#3221 | |
Drives: BRZ 2017 Pure Red, MT
What shims are you using? OEM? I tried to find titanium shims, but didn't find anyone selling them. |
#3222 |
Drives: 2013 Raven FR-S
I'm actually using the ones that came with my other StopTech pads. They're really thin and do a good job reducing noise. Not sure where you can buy shims like that by themselves though. I didn't use the stock shims because they seemed too thick to use with the already super thick Winmax pads.
| The Following User Says Thank You to smg1138 For This Useful Post: | nico_rsx (04-17-2018) |
#3223 |
Drives: 15 BRZ
Bit more than I'd like to spend. My concern with the W3 are the "corrosiveness" of the dust.
Delta/CENLA Region SCCA - DS
#3224 |
Drives: 2017 BRZ
Stay away from Hawk and EBC then, from what I have seen. Far as I know, Winmax isn't particularly corrosive, except maybe to your lungs...
#3225 |
Drives: 15 BRZ
*adds W3's to cart*
#3226 |
Got my Shorai battery installed. Was able to use the stock tie down by just using some 1" nylon spacers. It feels totally secure, so hopefully no issues passing tech.
Trying to decide if I should put some kind of foam shim between the tie down and top of the battery? Think I've seen some other people do that. |
| The Following User Says Thank You to smg1138 For This Useful Post: | strat61caster (04-18-2018) |
#3227 |
Drives: 2017 BRZ
That tie down is a buckle risk. I'd recommend getting a solid one. I don't use foam, but I have one if the trays specifically for the battery...
#3228 |
How is it a buckle risk? Do you think it could come loose? The only tray currently in production I've found for this battery is like $160 :/
#3229 | |
Drives: 2017 BRZ
A solid hold-down would alleviate this particular risk. That should be a lot less than $160. The stock hold-down is formed (thin) steel - a little twist could put just enough of a stress line into the steel that it could decide to fold. Which would leave you with a very loose battery. Far less likely under normal conditions, but those aren't always guaranteed either... A proper fitting battery tray is even better than a solid hold-down, and $160 sounds reasonable for a battery tray (depending on the specifics I guess) - about what I spent I believe. I can't quantify how much of a risk it is, to be sure. I've suffered losses due to a series of unlikely events, so I make note of the things that I'm not super comfortable with now... especially when a failure increases fire risk (which I did not encounter) C
| The Following User Says Thank You to cjd For This Useful Post: | smg1138 (04-18-2018) |
#3230 |
Drives: '13 FRS - STX
My battery is mounted similarly, it's survived a few autox's and being rear-ended twice in the last 6 months. Check it regularly as I think cjd is correct, you're putting pressure on the bracket to lock the battery down, if the bracket deforms (it's steel so it probably will over time) it can become loose and then you can start running into trouble. It's a passable temporary solution imho.
As an aside, my uncle had an NB miata, the thing would shut down upon hitting a bump randomly, you'd coast but could eventually restart and keep going. The battery was loose and it would slide into the bracket grounding out the car and turning everything off. My uncle was a certified mechanic, his gf's son was a certified mechanic, my father and I work as mechanical engineers, it stumped us all for a year. It also passed every autox inspection it went through including a battery check, nearly a dozen or so. My brother noticed it a few hours after he bought the car, fixed it in 5 minutes.
#3231 | |
Drives: 2013 FRS
https://www.ebay.com/itm/19cm-Alumin...xaXPr-&vxp=mtr $10 just search on ebay for "19cm Aluminum Light Weight Battery Tie Down Bar" there is a variety of colors. |
| The Following User Says Thank You to bmacfrs For This Useful Post: | smg1138 (04-19-2018) |
#3232 | |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Enquiring minds want to know. Are you just dragging the brakes? Stuck caliper? There's no reason at all why someone should get any fade at autox speeds and time on course... I would look at something being wrong/broken before blaming any pad for fade, including OEM. I don't care if you had light Left Foot Brake for all of 60 seconds, it's not going to be enough to heat the brake fluid beyond it's boiling point (which causes fade). You may have glazed the pads, or gotten deposits on your rotors, but that's also not fade. That's just bad selections for the application. --kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
| The Following User Says Thank You to Imp For This Useful Post: | strat61caster (04-19-2018) |
#3233 | |
#3234 | |
I've experience brake fade with the OEM pads on a special AutoX event where we do 3 laps without stopping (fading occure at the beginning of lap 3). |
| The Following User Says Thank You to nico_rsx For This Useful Post: | strat61caster (04-19-2018) |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
