Old 04-12-2018, 10:21 AM   #71
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Originally Posted by rvoll View Post
So if you wanted 265's in back, you should also have them in front? Really? Perhaps you should tell the Porsche, Corvette, Ferrari, and McLaren people, who obviously know nothing about sports cars, that they should have a square setup...
Having only just stumbled across this thread, this was the post that irked me the most. Do you think that is in any way a reasonable comparison? Like, at all?
FWIW, I run 245s all-around for autocross. If I were to put 215s back on the front as you seem to suggest I should, I would get butt-raped in the butt with a lot of rape.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
venturaII (04-12-2018), why? (04-13-2018)
Old 04-12-2018, 11:00 AM   #72
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Well, they're all cars.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-12-2018, 11:29 AM   #73
Jordanwolf
Rice King
Jordanwolf's Avatar
Obviously no one knows what they are talking about here. You kids all need to start running 265/70/15 in the front and 185/35/18 in the rear for maximum grip and and acceleration.
:b arf::bar f:
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
rvoll (04-13-2018)
Old 04-12-2018, 11:58 AM   #74
Deorio
Drives: 2013 Scion FRS
I personally prefer running a staggered setup with 255/R18s on the driver side and 205/R17s on my passenger side. Since all the off-ramps in my city are right hooking, I get the immediate responsiveness of the passenger side narrower tires throwing me into the bend with the meaty driver side tires keeping me from spinning out. 10/10 wood recommend.
Deorio is offline   Reply With Quote
The Following 4 Users Say Thank You to Deorio For This Useful Post:
Jordanwolf (04-12-2018), rvoll (04-13-2018), Stang70Fastback (04-12-2018), Tcoat (04-13-2018)
Old 04-12-2018, 12:06 PM   #75
venturaII
venturaII's Avatar
LOL at the recommendation in another thread to run staggered 215/245 setup...can't make this shit up.
Old 04-12-2018, 12:22 PM   #76
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
None of it was a reasonable comparison
......and no one like butt-rape so.........
Old 04-12-2018, 12:38 PM   #77
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
What tire temperatures do you have after an autocross event? I mean your tires don't have time to heat enough or am I wrong?
Old 04-12-2018, 12:56 PM   #78
Stang70Fastback
A.K.A. Starlord
They absolutely heat up. On warmer days, you need to bring a water sprayer to keep your tires cool. It only takes one 45-60 second autocross run to bring them up to a good temperature. Even with 5-10 minutes between runs, your second run will be significantly grippier, and your third run will be even grippier. If you get shoehorned into a re-run in between, though, you can sometimes get buttfucked by an overheated tire if you don't get the 5 minutes between runs you are supposed to get.
nikitopo (04-12-2018), strat61caster (04-13-2018)
Old 04-12-2018, 01:26 PM   #79
Soonsoon
Drives: Working on it
Between this and all the rape, I don't want to autocross wherever you autocross. The wrong kind of stakes for weekend motorsport.
Soonsoon is offline   Reply With Quote
The Following 4 Users Say Thank You to Soonsoon For This Useful Post:
Bergycheese348 (05-07-2024), Qadthane (04-12-2018), Tcoat (04-12-2018), why? (04-13-2018)
Old 04-12-2018, 02:04 PM   #80
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
This thread is nuts and the comparisons brought up are horrible.
I run 17x9 with 255/40 because I think it looks good, protects me from NYC potholes, and saves my wheels from the occasional curb rub from a hasty parallel parking job. Never been on the track.
We all have our own reasons, stop justifying to others or trying to convince others. Especially with such bad comparisons.
Old 04-12-2018, 02:37 PM   #81
venturaII
venturaII's Avatar
Errr...how does that size protect against potholes? It's virtually the same sidewall as the stock 215/45...
Old 04-12-2018, 02:50 PM   #82
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Originally Posted by new2subaru View Post
If 205's are good why not go down to 195?
if you're in a cold environment and cant get heat into your 205's sufficiently and the manufacturer says its safe on your wheel that would work. You'd drop weight and get into your operating temp range quicker.
There is no 100% right answer for all conditions. most people WAY over tire this car... I know mine is but dammit it looks cool lol
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following 2 Users Say Thank You to Roadcone For This Useful Post:
new2subaru (04-12-2018), why? (04-13-2018)
Old 04-12-2018, 02:52 PM   #83
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
for this particular wheel size, the 255/40 is a little more meat on the 9" wheel
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 04-12-2018, 03:35 PM   #84
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A comparison is always a comparison. Especially when the one car is considered to be much better than the other and the result is different. We tried to identify the reasons. There was reasoning in different directions and that is good in a discussion.
Your own reasons using large wheels/tires are not relevant with performance. Why do you need to get bothered with this discussion?
What am I missing with all the ultra-wide wheels & tires? Vdub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-14-2017 08:08 AM
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 12:14 AM
Tires that run wide or narrow switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 12-08-2013 03:55 PM
I have a 18x7.5+38 wheels..How wide can i go with tires Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2013 12:04 PM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 08:38 AM
