Old 03-21-2018, 08:56 PM   #1
dattran86
Driver
Drives: 2013 Whiteout FRS
ABS and SAS came on after Coilovers installed
I got ABS and SAS came on after the coilovers installation tonight. Of course I haven't had time to get an alignment yet, so the steering wheel is off quite a lot. about 45 degree to the right with the wheel being center
I talk to a couple mechanic friends. they said that it would go away after an alignment. and all the toe in front are back to 0. It came on due to the car electronic steering and it senses the wheel is out of center.
Now i'm just a bit worry that after the alignment, I may have to bring it to the dealership to get it flashed. And it won't go away by itself.
Anyone went through the same issues that I have?
If So, Please shed some light for me.
Thank you in advance.
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 03-21-2018, 09:03 PM   #2
CSG Mike
CSG Mike's Avatar
You most likely damaged the wheel speed sensors/lines.
Tristor (03-21-2018)
Old 03-21-2018, 10:22 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You've done something VERY wrong in my eyes.
I can't imagine why your steering is so far off from a simple suspension swap.
If done correctly you shouldn't have more than camber and toe to fix.
The steering wheel should still be centered either way.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
CSG Mike (03-22-2018), strat61caster (03-21-2018), Tristor (03-21-2018)
Old 03-21-2018, 10:42 PM   #4
dattran86
Driver
We had to disconnect the sway end link, and installed new OEM endlinks as well.
I had Coilovers done on my previous car as well from Stock ride height to Coilovers the steering was off as well.
Car is about 1.5-1.6 inch lower from stock, with camber bolts, and the top hat maxed out on neg camber.
IG: aimforapex
Old 03-21-2018, 11:04 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Just get it aligned and see if it fixes it, if it doesn't you likely damaged the wheel speed senor as Mike stated.
I just did my coils a couple months ago and my alignment only changed the toe slightly, but it was pretty even on both sides.
Old 03-22-2018, 12:12 AM   #6
dattran86
Driver
Got the car up in the air. And inspecting everything.
I think I figure out why the steering out of wack.
-maxed out neg camber from top hat
-additional camber bolts
I have close to -3 maybe a tad bit more camber in the front right now with the OEM alignment (assuming I had an alignment with OE suspension, I'm the second owner)
I think having a lot of camber will effect the toe dramatically.
Will update this thread after my alignment and corner balance!
IG: aimforapex
Old 03-22-2018, 12:48 AM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you've added camber even remotely evenly, like within half a degree L/R it shouldn't throw your steering that far out of whack.
I had a camber plate come loose on me after hitting a pothole, so left was full negative, right was full positive and I only had a slight ~10 degree angle to continue going down the freeway until I got home to fix it, iirc that would have been 1.5+ degrees different left to right.
45 degrees off center is something not right, but a good alignment tech can hopefully find and fix that without charging you an arm and a leg
ineedyourdiddly
dattran86 (03-22-2018)
Old 03-22-2018, 12:55 AM   #8
dattran86
Driver
I may have jump the gun and said 45 degrees
Here is a picture of my steering wheel, while going straight (a little bit toward the right) the road has a little curve.
IG: aimforapex
Old 03-22-2018, 03:56 AM   #9
Brzxton
Drives: 2015 Subaru Brz
I literally just fixed this problem but it was from me taking off the steering wheel. My wheel was about 30 degrees to the left. I had to take it to the dealer and asked them to recalibrate the steering angle sensor which foxed the problem and got rid of the lights. I also got a new clockspring off ebay but idk if that was necessary. Hope that helped. Ill link the thread that i made on the issue.
http://www.ft86club.com/forums/showthread.php?t=126079
Brzxton is offline   Reply With Quote
Old 03-22-2018, 08:55 AM   #10
dattran86
Driver
Taken a better picture in the morning.
It doesn't look that bad at all. This is the front wheel completely straight ahead.
I think after the alignment it should be fine.
I will update this thread just in case anyone run into the same issue that I am in the future.
IG: aimforapex
The Following User Says Thank You to dattran86 For This Useful Post:
strat61caster (03-22-2018)
Old 03-22-2018, 09:55 AM   #11
cjd
cjd's Avatar
Drives: 2017 BRZ
I just went from stock to coilovers and -3.4° camber and only had .17° of toe to correct in the front.
Something more is going on here.
That said, I still think an alignment is a good start.
The Following User Says Thank You to cjd For This Useful Post:
Old 03-22-2018, 10:24 AM   #12
dattran86
Driver
Good news update.
I mess around with the toe last night, and did a quick dirty alignment. and drove to work this morning with a steering wheel straight. all the lights came off.
Thanks everyone for the help and input! now I know its just the steering wheel sensor, sensing the wheel is off center.
off to the alignment rack I go!
IG: aimforapex
Old 03-22-2018, 10:25 AM   #13
dattran86
Driver
Pics after 2 minutes of driving with the steering wheel in centre straight on.
Have not come back since
IG: aimforapex
Old 03-22-2018, 01:08 PM   #14
KL
Drives: 2013 SWP BRZ
Lol, my ABS, TCS and cruise lights came on after I put in rear LCAs and front camber bolts. An alignment solved all the things. I'm far from an expert but I think that when the car realizes it's that far out of spec, it trips those systems off
KL is offline   Reply With Quote
The Following 2 Users Say Thank You to KL For This Useful Post:
dattran86 (03-22-2018), zc06_kisstherain (03-23-2018)
Camber and toe after coilovers installed ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-22-2015 01:58 PM
RS-R* Sports i Coilovers installed!!! eddieEndo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-10-2014 01:25 AM
ST coilovers installed yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 10-08-2014 02:22 PM
ST coilovers installed ThatManAnt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-23-2014 09:55 PM
BC Coilovers, installed today Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 12-17-2012 12:07 AM
