Noob
Drives: FR-S Mammogram
Last year, I got P0137, P0037, and P0141 codes during a track day. After clearing several times only to have it return, I did some searching here and saw it was most likely a dead secondary o2 sensor.
I replaced the sensor, but now not even a year later, I got the same codes at a track day again! Could it be because of the mods I have? Should I just disable these CELs?? I really don't want to have to be buying secondary o2 sensors every few months... engine mods: JDL UEL header, OP, FP MotoEast flex fuel (EVAP connection) Dyno tuned via ECUtek
#2 |
Drives: RX-7 / BRZ
I also go through the rear 02 sensors 2 times a year. I figured mine was because the turbo though.
Os your header cattless? If you arent using it for emissions you could try a spacer to back it out of the exhaust flow to prolong its life.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#3 | |
Noob
I'm thinking it may have to do with tracking. A friend of mine has the same set up and has burned through 2 or 3 o2 sensors as well. Did you disable your codes with ecutek?
#4 |
Drives: FT86
You will need to disable dtc codes and also the rear 02 fueling compensations
| The Following User Says Thank You to steve99 For This Useful Post: | Jyn (04-30-2018) |
#5 | |
Noob
| Secondary O2 sensor heater current | armstrom | Software Tuning | 2 | 08-02-2017 01:46 PM |
| Aftermarket header, new secondary O2 sensor, code P013A | kizz | Software Tuning | 15 | 06-01-2017 11:01 PM |
| Secondary o2 sensor needed in Portland ASAP! | DarrenDriven | Northwest | 2 | 02-21-2016 09:04 PM |
| Secondary O2 sensor needed for Cruise control? | DJCarbine | Engine, Exhaust, Transmission | 31 | 04-10-2015 09:49 PM |
