Old 04-11-2018, 02:04 PM   #15
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by fatoni View Post
Okay. Show me what the tread wear of the ad08b is please. I'm not convinced that it's the same tire as the a052 and it sounds like you aren't either.
Tread wear numbers doesn't say the complete truth of the tire compound. Such numbers are based on actual road use and they are also relevant with the tire's tread depth.
Here is the original communication by Yokohama. They say that the tire meets the official Gazoo regulations. It would be a madness Bridgestone to be allowed to use the RE71R tire and Yokohama to come with a tire that had a much softer compound.
http://www.y-yokohama.com/release/?id=2881
Do you have any idea about racing regulations or are we losing our time here? In the specific races they cannot use whatever tire compound.
Old 04-11-2018, 02:13 PM   #16
fatoni
Originally Posted by venturaII View Post
I agree that it's likely not the same, but manufacturer tw ratings are pointless when you've got 140tw and 180tw tires one year suddenly becoming 200tw the next year..
Yeah, it's probably not the way to make my point. My point was that it seems like the compound is faster. That along with that size being a half inch shorter means that tire width and wheel width are a couple of many variables and is foolish to think you know that it's those variables instead of, imo, much more important variables like compound and drive ratios.
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
venturaII (04-11-2018)
Old 04-11-2018, 02:59 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
No, the clue is that the wheel/tire selection on the TRD 14R60 car was wrong or guided entirely by the marketing department. How many customers would buy a 6.3 million yen car with narrow tires? Are you aware that this one was inspired by the Griffon TRD 86 car which made a lap time of 58"407 at the same track? All the other equipment of the 14R60 car like the final drive/gear ratios you mentioned, the compound and all the rest of the factory modifications which it looks you are unaware were very competitive. Issue is that the wheel/tire size was too much for the specific stock power levels and in general for a car on similar power levels.
Old 04-11-2018, 03:27 PM   #18
ZDan
ZDan's Avatar
Drives: '23 BRZ
There are WAY too many variables other than tire size to draw the conclusion: quicker because smaller tires...
Test the same car, same make/model/age/heat-cycles tire, same day, same driver, only difference being tire width, and then you have a valid comparison.
Road and Track did a test like this, but unfortunately didn't test tires of the same diameter (215/45-17 = 24.7", 235/40-18 = 25.4"), so different gearing and c.g. height. If only they'd tested a 245/40-17 vs. 215/45-17...
https://www.roadandtrack.com/car-cul...ransformation/
Car went 6 tenths faster lap time on the 215/45-17 StarSpecs vs. 235/40-18. However pulled slightly more g's and quicker slalom time on the 235s...
Old 04-11-2018, 03:44 PM   #19
fatoni
Anyone who spends 6 million yen on a twin isn't going to pass because the wheel size. That's a stupid buy for any reason other than exclusivity and fanboyism. Performance wasn't a factor in a single one of these purchases. I spent well over 3 million yen on a car with 5.5" rims. When I was talking about ratios, I was referring to your preferred tire size being a half inch shorter at a race on thr worlds smallest race track. You don't know what you're talking about. How can the tire compound be "very competitive"? In in the video I linked before it said that the ad08b won every single race in that series. What about that is competitive?
Old 04-11-2018, 03:52 PM   #20
Compound is the #1 factor, always.
Tire width can be track dependent (for a given car).
- Andrew
These ^
There is no such thing as perfect size, compound, tread, sidewall, weight and so on for tires that applies to all applications. The same tires, on the same car, on the same track can perform radically different depending on weather conditions the surface or even the layout so saying one is better than the other no matter what the application is not possible.
nikitopo (04-12-2018)
Old 04-11-2018, 03:58 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you wanted an example of this it would be the same brand tire, on the same car, with same setup except camber optimized for each tire width.
This comparison is like asking someone to watch me throw two different sized rocks, and then judging which one went faster.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Cole (04-12-2018), Mr.ac (04-11-2018)
Old 04-11-2018, 03:59 PM   #22
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Tcoat. Don't forget the other variable - driver. Different drivers with different styles can use tires in very different ways.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-11-2018, 05:12 PM   #23
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
treadwear numbers mean absolutely nothing. It's a HORRIBLE way to class tires.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
Old 04-11-2018, 05:51 PM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You mean 200TW RS4's aren't equal to 200TW RE71R's?
Or how the GT Radial SX2 magically went from 200TW to 260TW.
Old 04-11-2018, 05:55 PM   #25
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Actually, they're not specifically classed by tw rating.
Grand Touring Summer, 240-300tw:
https://www.tirerack.com/tires/tires...iEcoContact+EP
Max Performance Summer, 340tw:
https://www.tirerack.com/tires/tires...remeContact+DW
Which one handles better?
People just assume that a lower number means stickier rubber, but it's a WEAR rating, not a grip rating. Lots of factors affect both characteristics, and classification.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Old 04-11-2018, 05:57 PM   #26
venturaII
venturaII's Avatar
Or how RS3s went from 140 to 200 from one season to another?
The Following 2 Users Say Thank You to venturaII For This Useful Post:
JazzleSAURUS (04-12-2018), nikitopo (04-12-2018)
Old 04-11-2018, 06:05 PM   #27
OND
OND's Avatar
Drives: 2023 BRZ
I love it when people start threads to justify their purchase decisions.
OND is offline   Reply With Quote
Old 04-11-2018, 06:16 PM   #28
new2subaru
Weight Weenie
Drives: 15 FR-S
If 205's are good why not go down to 195?
What am I missing with all the ultra-wide wheels & tires? Vdub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 07-14-2017 08:08 AM
What are some good slippery narrow tires? PowderfaceTr. Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-07-2015 12:14 AM
Tires that run wide or narrow switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 12-08-2013 03:55 PM
I have a 18x7.5+38 wheels..How wide can i go with tires Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-23-2013 12:04 PM
235 mm tires, great fit but not too wide Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 02-07-2013 08:38 AM
