Old 03-23-2018, 10:59 AM   #3571
Racecomp Engineering
Originally Posted by bdtbdtbdt View Post
Thanks RCE! I installed a set of Tarmac 2's this winter. WOW! I came from stock dampers. I went from 35th pax last year to 9th pax ,same autox club.
THANK YOU ... LOVE THEM. Thanks to the forum for all the install help. They feel great!
Yeeeeahh! Thanks! We're glad you like them!
- Andrew
Old 03-23-2018, 03:51 PM   #3572
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
A little bit more rear camber would be good for grip out of corners, as would reducing rear damping (as long as the spring is still properly damped).
- Andrew
Thanks. The only reason for the -1.0 camber in the rear was to get the most amount of traction when accelerating on straights.
malubawla is offline   Reply With Quote
The Following User Says Thank You to malubawla For This Useful Post:
Racecomp Engineering (03-23-2018)
Old 03-24-2018, 06:57 AM   #3573
churchx
churchx's Avatar
Drives: 2014 GT86
To increase grip in straight line floored acceleration, i'd try to get as even as possible rear camber between sides, and add slight toe-in. With stock alignment, which was all around imprecise, i had to be very careful with throttle in winter even in straights. Now even if rear wheels slip during acceleration, rear won't dance around requiring lot of corrections.
Old 03-24-2018, 10:14 AM   #3574
DeaconRoc
Drives: GT86
...as would reducing rear damping (as long as the spring is still properly damped).
- Andrew
Could you explain this a little more please? How do you tell the spring is still properly damped? Thank you!
Sent from my ONEPLUS A3003 using Tapatalk
DeaconRoc is offline   Reply With Quote
Old 04-01-2018, 04:55 PM   #3575
Soonsoon
Drives: Working on it
T2s would work well and can be adjusted to ride well on the street (if done correctly!). But they may be a fair bit of overkill for you. Our upcoming GTWORX Bilstein coilovers may fit the bill nicely for you...simple, high quality inverted monotube with a double digressive piston. No damper adjustment, but great valving that just works.
You might need camber plates to get that fitment right, and I would also recommend rear LCAs. I'm starting to recommend rear toe arms more often because I do not like the OEM piece as it's inconsistent. You do not "need" them though. Skip the swaybars to start. There's a couple bushings that I would recommend. If you're interested I can put together a package for you.
- Andrew
Is there any news on release date, spring rates, comparative ride quality, damping, top hat compatibility, pricing... etc?
Thanks!
Soonsoon is offline   Reply With Quote
Old 04-16-2018, 02:17 PM   #3576
n0thing
Drives: Subaru BRZ
Will be replacing j hook rings soon for my front sprint kit. any particular instruction to follow? torque in star pattern? torque spec? retorque after bedding brakes?
n0thing is offline   Reply With Quote
Old 04-16-2018, 02:41 PM   #3577
Check with essex for support...I'd trust their instructions!
https://www.essexparts.com/support/p...hnical-support
- Andrew
Old 04-16-2018, 02:41 PM   #3578
Thanks!
Full details soon. Still hoping for spring time release. I hate the delay but not much we can do.
- Andrew
Old 04-16-2018, 02:42 PM   #3579
From the driver's seat, if you feel excessive bouncing after a bump that means there's not enough rebound. A little bit of "overshoot" is okay, but if it keeps going and going that's a problem. Too much rebound would be sort of "undershooting" where it actually takes too long to reach equilibrium again.
Critically damped (100% critically damped) means no overshoot, but doesn't necessarily mean the best ride quality or handling.
- Andrew
DeaconRoc (04-16-2018)
Old 04-17-2018, 03:57 PM   #3580
norcalpb
norcalpb's Avatar
Hi guys,
I think my camber plates are in need of a rebuild.
Is it ok to install the stock front suspension and run that in tandem with RCE spring on a bilstein? I would get an alignment to compensate for the different toe, but just want to know if I can drive the car like this for 1-2 weeks.
Old 04-17-2018, 09:16 PM   #3581
Originally Posted by norcalpb View Post
Hi guys,
That would be fine, I'd just drive carefully. You could also just put some stock top mounts on your Bilsteins + RCE springs.
- Andrew
norcalpb (04-17-2018)
Old 04-18-2018, 11:39 PM   #3582
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Hi there,
I have a set of AST5100 and planning to use OEM Top Hats, do I need camber bolts to achieve -2 deg front camber? Or the coilovers itself has a slotted hole so I can reuse factory bolts to achieve the -2 deg.
Thanks!
I have been told to replace the factory BRZ bolts with OEM WRX STI bolts but I am not sure if that's necessary or if it fits.
https://parts.subaruonlineparts.com/...bC1oNC1nYXM%3D
https://forums.nasioc.com/forums/sho...d.php?t=834115
This thread also says do not use OEM 14mm bolt on the slotted hole. So what bolt shall I use? I am confused, Thanks!
http://www.ft86club.com/forums/showthread.php?t=54834
OEM 14mm Bolts
https://parts.subaruonlineparts.com/...g0LWdhcw%3D%3D
botbs is offline   Reply With Quote
Old 04-19-2018, 01:41 PM   #3583
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by botbs View Post
Hi there,
Thanks!
OEM 14mm Bolts
Not sure on the first questions but here's my input for the quoted bit:
any camber bolt can slip. That's why it important to recheck them every so ofter (like before/after a track day, when you rotate tires, etc)
I have ran the 14mm OEM bolt with my slotted AST 4150 for 2 track days and almost 10k street miles without issue (this includes canyon runs as well). Take it for what it's worth, but
botbs (04-21-2018)
Old 04-21-2018, 02:09 AM   #3584
BaatLuk
Drives: Evo X
I posted this question in the other thread regarding the USDM STI springs but couldn't get a clear answer, I am re-posting it here. I apologize in advance for being redundant.
Why are the USDM STI springs (B2010CA000) "not applicable to Limited with Performance Package"?
We know the lowering springs such as the RCE yellows have not changed over the years and they work well with the PP Sachs dampers. Following that logic, why wouldn't the USDM STI springs work well with or be "applicable to" the Sachs dampers?
BaatLuk is offline   Reply With Quote
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
