Old 03-09-2018, 04:30 PM   #29
radroach
Drives: car
Glad that Blackstone are reporting fuel dilution amounts, however . I was just reading today about some reports from Blackstone perhaps falsely reporting fuel dilution amounts. I'd get a second test from another company on the fuel dilution amounts at that mileage, because of what I've been reading so far about this.
Old 03-10-2018, 04:39 PM   #30
Whatever happened to the days, where if you pulled the dipstick out and the oil looked dirty, you changed it .......
Or, as in with ol @Tcoat 's old cars, the oil was constantly being changed by having to add a quart every few days ......
Old 03-10-2018, 06:15 PM   #31
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
My stepdad was an Amsoil distributor a long, long time ago. I remember them, at first saying you just swap out the filter (I do not remember the interval) and top up, but you never actually changed it. Seems crazy.
My Corolla had a CVT that was supposed to never need an oil change. One of my shaft drive motorcycles has a sealed final drive with "lifetime oil" -Lots of failures means they changed their minds and because the bike does not have provisions to drain/fill it is a real PITA to change.
SCQTT is offline   Reply With Quote
The Following User Says Thank You to SCQTT For This Useful Post:
humfrz (03-10-2018)
Old 03-10-2018, 06:44 PM   #32
Well, I'll agree that crankcase oil (and filter) should be changed every now and then ....... but, I think we usually over change the MT and differential oils.
Heck, back on the farm, I don't recall my father or grandfather EVER changing the transmission or differential oils in any motor vehicles ......
Yep, they would just keep running round and round .....
Old 03-20-2018, 08:23 AM   #33
bluesubie
Drives: 2004 Subaru Forester 2.5XT
It’s not a false fuel amount but rather just an estimate based on the flashpoint. Oil Analyzer’s Inc tests both ways. If viscosity and flashpoint appear normal, they’ll only provide you with an estimate. If something looks wonky, they’ll do an actual fuel test using Gas Chromatography. They will also do GC if you request it.
I wouldn’t worry about it in a car that’s not modified since these cars don’t have fuel dilution issues. But I’d want a more accurate picture of fuel dilution in a modified car. OAI’s GC tests will typically show 1-3% more fuel than BS, IIRC. This is why a lot of WRX users switched to OAI. Without the port injection of Toyota’s system, the 2.0 DIT typically dumps 2-4% fuel into the oil.
OP- Your silicon is slightly elevated. What air filter are you running?
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
Tcoat (03-21-2018)
Old 03-21-2018, 03:32 PM   #34
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just a dry cone filter.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-22-2018, 09:26 PM   #35
reeves
Ahhhh.........go for 20,000 ...... for science .......
20K-mile intervals are possible, according to some..
[ame="https://www.youtube.com/watch?v=l-zDt9FGJi8"]Can Engine Oil Be Proven To Last 20,000 Miles? - YouTube[/ame]
The Following User Says Thank You to reeves For This Useful Post:
humfrz (03-22-2018)
Old 03-23-2018, 08:16 AM   #36
Varelco
Drives: '15 GT86 & '22 GR86
The service interval for Oil changes is 10k over here in the UK, so racking up this mileage between changes isn't at all sketchy. Not sure why its different for you guys?
Varelco is offline   Reply With Quote
Old 03-23-2018, 05:30 PM   #37
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
10k (miles) or 10k (kilometers)?
JimmyMac is offline   Reply With Quote
Old 03-23-2018, 05:45 PM   #38
Teseo
Drives: frs
Miles
Old 03-23-2018, 06:56 PM   #39
JimmyMac
JimmyMac's Avatar
Originally Posted by Teseo View Post
Miles
So 10k Miles for UK service interval? My USA service manual says every 7500 miles under normal use not 10,000. Interesting.
Old 03-23-2018, 08:58 PM   #40
Teseo
Drives: frs
Then stick with your manual and dont forget to use high quality oil. In my case i change mine at 5k and little more for peace mind due to notable change in weather temp (sometimes we are at 77°F, next day is 95°F)
Old 03-24-2018, 12:59 PM   #41
JimmyMac
JimmyMac's Avatar
I'm not worried about change interval, just more curious about @Varelco comment on 10k change interval in the UK. Curious if their manuals stated 10k miles or 10k kilometers. 10,000 kilometers is about 6200 miles.
Old 03-26-2018, 05:42 AM   #42
Varelco
The UK is a metric country so yeah I'm talking miles
The European service template does state under normal conditions the oil is to be replaced every 9,000 miles or every 4,500 miles under severe conditions (which is classed by Toyota as frequent short journeys, extreme cold temperatures)
Its a little confusing but in the UK the Toyota and Subaru dealerships actively state that ours cars are serviced every 10,000 miles or annually (depending which one comes first)
Another interesting note on the template is the range of oil grades, obviously this is country dependent but it goes right up to 20w50!
how many miles before first oil change Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 72 10-25-2014 10:35 AM
Just purchased my '13 BRZ with 1,800 miles. Should I change the oil? torqueno Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 10-08-2014 10:55 PM
Oil change at 4100 miles djdrugga24 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2014 02:00 PM
Almost at 1000 miles. Oil change when? TheGuyWithTheFireStorm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-08-2013 12:31 PM
Oil change at 1000 miles. Dorb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 03-08-2013 04:18 PM
