Old 03-16-2018, 09:15 PM   #1
LilGreenNumbers
Drives: Silver BRZ
Head Unit Screen Malfunction
I have a 16 BRZ and a couple of weeks ago I noticed that the head units screen was getting fuzzy with lines across it like a bad connection. But it would go back to normal after the car would turn off and reset it. A couple of days ago it happened but hasn’t gone away. I lost the ability to use the radio or Bluetooth The touch screen still works but it seems as though it might have a faulty logic board? I’m not sure. So I removed the dash and got to the back unplugged everything and secured all the harnesses and plugs. The image got worse but touch still remains working. My question is should I take it to the dealer to see if it’s the HU itself or if it’s a loose cable in a harness (I really hope not). I’m not sure if it’s still under warranty but I’m also thinking about skipping the dealer and installing a new aftermarket HU, that’s why I’m worried about the possibility of dead cables in the harness. Any suggestions?
LilGreenNumbers is offline   Reply With Quote
Old 03-17-2018, 12:32 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If under warranty take it in.
Most likely it's the screen and not anything else. If you just want upgrade then do some shopping. There are lots of options nowadays. Prices from $200-1k
Any way to use a micro SD card in touch screen head unit ggiddix Electronics | Audio | NAV | Infotainment 7 01-03-2018 11:22 AM
head unit screen cracked flat486 Issues | Warranty | Recalls / TSB 5 01-15-2016 12:44 AM
Scion touch screen head unit from FR-S geezer86 Audio/Visual, Electronics, Infotainment, NAV 9 10-03-2014 10:28 PM
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 06:24 PM
WTB: 2014 Scion Frs Touch Screen Head Unit 86 FRS Want-To-Buy Requests 1 07-28-2014 02:42 PM
