#99 | |
Drives: Toyota GT86
A lower temp thermostat (not mishimoto). Remove the lower engine cover (if you do, remove the one behind it too) or get a baffled one. Water wetter with distilled water as a coolant. Tune the fans to come on earlier to work with the thermostat. The fans and the thermostat won't help much once you start to build heat and driving at high speeds. But it will give you a cooler engine when you start your trip and cools down more when you let off or slow down in traffic. From my experience if the outside temp is less than or around 30c you should be fine at 100mph. At 40c you might run a bit hot but not over heat. With a stock short block I wouldn't push it if the coolant temp gets to about 95c. That's how I blew my first engine ![]() Sent from my Pixel 2 XL using Tapatalk |
#100 |
Drives: 2016 Subaru BRZ
#101 | |
#102 |
Drives: Pearl White '13 ZN6
#103 |
#104 | |
Drives: 2017 BRZ Limited
#105 |
Drives: 2016 FR-S
#106 |
#107 |
![]() Low line = 2017 baseline (205hp crank) 2nd line = wastegate, 91 octane (~310hp crank) 3rd line = wastegate, e70 (flex) (~370hp crank) high line = 10.5psi at peak power, e70 (flex) (~450hp crank) Due to the nature of the dyno, the graph doesn't accurately represent how quickly the setup actually spools; I boost within 0.3s of throttle input from being off throttle, and can have full boost well before 3000 RPM. Also, note that this was with a stock front pipe, and stock exhaust! |
#108 | |
#109 | |
This kit is well engineered, with a carefully selected, properly sized turbo. Many other kits offer more "features" to attempt to boost their perceived value. Those "features", in reality, are not needed for most users, including myself. Note the lack of a BOV. I don't have to re-spool from scratch every time I transition on-off-on throttle, and the turbo is strong enough to handle not having a BOV. |
#110 |
Drives: FRS
#111 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
Mike,
Are you using the base t518z turbo from like 2014? I currently have the T620z that I bought back in 2014, do you have an idea what the max boost these turbos can go up to? Quote:
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
#112 |
| Greddy / Trust Turbo Kit (Video and Pictures) | BPAuto | Forced Induction | 62 | 03-18-2016 06:04 AM |
| BRZ GReddy t518z | NOTORIOUS.BRZ | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-15-2014 02:15 PM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 06:09 PM |
| GReddy Tuner T518Z Turbo Kit Fitted / Photos/ DYNO/ Video ! | NOTORIOUS.BRZ | Forced Induction | 17 | 07-29-2013 04:42 PM |
