Old 02-08-2018, 08:16 PM   #43
steve99
Drives: FT86
Originally Posted by TofuJoe View Post
Thanks, guys! Yes, there was a loss of traction. And @steve99 you are correct that IAM wasn’t an available parameter on the stock tune (no ECUTek license).
@Kodename47 I’m not sure if FLCK or engine load were available as I was borrowing a computer and cable, and it was set up for me with a default set of parameters.
The point of the log was to make sure that going to a 2013-2016 airbox on my 2017 doesn’t necessitate a tune. This swap was needed to allow room for an oil cooler.
I saw recently on Facebook that the OFT will now log 2017 cars, but I haven't confirmed. If the OFT works for IAM, FLKC, etc., maybe I'll get one and do some more logging.
the ltft are getting a little high like -10 in places so when you get tune it will be worth rescaling maf to reduce those trims and get afr and commanded afr close during WOT. you may need to rescale o2 sensor to read richer to d this depending on fueling
TofuJoe (02-08-2018)
Old 02-08-2018, 11:30 PM   #44
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
@TheRacersLine - FYI. Sounds like a tune would optimize the airbox and intake elbow swap. Or just the stock tune in general. Dammit...LOL
TofuJoe is offline   Reply With Quote
Old 03-04-2018, 05:38 PM   #45
Totalrecall
Drives: frs
Read this twice and still confuse mainly due to descriptions on websites..
If i want strictly Ecutek bluetooth dongle, and Etune what else do i need other than a Vehicle License? Is the vehicle license the same as software license?
Totalrecall is offline   Reply With Quote
Old 03-05-2018, 04:00 AM   #46
Tor
Tor's Avatar
Drives: Toyota GT86
With the old programming kit, there is also an encrypted USB key/dongle included. Without this dongle the ProEcu software doesn't run, so you need to purchase this dongle as well, as it's not included with the BT Vehicle interface.
With those 3 things: Dongle, BT VHI and license you can flash a tune you purchased somewhere else.
If you want to do DIY tuning, you need to additionally purchase RaceRom extension.
Tor is offline   Reply With Quote
Old 03-05-2018, 05:26 PM   #47
gutbuster
Drives: 13 FR-S
I thought the Bluetooth interface cannot be used to flash the ECU.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
gutbuster is offline   Reply With Quote
Old 03-05-2018, 06:50 PM   #48
Tor
Tor's Avatar
Drives: Toyota GT86
It can indeed but not via BT. It has a mini USB port, so it's over USB. But you need the dongle as mentioned.
Old 03-21-2018, 10:01 AM   #49
stlgrym3
Does ecutek stock ROM now includes 2017 automatic models? Specifically with push button start?
stlgrym3 is offline   Reply With Quote
Old 03-21-2018, 10:39 AM   #50
steve99
Drives: FT86
Yes includes K00D, push button or non pushbutton start have same ecu calibration
stlgrym3 (03-21-2018)
Old 03-24-2018, 11:09 AM   #51
stlgrym3
One downside for ecutek is once flashed, the trace will be detectable in ECU unlike OpenFlash you can completely remove it before going to dealer for warranty works. Is this true? Any way to get around it?
Old 03-24-2018, 03:28 PM   #52
Kodename47
Kodename47's Avatar
Drives: UK GT86
Sigh.....
To be "able to tell" if a car is tuned will require more equipment that a dealer has. They certainly can't connect to the ECU and it tells them that a car is tuned.
The EcuTek license will remain in the ECU so this could be picked up by forensic checking of the ECU but this is not something the dealers would do, but Subaru/Toyota. If an EcuTek tune is on the ECU then the dealers will not be able to re-flash the car. If you flash a stock ROM on with EcuTek this is not the case but then if the dealer flash over it you will lose the EcuTek license. Then again if the dealer flashes over an OFT file then you could have your CalID changed and cause issues with the marrying of the device.
TBH I don't know why you'd bother to go back to stock, I never did on my car. Then again the US dealers seem more likely to reject claims....
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-24-2018, 05:21 PM   #53
steve99
Drives: FT86
Originally Posted by Kodename47 View Post
Sigh.....
Unfortunatly the dealer can easily check with their tool.
however a kodename 47 said it not a routine practice unless they are looking for evidence, and required a little research by the dealer technician.
They need to read the CVN and the Calibration ID then look up and compare the values.
Parameter called CVN Calibration Verification Number is available via dealer tool, this is basically a checksum of the flashable area 8000-13FFFF
each stock rom has a set CVN, so they would need to look that up and compare it with the CVN read from vehicle. If its different to stock rom of same calid , bingo got you.
this is different to the Calibration ID which does stay same ie like ZA1JB01C or whatever it is.
[18:27:03.414] CALID : ZA1JA01D
[18:27:03.429] CVN : ED0690B9
[18:27:03.429] VIN : JF1ZNAA12D272
Any type of tune from any tune system will be detectable as CVN will be different from a normal stock rom of same Calibration ID
with Ecutek the embedded licience will alter the CVN as its a 14 byte string just after 8000 hex in the flashable checksummed area of rom, so even ecutek "stock" roms are detectable.
It possible to remove the ecutek licience with ecutek using a special switch then flashing, but in doing so you will loose your ecutek licience and need to get it renewed or buy a new one.
or if you wrote over your stock ecutek rom in ecu with another flash tool again licience will be lost. this also happens if dealer reflashes your stock ecutek rom in ecu.
any modified ecutek rom has access keys changed to dealer cannot read or write rom , but they can still run diagnostics and read stuff like CVN and Calid and discover rom is not 100% stock.
note the "flash counter" you see in ecutek is put their by ecutek its in that 14 byte encoded string, so its not readable or useable by dealer.
Old 03-24-2018, 05:46 PM   #54
stlgrym3
wow, it's kind of scary dealer would reflash ECU during dealer visits. OpenFlash doen't have to deal with these issues?
Old 03-24-2018, 08:10 PM   #55
tomm.brz
Drives: brz 2017 hksv2
a question
Ecutek kit is: cable + dongle, then you need a license for every single car
Is the license contained in the dongle? or is it just downloaded digitally from the ProEcu software?
I mean, if I borrow my ecutek cable to a friend, and he wants to use my cable he will then buy a license from a master tuner
How does it work with the new license for him? will he receive a new dongle or just use mine ?
Old 03-24-2018, 08:56 PM   #56
steve99
Drives: FT86
if you leave ecutek tune in ecu then ecu is locked and dealer cannot flash
If ecutek stock rom in car yes they can flash
If you keep receipt from dealer ecutek will in mosr cases replace licience for free.
openflash or Tactrix don't lock ecu so dealer can always reflash and theirs no licience in ecu with those systems.
OFT can be a bit of drama if you did not unmarry oft , and dealer reflashed to different calid. but you can just write over it.
PTUNING Plug and Play WMI (Water/Methanol Injection) System and ECUTek Tuning ptuning Forced Induction 71 02-27-2019 07:55 AM
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
WORKS Exhaust System - Development 86_ZN6 Engine, Exhaust, Transmission 305 02-24-2014 04:57 AM
Borla UEL Header, works automotive parts and ecutek tune clayrush Engine, Exhaust, Transmission 14 06-27-2013 03:37 PM
subaru brz navigation system wire diagram? watching movies usb works !! SgtBolt Audio/Visual, Electronics, Infotainment, NAV 3 06-21-2012 11:31 PM
