Old 03-09-2018, 09:39 AM   #785
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Exclamation
Originally Posted by Kylebrz View Post
Yea yours should be good if the spring rate is the same as the hks Bov.
Sent from my SM-G950W using Tapatalk
Latest edition of installation manual (E04215-T590044-00) contains some better specified warnings about spare parts and maintenance. The most important are : verify oil level and oil filter upon mileage/usage, by-pass valve.
It's easy to order the parts to keep for urgent maintenance:
- 17672-002100 Bypass Valve, JPY 2,916 (USD 27,30), sending excluded from Japan
12002-AK015 Traction oil filter*, JPY 3,780 (USD 35,40), sending excluded from Japan *Change 5 years or 50k Miles (70k KMs)
12002-AK029 Traction Oil as Oil filter, 22,680 JPY (USD 213,00)
This is the oil spec for Europe/Japan/Asia climate area. For NA and NEurope cold climate area (winter below -10C°) it needs other code of Traction Oil
Trap63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Trap63 For This Useful Post:
Efferalgan (03-20-2018), FT86Z (12-14-2023), Kylebrz (03-09-2018)
Old 03-09-2018, 09:42 AM   #786
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
Originally Posted by Trap63 View Post
Latest edition of installation manual contains some better specified warnings about spare parts and maintenance. The most important are : verify oil level and oil filter upon mileage/usage, by-pass valve.
It's easy to order the parts to keep for urgent maintenace:
Yea I ordered extra traction oil and filter was 650 bucks
Kylebrz is offline   Reply With Quote
The Following User Says Thank You to Kylebrz For This Useful Post:
Trap63 (03-09-2018)
Old 03-09-2018, 09:48 AM   #787
Trap63
Trap63's Avatar
I ordered from Japex Ltd,#1 by-pass valve and #1 oil traction filter for the price I wrote above; JPY 2,600 of EMS sending to Europe.
Here I due VAT and Custom fees for the 26% of total.
The Following User Says Thank You to Trap63 For This Useful Post:
Old 03-30-2018, 05:34 PM   #788
wbradley
Sarcastic SOB
wbradley's Avatar
Going strong just not revving excessively or unloaded (clutch disengaged) to be cautious. This time I think it's going to hold up great. Really enjoying the car's extra oomph where the torque dip is otherwise. And finally got the oil cooler sorted out so pretty happy now. And pretty comfortable with keeping it going long term.
The Following 3 Users Say Thank You to wbradley For This Useful Post:
Kylebrz (04-10-2018), weederr33 (03-30-2018), zeal86 (03-30-2018)
Old 04-23-2018, 04:34 AM   #789
saikat.saha
Drives: Toyota Gt86 2012 orange
My V2 came with the HKS Flash Editor, so i used that to flash my ecu after the setup. Now i am thinking to getting a replaced ecu and flashing it with delicious tune. do you think this will be a better move on my part as there is no hks tuners around?
saikat.saha is offline   Reply With Quote
Old 04-23-2018, 06:01 AM   #790
Trap63
Trap63's Avatar
Exclamation
So your FA20 is Japanese ECU?
Old 05-06-2018, 07:07 AM   #791
saikat.saha
Originally Posted by Andew727 View Post
go with a Tial QRJ full recirculating BOV. i have one on my car with a high boost pulley. sounds amazing, looks better, and in my opinion performs better than the bypass valve.
pictures on my IG: andyb727
ill have videos up soon once i fix the crank pulley pin that i bent.
hey andrew, i have sent you req on instagram, i wanna see the tial bov on the sc kit, i also might have a few questions about it.
Old 05-13-2018, 02:59 PM   #792
wbradley
Sarcastic SOB
wbradley's Avatar
Pretty happy with the supercharger. Great performing product which I've stuck with and will confidently continue to use it as it was meant to be.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
weederr33 (05-13-2018), zeal86 (05-13-2018)
Old 05-30-2018, 12:07 AM   #793
NJUL9925
Drives: 2013 FRS
Hello does anyone have information on the maintenance of the blower unit?
I'm about to tackle the oil & filter change. I have a V1 btw
thanks
NJUL9925 is offline   Reply With Quote
Old 05-30-2018, 06:10 AM   #794
Trap63
Trap63's Avatar
thanks
see http://www.ft86club.com/forums/showp...&postcount=785
about SC core unit no maintenance schedule
Old 05-31-2018, 01:58 PM   #795
NJUL9925
Drives: 2013 FRS
Thanks I have the parts looking for the procedure if anyone has any tips or what to avoid.
Old 05-31-2018, 02:31 PM   #796
Trap63
Trap63's Avatar
Wink
check fluid level as usual weekly check list and belt tensioner reference point each 800/900 miles is my best suggestion to be sure of system's efficiency.
Old 05-31-2018, 07:28 PM   #797
killsafkat
killsafkat's Avatar
Drives: 2013 GT86
need advice.
i have the SC v2 kit with the flash editor. no other bolt ons, stock exhaust and manifold. i am thinking of going catless uel headers and i know the issue of CEL, but hks has a map ofr the NA cars on the flash editor which gets red of the CEL (Code P0420).
SO my question is, will i get the code with the catless headers, and what can i do to prevent it.
FYI there are no HKS tuners where i live.
killsafkat is offline   Reply With Quote
Old 06-01-2018, 01:58 AM   #798
Trap63
Trap63's Avatar
So HKS Flash editor runs only on Japanese ROM.
You need to identify the stock ROM and manage the right flasher update as well described in data sheet of HKS.
You can read in warnings that HKS talks about some Cel issues in several ROM, not for all.
BESIDE this you need to run editor ONLY for the setup they listed on first page of install manual.
Therefore you cannot flash on a car with catalyzed. The header must be the HKS one, a light metal cat.
I suggest you to find a ecutek tuning suite or any other if you get trouble to manage HKS flasher.
All directions and data sheet are only in Japanese for non USDM flasher as I think you get.
See warnings on bottom about CEL issues:
....を装着した際、走行条件によりP0420(触媒異常)エラーが発生しチェックランプが点灯する場合 がありますが故障ではありません。
  初期化ツールVer.2.04以降の PHASE2データは、P0420(触媒異常)エラーを【無効】に設定してありますので、チェックランプの 点灯を回避することができます。
  PHASE1データは、純正の設定と同じP0420(触媒異常)エラーが【有効】の設定になっています。
, The P0420 (catalyst abnormality) error may occur depending on driving conditions and the check lamp may be lit but this is not a malfunction. Since the P0420 (catalytic error) error is set to [Invalid] in PHASE 2 data of the initialization tool Ver. 2.04 and later, it is possible to avoid lighting the check lamp. For PHASE 1 data, the same P 0420 (catalyst abnormality) error as the genuine setting is set to [Enable].
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 10:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 10:37 AM
