Old 04-21-2018, 08:48 PM   #1
Cothman4Life
Drives: 2016 VW Golf, 2017 Toyota 86
Squeeking coming from rear after tire change
Hey guys not sure if this is a big issue but wanted to see if anyone had this issue arise or if I'm just being over paranoid as usual.
I just changed over my winter to my stock summers. Lifted from the rear diff and front frame as in the manual. Torqued to spec and all that fancy stuff. But now when I get in the car or the car goes back and forth there's squeeking coming from the rear. I'm not sure where it's coming from.
I also notice that my breaks are really firm getting into the car, then soften up as I start the car.
Sent from my Pixel 2 XL using Tapatalk
Cothman4Life is offline   Reply With Quote
Old 04-23-2018, 11:34 AM   #2
The act of jacking it up probably just moved something a bit. The squeak should go away.
The firm brakes is normal. When the car is not running the power assist is not working so they are firm. You probably just never noticed before.
Cothman4Life (04-23-2018)
Old 04-23-2018, 12:06 PM   #3
Cothman4Life
Thanks, thought it could be a hub bearing as it seems to be one side. But hopefully it does go away.
Old 04-23-2018, 12:13 PM   #4
I may have misunderstood what you meant by "squeak" is it a rotational sort of sound? Not suspension flexing? If rotational then check your lug nut torque.
Old 04-23-2018, 12:24 PM   #5
Cothman4Life
It's when I get in the car and it jolts back and fourth. I've torqued it down to spec but if that might be the case I'll double check the torque.
Old 04-23-2018, 12:24 PM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
when you stop after a good drive (highway for 30 mins) check each rear wheel for extra heat. You may have a stuck e brake or caliper. Esp. up north after the winter and all that salt.
guybo is offline   Reply With Quote
Old 04-23-2018, 12:27 PM   #7
Cothman4Life
Wouldn't it make sound as I'm driving if it's stuck? Or would I not notice over road noise?
Old 04-23-2018, 12:27 PM   #8
So not rotational then. Probably just got some crap on the suspension when it drooped while jacked up. Would think it will clear it's self but if persists just get it checked. May need some lube.
Old 04-23-2018, 04:52 PM   #9
Impureclient
Drives: 2015 FR-S
That's what she said.
Pieces of Tire Coming Off? soccerk18 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-10-2016 10:49 AM
5axis rear lip coming off triwoody Cosmetic Modification (Interior/Exterior/Lighting) 6 07-16-2013 01:40 AM
Humm Coming From Right Rear Tire Well While Car iIs Parked In The Garage davesrave BRZ First-Gen (2012+) — General Topics 2 05-09-2013 09:06 PM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 03:14 PM
Total noob tire-change question Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 04-17-2012 08:15 PM
