Old 07-09-2012, 11:37 PM   #141
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by SprayedBigCube View Post
If you're anywhere between Pensacola and Panama City Beach, I'll help.
I wish, I'm in New Mexico, sorry I forgot I changed the location on my info LOL
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-09-2012, 11:59 PM   #142
SprayedBigCube
SprayedBigCube's Avatar
Drives: 2013 FRS 6M, 2010 Camaro 2SS 6M
New Mexico is nice, what little I've seen of it. Be thankful you don't live up north and be tied to scheduling your life around that thing called 'winter' LOL
FRS bone stock. Camaro SS LSA forged, stroked, ported, nitrous plate w/standalone, dyno tuned old stock cube numbers: NA-473/437, N20-585/626 at the wheels, 3.90 RPM diff, ACT twin-disk clutch, 18x10 F14's w/NT05R 305/45's, and other supporting mods.
SprayedBigCube is offline   Reply With Quote
The Following User Says Thank You to SprayedBigCube For This Useful Post:
jedibow (07-10-2012)
Old 07-10-2012, 08:47 AM   #143
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Agreed. I wonder how much wiggle room there is from the EPA friendly exhaust timing that could be recovered. Toyota must have really yanked on it alot to create a large lobe separation angle for little to negative overlap.
I assume if you're tuning in speed density, you've either got a real VE table or god forbid (as GM has recently done with Gen IV ECUs) an inferred (from parameters) VE table. How bad are the midrange VE numbers looking? Can you post a screen shot?
The Hydra gives you a number of options now for fuel tuning but I'm a purist and tune straight injector pulse width.
The exhaust cam must be fixed to open extremely late so if you use no exhaust cam timing you lose about 25 hp up top. You can get the exhaust cams to move fully/reliably at about 3000 rpm. You just can't get a perfect blend between the exhaust and intake cams to eliminate the dip.
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
SprayedBigCube (07-10-2012)
Old 07-10-2012, 09:01 AM   #144
Element Tuning
Originally Posted by jedibow View Post
How did extending the offset between the intake cam, and the exhaust cam effect the dip? Have you tried this?
For clarification I meant decrease cam overlap, sorry that was not clear...
That makes it worse which must be close to the oem strategy for emissions and fuel economy. Increasing overlap when tuning the Hydra EMS is what helps for me.
I think a larger intake plenum would help but what do I know I'm a turbo guy
Now keep in mind with the Hydra EMS we are not captive to the oem port and direct injection strategies but we have only scratched the surface. For now I've been focusing on building the cam timing strategies.
Old 07-10-2012, 09:21 AM   #145
serialk11r
Drives: '06 AM V8V Coupe
Are you running only the direct injectors for now?
Old 07-10-2012, 09:34 AM   #146
jedibow
I'm going to add you guys to the first page since you have ported the Hydra to this platform, please advise of anything unique, Harness, etc. I will include that the dv4s system is non functional.
Thanks,
G
Old 07-10-2012, 03:50 PM   #147
Element Tuning
Thanks,
G
I'm pretty sure we are only going to sell the Hydra when I have tuned a direct injection strategy we are happy with. Now I may bend the rules slightly for experienced tuners who are pushing forward developing turbo kits etc and really need something now...like me You can always get the flash updates as we have them since Hydra 2.7 units are user flashable now for upgrades.
It will be interesting once I get hold of all my options how we'll tackle this but I would like to go for some serious lean burn strategy to bump fuel economy way up and then adopt more of a cylinder cooling strategy for maximum power.
For now the Hydra is 100% plug and play stand-alone with CAN Bus so your dash, power steering, AC, etc is fully functional.
Old 07-10-2012, 04:11 PM   #148
jedibow
Thanks for the info, I've used hydra ECM in the past
Old 07-10-2012, 04:34 PM   #149
Illusive
Drives: 2005 Subaru STi
Very cool news indeed.
Illusive is offline   Reply With Quote
Old 07-10-2012, 05:36 PM   #150
serialk11r
Sounds like you are running port injectors only? :O
Somewhere in one of the Toyota papers they wrote that the direct injectors are used at relatively high duty cycle to prevent them from overheating, apparently they can't go over 150C. I hope you guys didn't leave them in and turn them off.
Old 07-10-2012, 06:00 PM   #151
Element Tuning
Thanks for your concern but don't you worry about me
A lot of what's posted about how this DI works isn't exactly the strategy Subaru is using on this engine as we've logged it plenty.
As I stated how we run the direct injection strategy is completely open and we'll run it so it benefits "us" the performance enthusiast the most.
Old 07-10-2012, 06:55 PM   #152
arghx7
Drives: car
You don't have the resources to do a direct injector durability study.
The Following 2 Users Say Thank You to arghx7 For This Useful Post:
jedibow (07-10-2012), rice_classic (07-10-2012)
Old 07-10-2012, 07:43 PM   #153
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Just a quick noob question, is a flash like EcuTek's compatible with 91oct fuel? Will we see such gains?
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 07-10-2012, 08:23 PM   #154
Element Tuning
A reflash is only as good as the person tuning it. With any tune, especially an off the shelf tune, you are digging into the safety/reliability margin placed there by the oem manufacturer. Its always best especially with a Subaru based ecu to custome tune the car.
We have built many blown up engines that only had an off the shelf reflash. Now its much harder to damage an NA engine vs. Turbo but it still happens.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
Bahraini86 (07-10-2012), jedibow (07-10-2012)
Great dealership in NE Ohio.. (still has multiple pre-order slots open) eikond BRZ First-Gen (2012+) — General Topics 15 03-02-2012 01:03 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-01-2012 11:01 PM
Open Deck Block nrclptcnsmniak Engine, Exhaust, Transmission 36 01-27-2012 01:00 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 10:21 PM
