Old 04-17-2018, 11:53 AM   #99
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Originally Posted by amaciose View Post
Did you get any pictures during the install? How/where does the V2 version attach?
I assume you're referring to the kit in this thread? If so, I ended up not buying it and bought these car parts mentioned instead. I think it solved more of the actual issue than the symptoms.
Originally Posted by Maverick986 View Post
Did you buy your parts from a dealer, or a third party OEM seller, like Subaruparts.com? I've been looking at replacing the brackets too.
Sent from my SM-G925V using Tapatalk
I called my local dealership and ordered them. It was around $25 for each headlight bracket plus $5.50 for the fender bracket. Free shipping cause delivered at dealership.
carsebuco is offline   Reply With Quote
Old 04-17-2018, 12:00 PM   #100
Maverick986
Drives: 2014 Subaru BRZ
I will have to look into ordering from my dealer. Thanks!
Maverick986 is offline   Reply With Quote
Old 04-17-2018, 12:20 PM   #101
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Ah, I missed the first sentence of your post. Thanks
amaciose is offline   Reply With Quote
Old 04-26-2018, 02:02 PM   #102
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Anyone figure out how to install this new Kansai kit? I tried replacing the headlight and fender brackets, and it helped for a bit, but soon after started sagging again. What a shit design...
flashburn is offline   Reply With Quote
Old 04-26-2018, 10:10 PM   #103
cfordart
cfordart's Avatar
Drives: 2014 FR-S
I never could get rid of the sag until I went the "threaded rod" and new bumper route...see this post. Worked like a charm and is "brand new" again.
cfordart is offline   Reply With Quote
Old 04-28-2018, 01:04 PM   #104
flashburn
Geez, what a pain. Well I'll probably be selling the car in a few months anyway, so I guess I'll just live with the sag.
Old 05-02-2018, 02:17 AM   #105
thinkV
Drives: BRZ Turbo
Do you have any pictures from the front on the sag?
thinkV is offline   Reply With Quote
Old 07-09-2018, 11:51 AM   #106
xjohnx
Grip>Slip
xjohnx's Avatar
Exclamation
Sooo, I had JapanParts reach out to HKS Kansai service and got installation instructions for the V2 kit.
You're welcome.
Old 07-09-2018, 12:00 PM   #107
FT86Z
Drift noob
FT86Z's Avatar
Drives: 2015 BRZ Sport-Tech CWP 6MT
You're welcome.
You're the man
Sent from my SM-G965W using Tapatalk
FT86Z
藤原とうふ店
FT86Z is offline   Reply With Quote
Old 08-07-2018, 02:18 PM   #108
iStanley
They call me Stan
iStanley's Avatar
Drives: Firestorm FR-S
Update: purchased the side marker bumper bracket for driver's side + headlight bracket for both sides and this is the result:
Note on first pic the gap on fender and headlight
Then look at the same places:
So the little metal thing is a great idea for an easy fix, but after doing this I realized that is not the main issue. The brackets were bad to begin with, so they've made new ones. And while it's not 100% fixed (more like 99), this is more of a permanent fix than the original tool in this thread.
So the only thing you've done was change the headlight and side marker bracket? How is it holding up? I've had the saggy bumper titty for 2+ years and it's finally reached a point where I finally considered doing something about it. If yours is still good, even after a couple of removals, I think I may consider your method over everything.
iStanley is offline   Reply With Quote
Old 08-07-2018, 03:16 PM   #109
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
If your bumper clips are intact, they are great. If they are broken, this fix helps, but does not solve the issue.
I had to keep taking bumper on and off a few other times and eventually I got lazy and broke the bumper clips, and now it doesn't hold as well anymore.
Old 08-07-2018, 03:33 PM   #110
iStanley
They call me Stan
iStanley's Avatar
Damn. Yeah, my bumper clips are broken so I guess it's probably better to do it that method, maybe combine it with your method if I want a better hold.
Old 08-07-2018, 03:46 PM   #111
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
...I think the old one is better after looking at the V2 instruction....... Jesus >__>
Old 08-08-2018, 11:49 AM   #112
iStanley
They call me Stan
iStanley's Avatar
LOL same, I would like to think i can do it but it's a good amount of work. Old one is just glue and go. New one is like make 2 surgical incisions here and screw here etc etc.
bumper sag repair, anyone tried this yet? nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 23 07-28-2016 10:14 PM
Bumper repair keneyy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-19-2015 05:30 PM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 04:52 PM
Front Bumper repair grgonium Scion FR-S / Toyota 86 GT86 General Forum 7 01-15-2013 06:25 PM
Bumper Repair Thatruth2001 Northwest 1 09-12-2012 01:15 AM
