| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
5mm spacer on stock studs in the rear?
Howdy,
I picked up an H&R Trak+ 5mm spacer for the rear to get flusher fitment with my new wheels. It came with replacement studs which are slightly longer than stock, but I'm trying to avoid having to remove the rear hub (and deal with the axle nut) in order to swap the studs. Is a 5mm hubcentric slip spacer on the rear safe for track use with the stock studs? If not, I guess it's axle nut PITA time. Alternatively, it looks like the replacement studs that come with the H&R spacer are 50mm in length, the stock rear studs are 43mm in length (according to another thread here). I'm guessing I may be able to install without removing the hub, in which case it won't be the end of the world to swap them. I see some folks saying 3mm is max for stock studs some folks saying 5mm... Last edited by Tristor; 04-18-2018 at 03:52 PM. |
#2 |
Drives: Subaru BRZ
No, you will have not enough thread engagement left.
I installed extended studs a few weeks ago, was not that hard. |
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | JazzleSAURUS (04-18-2018), Tristor (04-18-2018) |
#3 |
#5 |
Just put 5MM spacers on the rear and did not remove the hubs. There is one spot in between the brake assembly where the new stud will just fit in, Barely.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | JazzleSAURUS (04-18-2018), Tristor (04-18-2018) |
#6 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
If you dont have issues with brake clearance or rubbing without the spacers on whatever offset wheels you have, why add another point of failure for track? I'd suggest to run without them. Plus its just annoying swapping on and off the spacers. I need them for my fronts to clear the wrx calipers on my daily driving set of wheels. For track I don't use them since my other set of wheels clear the brakes and there are enough reliability items I'm worried about. If you do use them, don't forget anti-seize.
| The Following 3 Users Say Thank You to hyper4mance For This Useful Post: |
#7 | |
Given what's been put in the thread above, I'm going to put in the extended studs and hopefully won't need to remove the hub to do so. I'll wait awhile to do it though since I've got other projects in the interim. |
| (Near) Catastrophic failure of H&R Spacer Studs. Causes? | rmr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 04-10-2017 03:57 PM |
| MAX Spacer thickness for stock studs? | FRSpdDmn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-09-2016 01:02 PM |
| How much spacer is safe on stock rear studs? | wparsons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-27-2014 01:49 AM |
| <FS> 4x H&R 15mm spacer and 15x extended studs (H&R and ARP) $140 shipped | mav1178 | Wheels and Tires | 0 | 08-22-2014 01:10 AM |
| 3mm spacer...need longer studs? | Fizz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-16-2014 02:50 AM |
