Old 04-12-2018, 08:04 PM   #1
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Aftermarket NA intake manifold progress?
I remember about a year ago seeing a lot of development on IMs for the FA20. Not seeing a whole lot of that anymore.
Any word on anything that's been happening?
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 04-12-2018, 08:52 PM   #2
monkeybike
Drives: 86
I saw this one the other day, no details though.
monkeybike is offline   Reply With Quote
Old 04-12-2018, 09:07 PM   #3
mrg666
pessimistic skeptic
mrg666's Avatar
Nobody could produce/design that is worth buying. There is no power gain from replacing intake and/or intake manifold. Short of FI, just do a header/tune and try E85 if you want anything beyond that.
The Following User Says Thank You to mrg666 For This Useful Post:
Tcoat (04-13-2018)
Old 04-12-2018, 10:43 PM   #4
FunnyGopher
Drives: 2015 BRZ Limited
I believe that to be an ITB manifold of some kind. You can tell by the lack of a throttle body where the end of the induction tube is.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following User Says Thank You to FunnyGopher For This Useful Post:
Williampreza (04-12-2018)
Old 04-12-2018, 10:48 PM   #5
FunnyGopher
I too was/have been interested in the production of an NA manifold. Lots of people tried, and a lot of them saw very little gain. It was very sad.
However, the one manifold that seems to do something is the JUN Auto GT Surge Tank. That price tag though. :p There was a guy on the forums with full bolt-ons NA, and then went ahead and threw this thing on and made another 12HP or something after a tune to account for the changes in airflow. Tempting, but that cost is unjustifiable unless you're just itching like mad. There's a post on here about it somewhere.
Old 04-13-2018, 12:08 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I never saw a dyno on the FBM, larger, intake, manifold for a FI or NA car. The biggest gains seem to be from a larger TB or ITB, but even then things might be minimal. Crawford power blocks might be the most proven intake add on...?
Old 04-13-2018, 12:32 AM   #7
Lantanafrs2
Drives: 2013 frs red
My guess is that the itb kits will give a nice bang under the curve but nothing up top due to runner length. Just a feeling based on one f.i. dyno and greddys claims.
Lantanafrs2 is offline   Reply With Quote
Old 04-13-2018, 09:28 AM   #8
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Greddy sells an ITB setup that nobody has been willing to drop 3k on. other than that i've seen some supposed gains over 6500rpm with the 17+ red intake manifold that you can get for sub 400. I know the 17 manifold is good for 15ish in the 350whp range when boosted
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-13-2018, 11:15 AM   #9
fika84
fika84's Avatar
This is the SARD ITB kit. Both this and the Greddy kit are priced at $3k. There's another thread on here talking about ITB options.
fika84 is offline   Reply With Quote
Old 04-13-2018, 11:51 AM   #10
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The cost is crazy, plus it makes it's power by pushing the powerband higher than the OEM motor can spin..
"The inertial supercharge peaked in the stock in about 7200rpm, but we calculated a port cross section and the port length and designed it in about 8000rpm to become greatest."
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Spuds (04-13-2018)
Old 04-13-2018, 02:41 PM   #11
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Same thing the Crawford blocks do, but in the opposite direction. It's all about runner length and plenum size.
Old 04-13-2018, 03:07 PM   #12
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There are more options, but they are expensive.
Old 04-13-2018, 04:48 PM   #13
EXCellR8
FR-S Driver (MT)
EXCellR8's Avatar
Drives: 2013 Whiteout FR-S
I actually like the Crawford blocks, installed recently. Plus it's $300 vs $3,000 so that's a no brainer. The BPB + Openflash tune completely killed my torque dip and the car pulls extremely smooth. No idea if I'm getting any actual HP gains but it just feels nicer overall so I'm very happy.
Has anyone bolted on a 2016-2018 aluminum manifold to their older motor?
EXCellR8 is offline   Reply With Quote
Old 04-13-2018, 09:12 PM   #14
Spuds
The Dictater
Spuds's Avatar
If I came across as saying they are bad, that's not what I meant. I was just pointing out that the blocks bring maximum power lower in the rpm range by increasing the length of the intake runners, where the intake mentioned does the opposite by decreasing the length of the intake runners.
OEM exhaust manifold gaskets ok for aftermarket header install? giorgi0424 Engine, Exhaust, Transmission 3 02-22-2017 11:43 AM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 11:40 AM
FBM Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 1 03-11-2016 08:36 PM
Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 0 03-03-2016 09:29 PM
Oil on/around Intake Manifold Wepeel Issues | Warranty | Recalls / TSB 2 05-13-2014 12:40 AM
