Old 04-07-2018, 08:08 PM   #1
NordicGT86
Drives: GT86
Question Oil recommendation for short driving distance in freezing conditions
Do you any oil 0W-20 with additive package orientated to short distance driving (16 km) in extreme cold weather conditions -20°C ? The oil must manage around 3000 km just the winter season.
Currently using Castrol Edge.
I appreciate any recommendation
NordicGT86 is offline   Reply With Quote
Old 04-07-2018, 08:47 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The issue with short drives is temperature. Need to see above 200F to boil the moisture out of it.
p1l0t (04-09-2018)
Old 04-07-2018, 08:55 PM   #3
NordicGT86
Drives: GT86
That's right. Is there any oil with additives for this application ? High humidity, gasoline in the oil due to idle operation this kind of severe condition.
Old 04-07-2018, 09:14 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
An occasional longer drive would be your best option, IMHO. Even if it's just once a week. A drive to get up to temp for a little bit to allow it to burn off excess moisture.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
Overdrive (04-12-2018), venturaII (04-07-2018)
Old 04-07-2018, 11:05 PM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The general rule of thumb is that your oil needs to be at full operating temp for ~20 min for all normal amounts of condensation/fuel/contaminants to be removed. Obviously that's a pretty loose number, but you get the idea. As mentioned, take your car for a nice ride on the weekends and you should be good to go. It will easily survive 3000km under those conditions.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-08-2018, 12:13 AM   #6
You're probably best off just to deal with it the old fashioned way ..... take a longer drive every now and then (as mentioned) and change the oil more often.
Even if I found an oil that claimed that it could absorb fuel/moisture/contaminates ..... I wouldn't believe it.
Summerwolf (04-08-2018)
Old 04-08-2018, 09:45 AM   #7
NordicGT86
Drives: GT86
Thanks for your answers!
It seems that the best option is to have the Sunday coffee at a service station 20 minutes away.
Cheers
The Following 2 Users Say Thank You to NordicGT86 For This Useful Post:
humfrz (04-08-2018), venturaII (04-08-2018)
Old 04-08-2018, 11:46 AM   #8
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I had the same concerns about my short drive to work so I installed the forester oil cooler hooked up through the throttle body that helped heat the oil quicker in the winter months and still controlled high temps at the track during the summer.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
Old 04-08-2018, 11:54 AM   #9
GrantedTaken
You're good
GrantedTaken is offline   Reply With Quote
Old 04-08-2018, 12:24 PM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I use a 5W30 oil in these temperatures without issues.
Old 04-08-2018, 01:40 PM   #11
NordicGT86
Drives: GT86
The question was in the direction of the additive package. Some oils are focus on provide better protection with hight load/temperatures or high millage. Given the number of cars working in these severe conditions, short commuting. Maybe there are oils for providing better protection in short distances, moisture, idle operation.
Old 04-08-2018, 02:48 PM   #12
reeves
Honestly, you're in a great situation.. You have an excuse to drive your car for longer than you need to, and you'll have to keep the revs up to get that oil cooking inside your engine.
Good luck on accomplishing those 2 things!
Old 04-08-2018, 04:05 PM   #13
NordicGT86
Drives: GT86
Even better. The trip is on frozen roads and friction tires ;-)
reeves (04-08-2018), venturaII (04-09-2018)
Old 04-08-2018, 04:17 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
In this case, there isn't one.
How bad is E85 in freezing winter? zmz0305 Software Tuning 35 05-12-2016 01:18 PM
Distance? Nonfacter1 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-13-2015 11:17 AM
Driving stick: A short(ish) guide boogle BRZ First-Gen (2012+) — General Topics 24 11-20-2014 01:31 AM
Any long-distance driving/time lapse video of BRZ/FRS/86? mav1178 BRZ Photos, Videos, Wallpapers, Gallery Forum 6 05-25-2013 01:33 AM
Windows freezing? L3P47 Scion FR-S / Toyota 86 GT86 General Forum 11 12-22-2012 01:49 PM
