Old 03-22-2018, 12:51 PM   #1
Norotor
Drives: '13 FRS, '18 WRX, '21 M3
Loud ticking from engine
Hello,
2013 MT with 70k miles, started getting a very loud ticking sound that increases in rate with RPM. It doesn't sound violent like rod knock , and it is present at any RPM above 950, cold or hot. The rate of the ticking gets faster with more RPMs; by 4000 rpm its so fast it sounds like buzzing. Sounds like its only coming from the passenger side/right side head.
Car is turbocharged with a 50-trim, was running very low boost (8 psi) when it started happening. I was getting onto the freeway, and when boost was coming on around 4.2k rpm the car jolted as if i hit the rev limiter. A few miles later the ticking sound started. Oil level has been fine, and this happened 3 miles after I had done an oil change. AFR is fine, builds boost a little bit slower, and no codes are present.
My question is, does this sound like a bent rocker arm? Stuck valve? Broken valve spring? Any help is appreciated.
Norotor is offline   Reply With Quote
Old 03-22-2018, 12:59 PM   #2
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
The 2nd YouTube video sounded like my FRS before it died due a VVT issue. http://www.ft86club.com/forums/showthread.php?t=125879
speedy racer is offline   Reply With Quote
Old 03-22-2018, 02:34 PM   #3
Originally Posted by Norotor View Post
Hello,
2013 MT with 70k miles, started getting a very loud ticking sound that increases in rate with RPM. ...........
Hello Noroto and welcome to our fine forum .......
Oh, my ......that don't sound good ..... has the car given you any codes .....??
Back in the day ...... I would have called that a stuck lifter or a valve out of adjustment.
However, today, with this engine, I would have to guess that it's a rod knocking ...... sorry.
Old 03-23-2018, 12:51 AM   #4
Norotor
No codes ever showed up.
Old 03-23-2018, 12:57 AM   #5
Hopefully, some other folks will chime in.
I listened to your 2nd u-tube posting and it still sounds like a rod knocking to me.
(I hope I'm wrong)
Old 03-23-2018, 01:09 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pre 15' are known to potentially develop rocker arm issues. Valve cover is going to have to come off from the sounds of it.
Old 03-23-2018, 01:55 AM   #7
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
That 2nd video sounds like a rod knock
shaynek is offline   Reply With Quote
Old 04-23-2018, 09:50 PM   #8
Norotor
Just wanted to give an update;
I pulled the engine out and took it apart, it has a badly bent rod. Bearings are okay. Haven't taken the shortblock completely apart yet so I'm not sure if the cylinder wall is okay.
Too-small of a turbo gives too much torque at low RPMs which the stock rods can't handle and end up bending. I had a small 50-trim, even though it was low boost it came on too quick. I remember now that when it happened, I was getting on the gas in third at low RPMs, should have downshifted
Thanks to everyone that chimed in.
Old 04-24-2018, 01:45 AM   #9
shaynek
shaynek's Avatar
Unfortunately, my engine blew late jan. It had an identical sound. The rod snapped and put a 2 inch x 12 long hole in the block. My rod snapped when I was leaving a parking lot so I think boost kicked it and the rod finally snapped
Squeaking/ticking noise coming from engine bay klus95 Issues | Warranty | Recalls / TSB 7 11-17-2016 11:56 PM
Loud engine noise? Rifle Engine, Exhaust, Transmission 9 08-16-2015 12:26 PM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 09:58 PM
FR-S Loud Engine Noise White0utFrs Issues | Warranty | Recalls / TSB 15 09-20-2013 08:28 PM
Engine is making a loud ticking with Redline 0w20 KevinBRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-29-2013 09:34 AM
