#407 |
AutoX-10/10ths every run
I'm wondering if at lower RPMs the time duration that the engine/rods see the load is longer.
#408 | |
Drives: 2017 BRZ
From that it follows that the resultant torque can be the same if combustion expansion is working over a more efficient range of leverage on the crank. For example, 1000 lb average force acting on an average crank throw of 2" would generate 2000 lb-in of torque. But if the combustion process is completed in a shorter amount of crank rotation (aka lower rpm's), you might have 1200 lb of force acting on an average throw of 1.67". Same torque in both situations, but more force at low rpm. Last edited by gtengr; 03-29-2018 at 02:45 PM. |
| The Following 4 Users Say Thank You to gtengr For This Useful Post: |
#409 | |
Drives: 14 BSP Edelbrock BRZ
Ah, that makes sense. You're saying at some low rpm you are producing a higher max cylinder pressure over, say only 15 degrees of rotation, versus 30 degrees at twice the rpm. If you had a sensitive enough engine dyno you would get spikes in reported torque on every power stroke that would smooth out as rpms increased. Thank you. |
| The Following User Says Thank You to toast For This Useful Post: | Tristor (03-29-2018) |
#410 | |
Drives: 2017 BRZ
#411 | |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | mrg666 (03-30-2018), TachyonBomb (04-03-2018) |
#412 |
Yes, that is the definition of impulse. If you don't have any physics background that generally means nothing to people.
| The Following User Says Thank You to toast For This Useful Post: | TachyonBomb (04-03-2018) |
#413 |
Gievn modern electronic control of everything where does ignition actually occur with regard to crank angle? At low rpm is it retarded to the point that the crank is as close to perpendicular to the rod as possible? I've never looked at any of the ignition tables nor do I have a feel for how long combustion takes in an absolute sense.
#414 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | TachyonBomb (04-03-2018) |
#415 |
Drives: Late 2014 Subaru BRZ
I have been pushing 400hp with flexfuel that has been on average of 74% for over a year and before that running 93 for a year. It's important not to tune for to much low end with factory rods. My boost controller will not allow more than 8psi under 4500rpms for good reason. Just set your maps boost control duty cycle for rpm/duty. No knock at all. I beat the shit out of her everyday, as she's my daily driver. Minus to everything is 3k oil changes and 10k miles I need new rear tires.
I have 27k miles boosted and loving it, no problems at all.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe Last edited by GsxrMe; 04-05-2018 at 02:03 PM. |
| The Following 3 Users Say Thank You to GsxrMe For This Useful Post: |
#416 | |
Rust bucket enthusiast
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tristor (04-21-2018) |
#418 |
Drives: 2017 Halo 86
Can you still blow an engine driving under 4.5K RPMs while boosted (non-spirited daily driving), or is blowing an engine entirely because people are redlining boosted cars that haven't had the bottom rebuilt?
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
| The Following User Says Thank You to Lakitu For This Useful Post: | weederr33 (04-21-2018) |
#419 | |
Sent from my SM-G960U using Tapatalk
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#420 |
Drives: frs
Why you will drive like an asshat for just to keep on boost?
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 74 | 05-07-2025 04:28 AM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
