#295 |
Drives: Scion FR-S
Hello,
I am looking in to getting Bilstein B16 coilovers for my FRS. Will I need anything other than CasCam plates and LCAs for camber adjustment? My last set up I just had Whiteline front camber bolts and rear camber kit, but I want more of a track set up this time around. thanks |
#296 |
TRACKBREAD
Has anyone found spring rates for the OEM 2017 suspension?
Google hasn't been helpful. |
#297 |
Drives: 2013 Subaru BRZ
Only estimates of 15% higher front, 10% lower rear.
Rear bar is now 15 mm. Front bar unchanged. |
#298 |
TRACKBREAD
#299 | |
I have the Whiteline 20 mm front bar, stock 14 mm rear bar and Bilstein B6 shocks all round. Ride is very civilized, comfortable even, and the chassis is very well balanced and easier to drive fast than with the original suspension settings. I also fit the MCA traction brackets which I can also highly recommend. |
#300 | |
TRACKBREAD
I'm going a very similar route, just stiffer springs and smaller bar up front. I've got OEM camber bolt up front. Going to fit the 2017 shocks and springs front and back, pair with a 19mm/16mm Perrin sway bar set and see how that drives. I did lots of testing of those spring rates (3kg/mm) and different sway bar settings in Forza and I'm hoping that the simulation calculations are as good as turn10 claims they are, because that combination was very stable and much more predictable than stock. Then I'll add the MCA brackets and the Billies later on. Sent from my iPhone using Tapatalk |
#301 | |
Your car will feel more tied down than mine, a bit sharper in the corners, but still with all the ride and rear axle grip improvements the softer rear springs deliver. |
#302 | |
TRACKBREAD
BRZ/FR-S Suspension Options List (Springs and Coilovers)
I don't think my new shocks are Sachs, they're from a regular 2017, not a PP version. I thought only the PP got Sachs. That and I really want monotubes on this car ![]() Sent from my iPhone using Tapatalk |
#303 |
Drives: 2017 Subaru BRZ limited PP
Would the Eibach pro-kit or sportlines be a good pair for the Sachs dampers? I purchased a 17 brz limited PP and wanted to get rid a little bit of the wheel gap
#304 |
#305 |
Which lowering spring would be the recommended one to pair with the Sachs dampers?
#306 |
Drives: '97 NSX-T, '18 Type R
#307 |
Drives: '13 Sport Tech
Does anyone have any real world feedback on the Blitz ZZ-R Spec DSC? They come with electronic damping adjustment. Spring rates look weird to me being 6F 4R.
Front - 6.0 kg/mm, adjustable pillowball upper mount Rear - 4.0 kg/mm, solid rubber upper mount 32-way single adjustment damper Includes remote adjustment via in-cabin electronic control DSC electronic control can be integrated with Blitz Touch-B.R.A.I.N. for datalogging and analysis Improves road feel and handling Comfortable street ride 1-year transferrable warranty from date of purchase |
#308 |
Drives: '13 GBS BRZ LTD 6MT
Based on threads here and assessment of my needs, I have decided on the Eibach Pro-Kit.
Why do we care? You ask. Because i have made two attempts to buy them from two different ebay sellers. Both purchases were allowed to complete only to be canceled within 24 hours. The first said they had just sold out. The second said that Eibach had recalled them and he is expecting the "redone" replacement springs in a couple weeks. Has anyone else heard about the recall? I googled but found nothing. edit: Also - sorry for reviving an old post. Last edited by caesar; 03-29-2018 at 11:07 AM. Reason: Necromancy |
| Adjustable shocks+ springs vs Coilovers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 06-08-2013 03:59 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| coilovers or springs? | koyv90 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-01-2012 08:49 PM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
| Subaru BRZ different suspension / springs tuning | ahausheer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 12-06-2011 12:52 PM |
