#43 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | TofuJoe (02-08-2018) |
#44 |
Ohne Titel
Drives: 2017 BRZ PP ISM
@TheRacersLine - FYI. Sounds like a tune would optimize the airbox and intake elbow swap. Or just the stock tune in general. Dammit...LOL
#45 |
Drives: frs
Read this twice and still confuse mainly due to descriptions on websites..
If i want strictly Ecutek bluetooth dongle, and Etune what else do i need other than a Vehicle License? Is the vehicle license the same as software license? |
#46 | |
Drives: Toyota GT86
With those 3 things: Dongle, BT VHI and license you can flash a tune you purchased somewhere else. If you want to do DIY tuning, you need to additionally purchase RaceRom extension.
#47 |
Drives: 13 FR-S
I thought the Bluetooth interface cannot be used to flash the ECU.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
#48 |
Drives: Toyota GT86
It can indeed but not via BT. It has a mini USB port, so it's over USB. But you need the dongle as mentioned.
#49 |
Does ecutek stock ROM now includes 2017 automatic models? Specifically with push button start?
#51 |
One downside for ecutek is once flashed, the trace will be detectable in ECU unlike OpenFlash you can completely remove it before going to dealer for warranty works. Is this true? Any way to get around it?
#52 | |
Drives: UK GT86
To be "able to tell" if a car is tuned will require more equipment that a dealer has. They certainly can't connect to the ECU and it tells them that a car is tuned. The EcuTek license will remain in the ECU so this could be picked up by forensic checking of the ECU but this is not something the dealers would do, but Subaru/Toyota. If an EcuTek tune is on the ECU then the dealers will not be able to re-flash the car. If you flash a stock ROM on with EcuTek this is not the case but then if the dealer flash over it you will lose the EcuTek license. Then again if the dealer flashes over an OFT file then you could have your CalID changed and cause issues with the marrying of the device. TBH I don't know why you'd bother to go back to stock, I never did on my car. Then again the US dealers seem more likely to reject claims....
.: Stealth 86 :.
#53 | ||
Drives: FT86
Unfortunatly the dealer can easily check with their tool. however a kodename 47 said it not a routine practice unless they are looking for evidence, and required a little research by the dealer technician. They need to read the CVN and the Calibration ID then look up and compare the values. Parameter called CVN Calibration Verification Number is available via dealer tool, this is basically a checksum of the flashable area 8000-13FFFF each stock rom has a set CVN, so they would need to look that up and compare it with the CVN read from vehicle. If its different to stock rom of same calid , bingo got you. this is different to the Calibration ID which does stay same ie like ZA1JB01C or whatever it is. [18:27:03.414] CALID : ZA1JA01D [18:27:03.429] CVN : ED0690B9 [18:27:03.429] VIN : JF1ZNAA12D272 Any type of tune from any tune system will be detectable as CVN will be different from a normal stock rom of same Calibration ID with Ecutek the embedded licience will alter the CVN as its a 14 byte string just after 8000 hex in the flashable checksummed area of rom, so even ecutek "stock" roms are detectable. It possible to remove the ecutek licience with ecutek using a special switch then flashing, but in doing so you will loose your ecutek licience and need to get it renewed or buy a new one. or if you wrote over your stock ecutek rom in ecu with another flash tool again licience will be lost. this also happens if dealer reflashes your stock ecutek rom in ecu. any modified ecutek rom has access keys changed to dealer cannot read or write rom , but they can still run diagnostics and read stuff like CVN and Calid and discover rom is not 100% stock. note the "flash counter" you see in ecutek is put their by ecutek its in that 14 byte encoded string, so its not readable or useable by dealer. |
#54 |
wow, it's kind of scary dealer would reflash ECU during dealer visits. OpenFlash doen't have to deal with these issues?
#55 |
Drives: brz 2017 hksv2
a question
Ecutek kit is: cable + dongle, then you need a license for every single car Is the license contained in the dongle? or is it just downloaded digitally from the ProEcu software? I mean, if I borrow my ecutek cable to a friend, and he wants to use my cable he will then buy a license from a master tuner How does it work with the new license for him? will he receive a new dongle or just use mine ? |
#56 | |
Drives: FT86
if you leave ecutek tune in ecu then ecu is locked and dealer cannot flash If ecutek stock rom in car yes they can flash If you keep receipt from dealer ecutek will in mosr cases replace licience for free. openflash or Tactrix don't lock ecu so dealer can always reflash and theirs no licience in ecu with those systems. OFT can be a bit of drama if you did not unmarry oft , and dealer reflashed to different calid. but you can just write over it. |
| PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning | ptuning | Forced Induction | 71 | 02-27-2019 07:55 AM |
| Works Axle Back Muffler Review (Works ABM) | ButeraFRS | Engine, Exhaust, Transmission | 16 | 03-15-2018 06:23 PM |
| WORKS Exhaust System - Development | 86_ZN6 | Engine, Exhaust, Transmission | 305 | 02-24-2014 04:57 AM |
| Borla UEL Header, works automotive parts and ecutek tune | clayrush | Engine, Exhaust, Transmission | 14 | 06-27-2013 03:37 PM |
| subaru brz navigation system wire diagram? watching movies usb works !! | SgtBolt | Audio/Visual, Electronics, Infotainment, NAV | 3 | 06-21-2012 11:31 PM |
