Old 03-09-2018, 05:49 PM   #3109
scirocco78
Drives: Scion FRS
I know I've seen this discussed before but I need some advice.
I had the White line diff inserts installed and the car worked fine.
I just installed the White line traction kit (rear sub frame inserts) and my car is EVIL on the street. I will not let my wife drive it the way it is right now.
Any of my "normal" driving on my normal routes results in sideways corner exit.
Is this just my throttle inputs needing adjustment or should I remove some of these bushing inserts?
I already took out my TRD rear sway bar and put in the OEM bar and softened my rear shocks quite a bit but it still steps out easily.
Any input is appreciated
scirocco78 is offline   Reply With Quote
Old 03-09-2018, 06:09 PM   #3110
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Tires?
Never had an issue with them on either of my cars. Just the power getting to the rear wheels better/quicker and more chassis feedback.
justinco is offline   Reply With Quote
Old 03-09-2018, 10:05 PM   #3111
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Alignment may be messed up now if the rear subframe went into a different position than it was before.
Old 03-09-2018, 10:32 PM   #3112
cjd
cjd's Avatar
Drives: 2017 BRZ
Isn't everything attached to the subframe? Though thrust angle could be different.
The Following 2 Users Say Thank You to cjd For This Useful Post:
DocWalt (03-11-2018), strat61caster (03-10-2018)
Old 03-09-2018, 10:50 PM   #3113
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Sounds like you've added toe out in the rear, I'd check the alignment since the sway bar wasn't the issue.
14stu is offline   Reply With Quote
Old 03-10-2018, 07:23 AM   #3114
scirocco78
Drives: Scion FRS
Thanks guys!
Old 03-10-2018, 08:27 AM   #3115
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
May just need to get used to them? I loved the extra input I got from the car after installing mine!
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 03-10-2018, 01:29 PM   #3116
scirocco78
Drives: Scion FRS
I checked total toe when I finished but I never checked to make sure the subframe was straight I guess too much beer while working on it.
I just got done re aligning it.
Thanks everybody.
The Following User Says Thank You to scirocco78 For This Useful Post:
Old 03-10-2018, 09:43 PM   #3117
cjd
cjd's Avatar
Drives: 2017 BRZ
For anyone paying attention quietly (assuming I didn't somehow miss a post with this information already...)
SPC toe arms do not appear legal purely from an 'amount of metal' standpoint. The bushings are bigger by about 1mm. They're also a good bit heavier than stock. I don't think they offer material benefit for performance beyond alignments being SO much easier with them.
The Following 3 Users Say Thank You to cjd For This Useful Post:
DocWalt (03-11-2018), Silver Ignition (03-11-2018), strat61caster (03-10-2018)
Old 03-10-2018, 11:23 PM   #3118
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Damn, you're right. I got a slightly different measure than you did, about 2mm diameter increase on the metal and the polyurethane.
The metal sleeve has a larger OD but I was hoping the larger diameter of poly would offset that so you'd have a similar poly/metal content but the SPC is theoretically 'stiffer' and therefore not even legal by the letter of the law.
But the fact that I nailed my rear alignment in my garage in <1 hour last night before today's test n' tune made it worth it.
calculations with some sweet powerpoint engineering:
minor update, metal/poly makes a bit more sense from a 'is there more metal than squishy stuff comparison standpoint'
Metal/Poly: OE=0.7 SPC =0.77
You could go in and calculate an actual percentage for the whole thing but you'll get the same net result.
(damn, I should have put *not to scale on the bottom)
ineedyourdiddly
cjd (03-10-2018)
Old 03-10-2018, 11:30 PM   #3119
cjd
cjd's Avatar
Drives: 2017 BRZ
It's tough getting a good read on the metal bushing because the rubber goes right up to the edge and is rather thick at that point. I didn't get the calipers out though so could really be off in fact... But that doesn't change the fact that it's bigger.
Alignment happens tomorrow. Hopefully this removes a lot of the stress I faced last time.
Old 03-10-2018, 11:49 PM   #3120
strat61caster
While the measurement is far from precise there's a big enough difference that I don't think any finangling can make the measurements and calculation come out favorably. I'm a nerd so I did break down the percentages, the SPC has 1% less poly in it's bush than OE. It's also worth mentioning that the SPC is undoubtedly heavier, I haven't weighed my OE links but according to Anthony's thread they're 3.5 lbs for the pair and I weighed the SPC's at 5.2 lbs for the pair.
Mine seemed stiff at first but it adjusts like a dream, so easy to just turn the two links as needed to dial in what you want.
The only hard part is the lock nut on the outboard side of the link is blocked out by the trailing arm so getting it loose or tightening it with the car on the ground is tricky unless you have the perfect wrench (short open end, I can't recall size off the top of my head).
I'm pretty sure most of my frustration with OE came from dinged up cam-washers on the nut side, either I fucked 'em up or a lazy tech did, either way I think replacing those will make going back to OE easier if I'm ever in a position to fight for a good finish.
ineedyourdiddly
cjd (03-11-2018)
Old 03-11-2018, 12:07 AM   #3121
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
Thanks everybody.
I put those bushings in not too long ago also. I dont recall there being any leeway on reassembly. So I'm not sure what you mean about the sub frame not being straight. Maybe I missed something?
Sent from my SM-G930V using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 03-11-2018, 06:44 AM   #3122
Silver Ignition
APEXHNTR
That’s really unfortunate about the toe arms, as I just installed mine last night and the alignment was a dream!
Any way to petition to have it added?
#1867 of 2500
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
