Old 03-16-2016, 12:31 PM   #1
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Whiteline Com 'C' Strut Mounts
I remember a while back people having problems with these clunking and popping. Does anyone know if Whiteline ever fixed that issue? I think it was related to the open bearings they were using.
smg1138 is offline   Reply With Quote
Old 03-16-2016, 10:52 PM   #2
df.dima
Drives: FR-S and Mazda 3 Sky
As far as I remember reading in other threads, they gave up and pulled the plug on those...
df.dima is offline   Reply With Quote
Old 03-17-2016, 05:41 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
I noticed that FT86speedfactory still has them on their site. Maybe you should contact them to see if they have any in stock.
Old 03-17-2016, 05:43 PM   #4
Calum
That Guy
IIRC someone posted that they changed the bearing. I think they ended up using the same bearing as OEM, but with a metal seal.
Old 03-18-2016, 01:56 AM   #5
cnk
Drives: '13 DGM BRZ Limited
They changed the bearing, but it didn't fix the issue. They actually sent me a new set with a couple machined washers that they said they were testing. I didn't want to go through the hassle of swapping them to only have issues again so I went with HVT mounts and haven't had any problems.
I still have the Comp-C's NIB if anyone is interested. Otherwise, was just going to throw them up on Nasioc for a WRX/Impreza owner instead.
The Following User Says Thank You to cnk For This Useful Post:
smg1138 (03-18-2016)
Old 03-18-2016, 08:30 PM   #6
Calum
That Guy
Like this?
Old 03-18-2016, 09:06 PM   #7
cnk
Originally Posted by Calum View Post
Like this?
Nope. That's the Subaru conical washer. I was running those and still had bearing problems. The ones they sent me look like this:
Calum (03-19-2016)
Old 03-18-2016, 10:37 PM   #8
makinen
makinen's Avatar
Drives: Toyota 86
I think its bearing axis should be inclined somewhat.
I've tried conical washers but bearings failed in the same way.
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
Calum (03-19-2016)
Old 03-19-2016, 01:10 AM   #9
wparsons
wparsons's Avatar
They still make them, but don't list them for the FRS/BRZ. They don't have issues on the impreza chassis, but something about the strut angle on these cars doesn't play nice with the bearing.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
Calum (03-19-2016), churchx (04-18-2018), Hyper4mance2k (03-19-2016), smg1138 (03-19-2016)
Old 04-17-2018, 03:25 PM   #10
norcalpb
norcalpb's Avatar
Bringing this back from the grave, has anyone ever had a set that didn’t make noise long term??
norcalpb is online now   Reply With Quote
Old 04-17-2018, 04:17 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
I managed to get wished camber & keep rubber top mounts via other means. -3 at stock height with camberbolts in both holes + powerflex bushing PFF69-801G. Pitty about no non failing bearings revision of compatible Com-Cs for twins, but i got what i wished at end.
Old 04-17-2018, 09:21 PM   #12
norcalpb
norcalpb's Avatar
What a shame. I’m considering group N rubber top hats but they do not have nearly the same benefits as a silent Com C would have.
Old 04-17-2018, 10:17 PM   #13
Racecomp Engineering
One of the products we'd love to make is a long lasting fixed camber plate with some rubber for reasonable NVH. Got a couple other things in the pipeline in the meantime, but hopefully we can make something like that in the future.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
churchx (04-18-2018), norcalpb (04-18-2018), wparsons (04-18-2018)
Old 04-17-2018, 11:44 PM   #14
whataboutbob
AutoX-10/10ths every run
I'd suggest just buying the RACESENG CASCAMs and be done with it. I have been through the COMCs previously and they never lasted.
http://www.raceseng.com/cascam-caste...ubaru-brz-2013
Build thread:Here
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 06:15 AM
