsteins, and R&Ts though. And yeah, I don't disagree about stiffness being a bandaid to travel/proper valving.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#493 | |
Drives: '13 FRS - STX
I'd be a lot more interested in the Ohlins if they just flipped the springs F/R and I had good confidence in their adjustment range to get the springs I'm thinking of, that would have been the case if they were the same valving as the MI20 but with different valving and the rear so soft I'm not sure. buying coilovers is hard if you overanalyze things
#494 |
I'm on the 4th suspension setup on my car... But that's more because I'm indecisive and likely have undiagnosed car modification adhd.
#495 |
Weight Weenie
Drives: 15 FR-S
#496 |
Drives: 2014 Scion FRS (Red)
Hey guys another question. How do you fully tighten the centre nut and at what torque?
#497 |
Drives: 2018 Subaru BRZ
I'm likely going to run higher spring rates than the kit comes with and Vorshlag front upper camber plate and rear plate with radial bearing upgrade.
I'm excited to see how this all plays out
On my fourth 86... and everything in between
#498 |
Strap wrench on the shaft and normal socket on the nut, and not sure about the torque spec off the top of my head.
#499 |
Weight Weenie
Drives: 15 FR-S
What spring rates are you thinking about? I'm curious as to how the car would feel.
#500 |
Drives: '15 BRZ RA
If I had the BRZ tS, then I would definitely change the suspension. I cannot stand the wheel gap.
Give us an update when you have the Ohlins installed. Last edited by nikitopo; 04-25-2018 at 02:51 PM. |
#501 |
My coilovers are already mounted. Not sure if that will work
I am trying to tighten the top nut, but every time to hit the torque spec of 30 nm, it seems to turn back its weird. Any idea why? IS it because Iam turning the shaft? |
#502 |
Drives: 2014 GT86
oppiee: maybe this might be of help?
#503 |
#504 | |
You should be able to get a strap wrench in even with the coilovers in the car, might need a helper to hold it (or use the torque wrench at the top). I've got this set, worked great for me on the v3's (off the car). http://www.canadiantire.ca/en//pdp/m...-0588335p.html
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 05:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 12:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 04:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 03:27 PM |
