Old 03-09-2018, 02:03 PM   #967
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Originally Posted by ajc209 View Post
The manual states 0W20 or 5W30 for hot condition or trackdays.
Since my oil cooler doesnt let oil above 110C on track I actuality switched back to 0W20 as my oil pressure was too high with 5W30.
What pressure were you seeing with 5w30 that you feel is too high?
The manual is also referring to a stock engine. Forced induction greatly increases torque, which greatly increases pressure on rod bearings. Our rod bearings are already unusually narrow, and the center pair share an oil journal. This engine was not designed for the torque loads of forced induction. That is why they have not added it despite all the demand. Your days running 0w or 5w are on borrowed time IMO. I would advise shim the pressure release valve and run 10w or higher on boosted FA20s.
killboy is offline   Reply With Quote
Old 03-09-2018, 02:40 PM   #968
gahooligan
Drives: 2017 BRZ Premium
Can you elaborate on shimming the pressure relief valve?
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 03-09-2018, 02:55 PM   #969
killboy
killboy's Avatar
There is a spring-based PRV inside the front cover. By adding a couple of washers under the spring, you can increase the pressure it requires before opening, so you can run thicker oil/higher pressure without blowing it out the PRV.
Old 03-09-2018, 03:46 PM   #970
ajc209
Drives: GT86 Cosworth
6bar hot at the pump outlet. Stock setup oil can get to 140C and its thin and weak with 0w20.
At 110C the film strength is considerably stronger and thats only on trackdays.
On the road I struggle to see over 90C.
Time will tell if I spin a bearing but lots of people on this forum use 0w20 with an oil cooler and forced induction.
Sent from my SM-G935F using Tapatalk
ajc209 is offline   Reply With Quote
Old 03-09-2018, 10:50 PM   #971
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I think we need some more owner pics in this thread. Post them up!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
nikitopo (03-10-2018)
Old 03-10-2018, 03:44 AM   #972
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
while you've got the front cover off I'd say to remove the oil gallery passage blanking plate and give the sharp corners of the main gallery a tickle with the dremel as it has to do a right angle turn to get out of the oil pump
Matt@Cosworth is offline   Reply With Quote
Old 03-13-2018, 02:25 PM   #973
killboy
killboy's Avatar
Yes! We did that also, forgot to mention.
Old 03-13-2018, 04:14 PM   #974
gahooligan
So are we saying NOT to run 5w-30 without the mods for street driving? But its ok at track temp? Or run 0w-20. I barley see 190°f oil temp on the street and only over 200 in traffic.
Old 03-14-2018, 12:23 PM   #975
gahooligan
More pictures as requested. This is my install on a 2017! Many thanks to a local owner of the kit, you know who you are! Love it! Not seen is the Jackson Racing rad/oil cooler combo, Tomei UEL and Top Speed Pro1 exhaust. I have also since added a UPR PCV side catch can and smaller pulley!!!
The Following 6 Users Say Thank You to gahooligan For This Useful Post:
CSG Mike (03-14-2018), Kiske (04-30-2018), muckypuppy (03-14-2018), new2subaru (03-14-2018), nikitopo (03-14-2018), weederr33 (03-14-2018)
Old 03-14-2018, 06:22 PM   #976
weederr33
weederr33's Avatar
That's a proper set up for sure! Love the way it looks. BTW what intake is that? Is it the perrin?
Old 03-14-2018, 06:33 PM   #977
gahooligan
Yes it is the Perrin. I need it on my 2017 so I could install the oil cooler and clear the lines running to the sandwich plate. The air Box on the 2017 manual transmission cars in the US have a larger air Box that does not have the bevel cut into the back side of it. It will not clear the oil cooler lines. As a bonus, I think it looks cleaner.
The Following User Says Thank You to gahooligan For This Useful Post:
Old 04-02-2018, 07:22 PM   #978
gahooligan
Just an update on the smaller pulley and Jackson Racing oil cooler/radiator combo from Mike at CounterSpace Garage... ran a track day two weeks ago. Never saw oil temps over 228f, and that was the highest. Mostly in the 118-124f range. Thanks for the advice Mike! Video link below. Track is short with little rest for the car, 30 min sessions too. Also running a delicious tune now. The Cosworth tune is excellent as well.
The Following 3 Users Say Thank You to gahooligan For This Useful Post:
botbs (04-03-2018), muckypuppy (04-03-2018), weederr33 (04-02-2018)
Old 04-02-2018, 07:57 PM   #979
weederr33
weederr33's Avatar
How does the delicious compare to cosworth's?
nikitopo (04-03-2018)
Old 04-09-2018, 02:36 AM   #980
enigma
Drives: Asphalt 86
Well friends, if anyone is in the market for a Cosworth Supercharged 86, I just listed mine for sale: http://www.ft86club.com/forums/showt...42#post3069842.
The car has been absolutely wonderful, and it's been one of the most enjoyable cars I've ever owned, but I've got my eye on something else, and I unfortunately won't be able to have two toys.
enigma is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
