Old 05-15-2016, 09:51 PM   #1
86ARMN
Drives: Dark Grey Metallic 86
Problem with writing roms from OFT to car!!
hey guys! I bought myself a used OFT and the previous guy had bought it for his Mx5, however I was able to read my stock ecu tune and copy the stock file. I used Open flash manager to load a OTS map from the OFT site (A00G) and when I went to write it, it came up with the error "ecu number mismatching, ecu write denied." what do I do??
86ARMN is offline   Reply With Quote
Old 05-15-2016, 10:05 PM   #2
steve99
that weird it seems to be saying the ecu vin number is now different from when the ecu was read.
the oft should show you a vin number in the display or in openflash manager check they match, check this matches your car vin.
also try writing back your stock tune from the slot labeled Original
assume your original rom calid was A00G ?
make sure you have selected vehicle type as toyota zn6
Old 05-15-2016, 10:52 PM   #3
86ARMN
hi steve, the vin that comes up is the same as my vehicles vin, and when i try to write back the original rom it comes up with "the file selected is already in the ECU".
If this is any use, I first read the stock rom and was paranoid that it may corrupt somehow because i had opened the door various times during the reading process so I decided to erase the tablet using the OFM. I then proceeded to read the stock rom again with everything switched off(radio, lights etc) and everything was fine. I went to OFM and my stock rom says PRESENT in the download section however the information table above does not show me my CALID. I know its A00G because it was there when I first read the stock rom.
Old 05-16-2016, 12:49 AM   #4
steve99
Ok are you on latest open flash manager 1.25.1
http://www.openflashtablet.com/downloads/
Also try updating to the latest template file here they don't seem to have in on website anymore, unzip it then apply it via open flash manager think it in the update tab
http://www.ft86club.com/forums/showp...79&postcount=2
the picture looks like it might be still on the mazda template file which might be causing the issues
after that you might need to ring the oft guys in USA
Old 05-16-2016, 03:00 AM   #5
86ARMN
thanks steve, yeah I just downloaded the template and updated it to the OFT. I now have the 86 as the background instead of the mx5. I then went to the car and tried to write the stage 1 file and it said the same thing, would I need to read my stock rom again? I don't think I will be able to erase and try again because isn't there a limit of 3 erases? Sent them an email yesterday and still waiting for a response
Old 05-16-2016, 03:31 AM   #6
steve99
Its 2 erases for rearly old ones and 5 for newer ones, wont hurt to try.
might be best to try phone usa day hours
Old 05-16-2016, 03:37 AM   #7
86ARMN
thanks for the response steve. I bought it used so im not sure if its the old or newer tablet. If i was to erase and it was the last erase on the tablet and it locks up(or whatever it does on the final erase) how would i unlock it?
Old 05-16-2016, 03:48 AM   #8
steve99
when you try and erase it in ofm it will say something like "erase count exceeded" tablet should still work in its current state.
You need to be connected to internet to erase.
The oft guys will need your oft serieal number to reset erase count on their servers.
Old 05-16-2016, 07:51 PM   #9
86ARMN
Resolved, Thanks alot steve! i erased and re read my original rom again with the new template and everything is working fine!
Old 05-16-2016, 09:01 PM   #10
steve99
thanks good to hear is all sorted,i would say having the mazda template file probably confused the oft when connected to an 86.
might be still worth asking the oft guys to reset erase count as you probably only have one left just advise them you switched from mazda to 86 and had a couple of problems.
its a good product rearly letting you switch between mazda 86 bmw and i suspect fiat abarth now
mismatch, oft, open flash tablet
About what aspect of your writing are you the most insecure? Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 32 09-14-2015 12:15 PM
Windshield Writing FRSure Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 04-03-2014 08:20 AM
Writing about first time track day experience with my BRZ Rescodna Tracking / Autocross / HPDE / Drifting 1 10-07-2013 02:15 PM
Removing writing on front windshield Chinadian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 10-24-2012 07:08 PM
Is the Scion FR-S useful for cursive writing? EsoBOFH FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 10-16-2012 04:16 PM
