Old 08-02-2017, 04:39 PM   #71
Ashikabi
Ashikabi's Avatar
Originally Posted by Raz View Post
Looks like the part is no longer listed on Japanparts. Anyone know another place that sells these?
I can't find any. Email japanparts and see what they say.
Old 08-02-2017, 09:25 PM   #72
Colombo
Drives: '13 BRZ
^^^^ weird. I just ordered these a few weeks ago and got them.
Colombo is offline   Reply With Quote
Old 08-06-2017, 11:37 PM   #73
Raz
Drives: DGM BRZ Limited
Did just that. They said the manufacturer stopped making them, but they think they'll start up again.
Raz is offline   Reply With Quote
Old 08-28-2017, 10:57 AM   #74
cvondra
Drives: 2014 FRS SR1
Anyone know where to source these anymore?
cvondra is offline   Reply With Quote
Old 09-05-2017, 10:30 PM   #75
cvondra
These are back in stock at JapanParts.com!
Old 10-13-2017, 11:17 AM   #76
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Sorry for the noob question, but will this fit the FRS bumper?
https://www.japanparts.com/parts/detail/49087
iLuveKetchup is offline   Reply With Quote
Old 10-13-2017, 11:50 AM   #77
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
It should. Thats the same one I ordered
Sent from my Pixel XL using Tapatalk
adrixe is offline   Reply With Quote
Old 10-13-2017, 11:53 AM   #78
Ashikabi
Ashikabi's Avatar
Yes it does. Make sure to modify the headlight surround to account for the screws though. That's no different from the BRZ but important none the less
Old 10-14-2017, 10:24 PM   #79
Gunman
Drives: 2019 Mazda Miata RF
Pix of what you modified?
Old 10-14-2017, 10:48 PM   #80
Ashikabi
Ashikabi's Avatar
Don't have any, sorry. There is a plastic bracket/mount that surrounds the headlight. This is what the bumper hooks onto. That will need modified slightly for clearance. You'll see when you try to mock up the bumper. If you don't use the included screws, you won't need to do this. If you don't use the screws, there will be a chance that these bumper reinforcement tabs will pop off. It's a small chance but it could happen
Old 10-17-2017, 07:37 PM   #81
norcalpb
norcalpb's Avatar
Just wanted to clarify on this and add my own experience.
The modifications being mentioned involve filing down a notch so that the forward most screws have room for the nuts. There’s a super tight gap between the fender and headlight bracket that just won’t accept the thicker, modified bumper tap.
And I didn’t see this mentioned but when you install the bumper there’s 2 things you have to keep in mind.
1) When you push the bumper under the front of the headlights, you want all four tabs BELOW the plastic flap. The inner most tabs can easily slip over the plastic flap and cause stress on the ends of the bumper.
2) When you push the bumper under the fender to finish up, use one hand to pull the bumper up and over the clip on the headlight bracket (basically squish the bumper into to the fender simulating zero gap). Use your other hand to push on the bumper to apply pressure, and carefully pull the bumper down and over the headlight bracket (while applying pressure still).
I didn’t hear a gratifying click or anything but damn I’ve had this gap for years and it’s finally gone.
Old 02-27-2018, 06:32 PM   #82
iLuveKetchup
Drives: EFF JAY
For those that have installed the new version, did you use the screw/nut AND also glue?
Old 02-28-2018, 02:21 AM   #83
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
So I basically fabricated my own version of this and it was a fail whatever I did. QL-25-SB "Mini" http://www.ft86club.com/forums/showthread.php?t=106110
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 02-28-2018, 04:00 PM   #84
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Just bought this. Going to give it a try with the MY2017 bumpers.
Elliotw is offline   Reply With Quote
bumper sag repair, anyone tried this yet? nickmerronesucks Cosmetic Modification (Interior/Exterior/Lighting) 23 07-28-2016 10:14 PM
Bumper repair keneyy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-19-2015 05:30 PM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 04:52 PM
Front Bumper repair grgonium Scion FR-S / Toyota 86 GT86 General Forum 7 01-15-2013 06:25 PM
Bumper Repair Thatruth2001 Northwest 1 09-12-2012 01:15 AM
