Old 02-28-2018, 05:46 PM   #85
Tristor
Tristor's Avatar
Originally Posted by Elliotw View Post
Just bought this. Going to give it a try with the MY2017 bumpers.
Can you take pictures and write instructions in this thread? I'm interested in all the front bumper issues folks have had. I haven't yet had any issues, but I think it's just a matter of time and want to make sure I know what I need to do. Thanks
Tristor is offline   Reply With Quote
Old 02-28-2018, 05:55 PM   #86
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
I got the QL-25-SP to fix the gaps. These are a great solution.
I LIKE TIRES!
Old 03-04-2018, 07:04 PM   #87
Maverick986
Drives: 2014 Subaru BRZ
I just got the Kansai new version that has just one "big" bolt and nut, with a hole drilled through the plates. Anyone install this version yet? The bolt seems way too big to fit without scraping paint off the body of my car.
I'm planning on cutting the clip hole in them and drilling ends for smaller bolts that will fit nicer. Unless there's a trick I'm missing?
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
Old 03-04-2018, 07:15 PM   #88
Ashikabi
Ashikabi's Avatar
I don't see how those are supposed to work
Old 03-04-2018, 08:31 PM   #89
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
how do you get to the underneath of the front section of the bumper? total removal of all undertrays?
Surok is offline   Reply With Quote
Old 04-03-2018, 01:00 PM   #90
amaciose
amaciose's Avatar
Drives: 2013 BRZ Limited
Did you ever figure out how this is installed? I was just about to buy this from JapanParts but noticed that the original version is no longer available.
amaciose is offline   Reply With Quote
Old 04-03-2018, 01:30 PM   #91
Maverick986
I ended up cutting slots in the second thinnest pieces and tried gluing. They ended up being too thick, and not sticking. Going to try again with the thinnest ones, and since I have a couple sets trying to sandwich the clip to see if that helps.
Old 04-03-2018, 04:37 PM   #92
amaciose
amaciose's Avatar
Looking at your picture, I can't wrap my head around how this new design is any better than the previous. Was really looking forward to buying a set shown in the OP.
Old 04-08-2018, 02:27 PM   #93
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
The one from OP's pic makes the most sense. Anyone knows a similar fix to it? The new ones just seem like way too much trouble.
carsebuco is offline   Reply With Quote
Old 04-08-2018, 02:32 PM   #94
Ashikabi
Ashikabi's Avatar
We must be doing something wrong. Surely HKS or whoever is making these now tested the design before they started selling them
Old 04-16-2018, 11:56 PM   #95
thinkV
Drives: BRZ Turbo
Also keen to know how the above works before jumping in on a kit :O
thinkV is offline   Reply With Quote
Old 04-17-2018, 01:59 AM   #96
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Update: purchased the side marker bumper bracket for driver's side + headlight bracket for both sides and this is the result:
Note on first pic the gap on fender and headlight
Then look at the same places:
So the little metal thing is a great idea for an easy fix, but after doing this I realized that is not the main issue. The brackets were bad to begin with, so they've made new ones. And while it's not 100% fixed (more like 99), this is more of a permanent fix than the original tool in this thread.
Old 04-17-2018, 02:15 AM   #97
amaciose
amaciose's Avatar
Did you get any pictures during the install? How/where does the V2 version attach?
Old 04-17-2018, 02:19 AM   #98
Maverick986
Did you buy your parts from a dealer, or a third party OEM seller, like Subaruparts.com? I've been looking at replacing the brackets too.
bumper sag repair, anyone tried this yet? nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 23 07-28-2016 10:14 PM
Bumper repair keneyy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-19-2015 05:30 PM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 04:52 PM
Front Bumper repair grgonium Scion FR-S / Toyota 86 GT86 General Forum 7 01-15-2013 06:25 PM
Bumper Repair Thatruth2001 Northwest 1 09-12-2012 01:15 AM
