| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Drives: Legacy GT
Yes it would work on the front with 2015 wrx brakes. You need the calipers too, they use 316mm rotors that are also found on the 05+ Legacy GT and tribeca. The tribeca was 5x114.3 also.
There is a 5x114 stock sized front rotor that fits over the bigger hubs, but you need 4-pot calipers to use it, because the hat is bigger to clear the hub, and will interfere with the caliper bracket. More expensive than the LGT brakes probably but pretty reasonable. http://knsbrakes.com/c/car-series/10...-+Single+Rotor The rear end gets more complicated, easiest way would be redrilling the stock rotor. The 2015 wrx uses 286x10mm non vented rotors. I think all the brz/frs get 290x18? |
#44 |
Drives: Supercharged GT86
So did anyone actually go for these?
#45 |
Drives: Firestorm FT-86
#46 |
#47 |
Drives: 2013 satin white brz limited
Late to the party but all the laughs about people not trusting them because they are "megan racing" parts. You know megan racing does not make any of their own parts they are just a brand right....
#48 |
Country Boy 4 Life
The brake rotor has the same bolt pattern as the hub. so when you get the hubs, you need new brakes too. I assume has the megan hubs and is using sti brake rotors.
I LIKE TIRES! |
#49 |
#50 | |
Country Boy 4 Life
Thank you for the information and clarification. If I remember correctly, HardRace made some adaptors too. What "Japanese Company" made the hubs you are using? Care to share any feedback on pro's & cons of the setup?
I LIKE TIRES! |
#51 |
Drives: Legacy GT
I still don't see much benefit to these. With other subarus, the 5x114 hubs and bearings are bigger and stronger. These appear to only change bolt pattern. So I guess it helps with wheel choice but that's it. If there's a set of wheels you can't live without that only come in 5x114 you might as well just use a bolt on adapter.
#52 |
Crap, let me look through my old stuff to find the name of the company. I I only found out about this company because of a buddy of mine told me. The only benefit was shock factor, Wheel options, and putting in STi/ATS swap without any problem. Been running them for 2 years without any problems.
#53 | |
Destroyer of Tires
Drives: 2001 Honda Accord, 1997 Lexus ES300
The only real downside I see to this is just simply cost. You'll have a much wider selection of wheels after the conversion is complete. |
#54 |
Drives: Working on it
Has anyone looked at whether Lexus IS hubs interchange?
#55 | |
#56 |
| Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) | Evasive Motorsports | Wheels and Tires | 31 | 06-13-2015 08:09 PM |
| CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) | JonMotoring | Wheels and Tires | 102 | 04-30-2015 08:22 PM |
| Lug Nuts - Muteki, Rays, Kics, Syun Project & Megan 5x114.3 Conversion Kit | eauto | Wheels and Tires | 359 | 10-15-2014 01:45 PM |
| Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric | deedz | Wheels and Tires | 12 | 05-22-2013 04:18 AM |
| Megan Racing's FR-S Drifting @ Extreme AutoFest | Guaruja | Tracking / Autocross / HPDE / Drifting | 3 | 06-11-2012 06:02 AM |
