Old 04-14-2018, 06:21 AM   #1
vagthomas
Drives: Toyota GT86
2017 GR edition cluster mod
Does anybody know whether the 2017 GR edition cluster mod is applicable to 2012-2016 model??
vagthomas is offline   Reply With Quote
Old 04-14-2018, 06:43 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Issue is the extra display on the right side.
Old 04-14-2018, 11:41 AM   #3
gpvecchi
gpvecchi's Avatar
So, you have to sell it to me... :-)
Old 04-14-2018, 02:36 PM   #4
vagthomas
Drives: Toyota GT86
This has already been installed in a 2013 model in Hong Kong and is working just fine!
I am waiting for some further info from the guy that installed it, if any further mods are needed so that to get full display on the right screen - same as 2017 model!
However nothing received yet. Just waiting
In the meantime, I have addressed my request to Gazoo Racing, as well.
Lets see what they will also tell me..
Old 04-14-2018, 03:42 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
My biggest question is WHERE to I purchase this at?!
MS, CSCS, TSAC-F, CPT
Old 04-14-2018, 06:38 PM   #6
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
I’m also looking at swapping the cluster on my 2017 to the similar one found in the 2018 models. It’s also found on the 2017 860 edition. Have parts numbers for the steering wheel additional controls and the cluster itself. I understand It will need to be programmed. But waiting on confirmation on wether or no it will work on key models as supposed to just push-start models.
el-guapin is offline   Reply With Quote
Old 04-14-2018, 09:21 PM   #7
spike021
spike021's Avatar
Any idea if the faceplate (basically the analog gauges and white piece) can be swapped to a 2017 and reuse the original screen/system?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 04-15-2018, 02:44 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If you mean if the cluster is reading just from regular obd it is not the case. Not all the sensors are from ECU. There are some sensors that they were added just for the gauge, but I am not aware of the details.
Old 04-15-2018, 03:58 AM   #9
gpvecchi
gpvecchi's Avatar
Amazon Japan
Old 04-15-2018, 09:52 AM   #10
weederr33
weederr33's Avatar
Originally Posted by gpvecchi View Post
Amazon Japan
Part number? Link?
Old 04-15-2018, 10:01 AM   #11
weederr33
weederr33's Avatar
https://www.amazon.co.jp/gp/aw/d/B07...kTL&ref=plSrch
Old 04-19-2018, 08:13 PM   #12
Sc629
Drives: 2017 86 Asphalt
Anybody know what goes into a clutter swap on our cars? Guessing it would require programing at the dealership rather than plug and play?
Sc629 is offline   Reply With Quote
Old 04-20-2018, 08:16 AM   #13
weederr33
weederr33's Avatar
I would think it would be as simple as plug and play, but I have a hunch it wouldn't be. I would also like to know about this.
Old 04-25-2018, 04:05 AM   #14
Sc629
Just giving yall an update. I did some looking through the frs and 86 service manual and it *looks* like when installing a new, unprogrammed cluster, the only required after hooking it up is getting the key programmed. From a different thread, you can even drive with the cluster unplugged but I have no clue if plugging in an unprogrammed one then driving to get it programmed would work or not. So yes, plug and play for the most part it seems but don't take my work for it
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 07:32 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 05:36 PM
Any Mid-Year 2017 86 Special Edition? Borchert97 Scion FR-S / Toyota 86 GT86 General Forum 42 03-14-2017 07:43 AM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 03:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-14-2016 11:32 PM
