Old 07-09-2012, 04:35 PM   #43
GremlinGSP
http://www.crutchfield.com/p_142SAT6...er-reviews-tab
These were all I ended up needing They lined up just right.
GremlinGSP is offline   Reply With Quote
Old 07-10-2012, 02:30 PM   #44
phenryiv1
Drives: 2011 WRX
Interesting. All Subaru users have hated those adapters, but maybe these cars lean closer to a Toyota pattern.
http://www.crutchfield.com/p_142SAT6...ts.html?tp=919
Those adapters that CF sends are useless in Subaru (non-BRZ) applications.
phenryiv1 is offline   Reply With Quote
Old 07-10-2012, 06:34 PM   #45
GremlinGSP
I measured them up the top 2 are 7 5/8" apart with the bottom one being 8 1/8" from the top 2. From the bottom of the speaker mounting plate the stock one is 1 1/16" high then some foam. Theres more room than that to work with though. Using those CF brackets I was able to mount some Infinity Kappa components on top with some space. I don't have a mm tape measure laying around or I'd check it that way. What I measured should be really close though.
Old 07-11-2012, 03:21 PM   #46
phenryiv1
Drives: 2011 WRX
Thank you for the measurements.
Old 07-12-2012, 01:49 PM   #47
phenryiv1
Drives: 2011 WRX
Reconciling the posts below, I got confused.
http://www.crutchfield.com/p_142SAT6/Speaker-Brackets.html?tp=919
I have the adapters in your first quote from ordering them for my WRX. They did not fit the WRX but I held onto them. I measured them and I get 5 15/16" to 6 3/4" (depending on which location on the elongated holes that you use) for the distance between the "close" holes, and a distance of 6 7/16" to 7 3/8" between those holes and the 3rd hole.
If you measured 7 5/8" and 8 1/8", respectively, the adapter in your first link would not have worked. Those measurements are off of the plastic.
Also, in looking at your picture and using the measuring tape over the speaker, it looks like the "close" holes are closer to 6.5" apart. Due to the angle of the picture, I can't tell about the 3rd hole.
Could you possibly re-measure the speaker and report back findings?
Thanks!
Old 07-12-2012, 01:58 PM   #48
GremlinGSP
doh lol . I know what I did. subtract an inch from what I got. i was starting at 1inch instead of the clip on the end of the tape. Those brackets i used worked I didn't have to cut them at all to get it to work.
Old 07-12-2012, 03:26 PM   #49
phenryiv1
Drives: 2011 WRX
That makes so much more sense!
Old 07-13-2012, 01:06 AM   #50
GremlinGSP
Heres a few more pics of the 3.5s
By gremlingsp at 2012-07-12
The Following 3 Users Say Thank You to GremlinGSP For This Useful Post:
djdnz (07-27-2012), phenryiv1 (07-16-2012), Yuck (09-20-2012)
Old 07-16-2012, 01:38 PM   #51
phenryiv1
Drives: 2011 WRX
All of that matches up with my other research. A million "Thanks" to you.
Old 07-20-2012, 09:17 AM   #52
phenryiv1
Drives: 2011 WRX
Based on the pictures and measurements above, I was able to fabricate these templates for adapters:
I made some PVC adapters (3/4" for the doors and 1/4" for the dash in which you could mount component tweeters). Two sets already went out for beta testing.
Old 07-20-2012, 09:19 AM   #53
Afghan Vet
Afghan Vet's Avatar
Drives: 2002 BMW 325i
Thanks so much for the pics of the dash speakers. I'd love to see a pic of the 'hole' left after you pull the 3.5" speaker out of the dash......is there a cavity? does it vent to the inside of the dash?
2013 Subaru BRZ Limited
Pioneer.Mosconi.Morel.Audible Physics.Ascendant Audio
Afghan Vet is offline   Reply With Quote
Old 09-08-2012, 11:32 PM   #54
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Did anyone ever measure the depth behind the rear side panels? I'm contemplating putting an 8" sub on either side when I get my car back.
kmbkk is offline   Reply With Quote
Old 09-09-2012, 09:04 AM   #55
gmookher
wow not an easy factory fit car huh
Old 09-18-2012, 03:52 PM   #56
E_br4ke
Drives: FRS 6MT
I just got my FR-s Thursday. Had a really nice aftermarket stereo in my old car so I'm rather irritated by the stock one. To get started I went ahead and popped off some panels to get some measurements. Thought I'd share some pics with you all.
The Dash speakers are 3.5" with about 2" depth
The Doors are 6.5" With 2" of depth. Anymore it will probably hit the window.
The Rear are 3.5 as well but the depth is more than enough.
Uploaded with ImageShack.us
Thanks for the pics and measurements. Looks like I'll be reusing the pioneer 6.5 speakers i have sitting in my garage. As long as they fit.
E_br4ke is offline   Reply With Quote
New Wheel Sizes/Photos from Rays / Volks BPAuto Wheels and Tires 68 12-12-2013 05:14 PM
Stock FRS Headunit/Speaker preformance jflogerzi Electronics | Audio | NAV | Infotainment 8 06-03-2012 01:03 AM
8 Speaker stereo specs? Rstalter77 BRZ First-Gen (2012+) — General Topics 56 04-24-2012 04:43 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 11:16 AM
