Old 03-12-2018, 03:40 PM   #1
iloveejose
Drives: 2015 Scion FRS
Post D2 Coilover clump noise
Hey so installed brand new D2 coilovers over the weekend for my 2015 scion FRS, and the front ones don't make any noise but my rear ones make a clump noise when I either turn on a sharp turn or hit a bump. it drives pretty smooth overall it just does that on the bumps. any suggestions on what it could be ??
iloveejose is offline   Reply With Quote
Old 03-13-2018, 09:45 AM   #2
Dee
Drives: 2014 Asphalt FRS
I have st coilovers. Exact same issue. Please let me know what it is if you find the solution
Dee is offline   Reply With Quote
Old 03-13-2018, 01:48 PM   #3
iloveejose
do you just drive it like that or did you end up taking them off ?
Old 03-13-2018, 01:55 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Did you pre-load the suspension before install?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-13-2018, 02:15 PM   #5
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
I'd go over all the nuts and bolts again with a wrench to double check torque.
Lincoln Logs is offline   Reply With Quote
Old 03-13-2018, 08:16 PM   #6
iloveejose
Yes but the bolt in trunk stays super high up every time I lower It idk what to do to make it go down
#clump #coilover #help #
Skunk2 coilover noise. Chayce808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-14-2016 09:20 PM
Rear BC BR coilover making noise PB-GT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 05-14-2016 02:58 AM
New coilover ticking noise ItzBidge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 01-07-2016 08:41 PM
Is this coilover noise okay? VIDEO autoCAR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-20-2013 01:55 PM
Another Coilover noise thread.. 256brz2013 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 07-05-2013 10:49 AM
