| Software Tuning Discuss all software tuning topics. |
Drives: Subaru BRZ 16'
Oft not writing properly brz 2016
Hi, i have problems writing on ECU it says its okay and shows no errors when i write map, but i still get CEL with code p0037 even i have turned it off on romraider. Does anyone have similar problems?
#2 | |
Drives: FT86
P0037 is Potential causes of a P0037 trouble code may include:
you need to check rear 02 sensor and wiring/plug That's an actual fault. you will need to do more than just disable code to remove rear 02 function, you will have to disable its compensations in tune as well as a bunch of cel codes. |
#3 | |
#4 |
Oh also i forgot to mension the launch control doesnt change even i change the value
#5 | |
Drives: FT86
write stock rom/tune back to car do you still get the cel code. if its all good you likely have mismatched tune/definition or mismatched tune for your car ie incorrect calibration id |
#6 |
When i bought the car it had some tune already done, so i dont have the stock map for it and OFM shows that my cal id is 10G, but OFT shows 01G when plugged to car.
#7 | |
Drives: FT86
See the Tactrix link in colour below, at end of that post is most of the stock roms, jiust unzip them and you will be able to load either the F10G or A01G stock to your car, jist load it to one of the tune slots in oft |
#8 |
I loaded the F10G stock map and still get the p0037, does it have anyother fuses that 29?
#9 | |
Drives: FT86
Its the EFI HTR fuse my guess would be o2 sensor was damaged during install due excessive torque applied Last edited by steve99; 03-24-2018 at 10:29 PM. |
| Problem with writing roms from OFT to car!! | 86ARMN | Software Tuning | 9 | 05-16-2016 10:01 PM |
| Windshield Writing | FRSure | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 04-03-2014 09:20 AM |
