Old 02-05-2018, 08:45 AM   #99
djezlee
Drives: 2017 BRZ Limited
Originally Posted by Misfire View Post
It's the 2017 Canadian one piece dash trim, and mine specifically is from the Inazuma edition. This is the thread about them.
Awesome... thanks!
djezlee is offline   Reply With Quote
Old 03-03-2018, 04:26 PM   #100
SkyKing
Drives: 16 BRZ Limited CWP 82 Alfa Romeo
Originally Posted by Flash02 View Post
Here are some more shots, this set up can be either Double Din or Single Din. As a single DIN a small compartment is attached to the bezel.
[IMG]https://uploads.tapatalk-cdn.com/20171127/ade92522b6d3d3122e89fa1abf206***.jpg[/IMG]
This looks like the same kit on the Crutchfield website. $32
SkyKing is offline   Reply With Quote
The Following User Says Thank You to SkyKing For This Useful Post:
tehShirt (03-03-2018)
Old 03-03-2018, 06:34 PM   #101
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
They must have just added that. Thanks!
tehShirt is offline   Reply With Quote
Old 03-04-2018, 02:44 AM   #102
djezlee
I agree... wasnt always there! Looks like the Crutchfield folks finally updated their system.
Old 04-13-2018, 04:10 PM   #103
Tonezorz
Drives: '17 BRZ Series.Yellow
Any updates from anyone running the Sony XAV-AX100 in the 17MY? I have the one piece dash trim and looking to upgrade to this HU.
Tonezorz is offline   Reply With Quote
Old 04-13-2018, 04:21 PM   #104
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
What kind of update do you need? It's a standard double din unit that will work just fine in any year model of the twins, for a 17 you'll use the Scosche SU2032B dash kit.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Tonezorz (04-13-2018)
Old 04-13-2018, 11:23 PM   #105
Tonezorz
Do I still use that kit with the single piece dash from Canada? And should I just use any wiring harnesses that crutchfield says I need?
Old 04-14-2018, 12:23 AM   #106
NCtoBRZ
No, the Scosche kit is intended for the trapezoidal opening of the US dash, there is another kit that I’ve seen mentioned in other threads that just fills in the gap on the sides of the head unit if you’re using the Canadian dash with a rectangular opening. The particular harness that you’ll need just depends on what type of installation that you are doing, what Crutchfield recommends should be fine... but more complicated installs such as using a Maestro RR (which I’m not sure if it is compatible with the Sony head unit) require either hardwiring or using their T01 harness plus adding some pins (look up my recent thread regarding installing the Meastro RR with a Pioneer head unit).
One piece dash and other 2017 parts Summerwolf Cosmetic Modification (Interior/Exterior/Lighting) 340 05-05-2020 08:47 PM
Stock Stereo/Headunit Frequency Crossover? Replacement Door Woofers PandaSPUR Electronics | Audio | NAV | Infotainment 3 01-12-2015 02:18 PM
10-Series Electroluminescent Dash Panel Replacement Raiin Cosmetic Modification (Interior/Exterior/Lighting) 0 11-18-2013 01:14 PM
Where to purchase replacement dash panels? jimmyze013 Cosmetic Modification (Interior/Exterior/Lighting) 4 07-18-2012 11:50 PM
FR-S headunit replacement drei CANADA 7 07-11-2012 04:08 PM
