Old 04-21-2018, 07:36 PM   #113
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Harey View Post
Ok still interested to hear why.
I just remember that they said the car changed the way it felt. Some comments were nose heavy, delayed throttle responses, etc.
I think it was Swarb? that had three different FI setups on track and said he was faster NA.
Mike at CSG may remember.
Old 04-21-2018, 07:38 PM   #114
new2subaru
Weight Weenie
Drives: 15 FR-S
Sorry, I thought the thread was about more power ruining the car. It doesn't, track or street, unless you don't know how to drive. More power as many have said needs proper support. That's my point. I can't imagine someone properly boosting and getting shity times unless they have more car than they can handle.
Just putting in my $.02.
TBH, I can't either, but I'm about to find out haha
I will need considerable seat time before i will need more power. That I do know.
Old 04-21-2018, 09:34 PM   #115
Lantanafrs2
Drives: 2013 frs red
Originally Posted by PetrolioBenzina View Post
More fun is an OFT flash away, for cheap. The V4 tunes and E85 is impressive.
That's my current set-up. The v4 e85 is nice
Lantanafrs2 is offline   Reply With Quote
Old 04-21-2018, 09:35 PM   #116
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by extrashaky View Post
Recall what got us onto this subject in the first place:
I still stand by the original statement. Zero proof shown that boxer is responsible for the handling success of this car...just marketing buzzwords.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-21-2018, 11:32 PM   #117
extrashaky
Drives: 2014 BRZ Limited
That wasn't the original statement.
This car's handling has zero to do with 'boxer'.
Glad to see you are backpedaling away from that and now recognize that while it isn't solely responsible for the handling, it does play a part.
Old 04-21-2018, 11:37 PM   #118
venturaII
venturaII's Avatar
If you're trying to dice up my posts and spin them in some other direction, let me be clear: boxer is not responsible for this car's handling. Believe what flat-brimmed marketing hype you like, but a lowly $25K MX5 has already proven that wrong.
Old 04-21-2018, 11:43 PM   #119
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If you're trying to dice up my posts and spin them in some other direction, let me be clear: boxer is not responsible for this car's handling. Believe what flat-brimmed marketing hype you like.
That's like saying the shocks aren't responsible for the handling because the tires matter too.
Without the boxer layout, given everything else is the same (coupe, 2+2, FR, steel body, DOHC, wheelbase, track), the CG would be higher and handling therefore worse or harder to tune for, wether it fits your narrative or not.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
mrg666 (04-22-2018)
Old 04-21-2018, 11:45 PM   #120
venturaII
venturaII's Avatar
And here come the excuses...
Done.
Old 04-21-2018, 11:47 PM   #121
extrashaky
But you're not being clear. First you said it had zero impact on the car's handling, then you implied it's not solely responsible, leaving open the possibility that it might contribute to it. Which is it?
Old 04-21-2018, 11:49 PM   #122
venturaII
venturaII's Avatar
Don't think I ever threw in the caveat of 'solely'. That was your own addition.
Now, really done.
Old 04-21-2018, 11:57 PM   #123
extrashaky
Then clarify instead of playing word games. Are you saying that the boxer configuration contributes nothing whatsoever to the handling of the car, or are you leaving open the possibility that it does contribute along with other factors?
Old 04-22-2018, 12:05 AM   #124
fatoni
That's speculative and likely not true. That super wide engine isn't placed very low because it would occupy space that suspension and the steering rack (not sure) occupy. An inline or v configuration means it can be put in the car much lower. Why didn't Porsche go on endlessly about cog? Probably because the Cayman is closer to a gtr than a miata or other impressive cars (brz included)
Drive upgrades. Don't buy them.
Old 04-22-2018, 12:16 AM   #125
extrashaky
The low end of the engine might end up lower, but the high end might also end up higher.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
mrg666 (04-22-2018), nikitopo (04-22-2018)
Old 04-22-2018, 12:24 AM   #126
Cole
Not a troll
Cole's Avatar
Originally Posted by nikitopo View Post
When you are working on weight reduction of rotational and non-rotational parts and not just on power, then it depends also with what you compare it. The acceleration comparison I did last time it was based with a '13 year UK car which is around 1230kg (2712 lbs). The latest cars and especially in US are known to be much heavier pretty close to 1280-1290 kg (2822-2844 lbs). It depends also the trim level. If you do a simple math equation, then you'll find that weight to power ratio gives an equivalent from 240hp to 251hp if you compare it to the heavier car. I said feels like 250-260hp, because we cannot even agree if the first cars had an actual 200hp or a 190hp power figure.
Do your research better next time.
hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahaha
Cole is offline   Reply With Quote
The Following 2 Users Say Thank You to Cole For This Useful Post:
fatoni (04-22-2018), venturaII (04-22-2018)
CNET on 86: More power would ruin it Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 03-04-2017 05:19 PM
I don't want to ruin my dream car. TruthfulDeception Engine, Exhaust, Transmission 28 03-23-2016 10:40 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 03:40 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-12-2012 11:19 PM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 03:52 PM
