Old 03-07-2018, 01:53 AM   #1
jorgerendonjr
Drives: Frs
2015 RS1.0 to 2017 retrofit
Thought it would be to share my project with you guys, still a few more components missing but I think it’s coming together nicely
Most of these parts were plug and play, with the exception of the gauge cluster which had to be reprogrammed prior to actual installation
But here are some pics
These are the oem headlights from a 2017 BRZ which I had the housing blacked out
Had to get the oem 2017 tail lights of course with the center clear portion tinted
2017 oem Brz radio with faux carbon ac controls
Same faux carbon on door switches from 2017 brz
2017 upgraded oem leather trims, side by side shot for comparison, swapped out all pieces
Standard oem 2013-2016 brz leather/Alcántara seats, which I hope to swap out for the yellow stitching seats from the 2017 Subaru BRZ series.Yellow Will also need to swap all the other leather trims
2017 860 steering wheel and air bag Which I hope to have the steering wheel restitched in red, or yellow if I manage to find the seats I want for sale, but here you can also see the gauge cluster as well
Now that 2018 brz came out and seem to have an upgraded headunit I’m going to try to get my hands one on for my car in the near future
I’m actually working on getting the 2017+ performance pack oem brembo kit so I’ll keep this thread posted with a more of those parts I will be adding
I also have a few other misc items installed as well, such as subaru homelink Auto dimming compass mirror, and the vanity mirror lights from a brz but these weren’t even worth a picture
Feel free to send any questions my way if you guys are curious on any of these parts and how installation came about
jorgerendonjr is offline   Reply With Quote
The Following 7 Users Say Thank You to jorgerendonjr For This Useful Post:
CxG (06-27-2019), DustinS (03-07-2018), Lonewolf (04-07-2018), monkeybike (04-06-2018), shaynek (07-01-2018), spike021 (03-08-2018), Vin (03-07-2018)
Old 03-07-2018, 01:28 PM   #2
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Nice work!!. I’m interested in the gauge cluster swap. I have a 17 86. Where did you get it, what’s the part number? How much?. How did you go about getting it programmed?. Same with the steering wheel buttons. Part number? Did you have to buy a harness?.. Do share!
el-guapin is offline   Reply With Quote
Old 03-07-2018, 02:50 PM   #3
ModalSoul37
ModalSoul37's Avatar
Drives: 2014 Limited WR Blue Brz
Looks dope so far! Did you have any trouble fitting the new headlights in? I have a ‘14 brz and I want to get the new headlights too
ModalSoul37 is offline   Reply With Quote
Old 03-07-2018, 03:30 PM   #4
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I among a ton of other people are going to be interested in the Gauge swap. I know clock spring needs to be changed for the steering wheel. What exactly needs done for programming the cluster? Does the car need to be available (Mine is currently apart for engine rebuild and upgrades), also are the steering wheel controls working?
Old 03-08-2018, 02:09 AM   #5
jorgerendonjr
Drives: Frs
Yea steering g wheel controls all work and yes that did require the 2017 dash harness and 2017 oem clockspring
Ask far as the cluster swapping goes, it’s only able to be one on push to start veihicles due to an immobilizing mechanism that key start cars have
For the programming the dealership did it for me and also sourced the parts, the wheel set up and cluster you’re looking roughly at mid $2,000 USD after all said and done
The Following User Says Thank You to jorgerendonjr For This Useful Post:
Chriswongbrz (09-15-2020)
Old 03-08-2018, 10:19 AM   #6
DustinS
DustinS's Avatar
Originally Posted by jorgerendonjr View Post
As far as the cluster swapping goes, it’s only able to be one on push to start veihicles due to an immobilizing mechanism that key start cars have
This is interesting, and a slight disappointment. I purchased a cluster already haha. Guess I will have one for sale soon.
Is this something that was tried and failed, or something the dealer told you?
Thank You for the info!
Old 03-08-2018, 11:13 AM   #7
jorgerendonjr
Drives: Frs
Other members have tried and told me on the Facebook group, if I may ask did you buy a brz or 860 cluster?
DustinS (03-08-2018)
Old 03-08-2018, 11:54 AM   #8
DustinS
DustinS's Avatar
BRZ.
I am trying to find a good wiring diagram or dealer service manual for 2017 BRZ or Toyota 86 with digital display to check out the wiring. I am having a hard time though.
Edit: Paid for Toyota TIS access to see the updated wiring diagrams and such. Nothing I see points to internal changes that wouldn't allow it to work, as well as the steps to program a new Gauge Cluster have not changed. Still kind of holding hope.
I also found the FB post, seems they were all saying that it wouldn't work without a reprogram. So I think it might still work. I will keep my hopes up.
Old 03-08-2018, 04:06 PM   #9
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
I have a 17 and have ben looking at parts to make the swap(if possible).
Found these two for the gauge for the 17 860:
SU003-07448 and SU003-07449
Not sure whats the difference.
For the switch i found this part number:
SU003-07459
Im hoping all I would need is to get the gauge programmed.
Old 03-08-2018, 06:31 PM   #10
Inextirpable
Awesome
Inextirpable's Avatar
Drives: World Rally Blue Subaru BRZ
This build looks great! I am interested to know how to managed to wire in the headlights. I was thinking of swapping in 2017 BRZ headlights on my 2013 BRZ.
Inextirpable is offline   Reply With Quote
Old 04-06-2018, 12:10 PM   #11
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Local dealer told me that when they order the cluster, the right mileage and VIN is needed as the cluster gets “burned” with that info before is shipped. This is the primary reason why this is a non-returnable item. When received is just a matter of swapping it out. Can anyone confirm this?
Old 08-09-2018, 04:14 PM   #12
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
Any more info on this?..
Old 10-06-2018, 01:41 PM   #13
Gustavo2nd
Drives: black frs 2013
Pmd
Gustavo2nd is offline   Reply With Quote
Old 12-31-2021, 03:50 AM   #14
jtiptonk
jtiptonk's Avatar
Drives: 2013 WRB Subaru BRZ Limited 2.0
Did you end up doing the 2018 Hu swap?
jtiptonk is offline   Reply With Quote
DIY - 2015 OEM Sharkfin antenna retrofit kbye DIY (Do-It-Yourself) Guides 93 05-13-2020 03:30 PM
2017 BRZ suspension retrofit kgc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 10-30-2016 01:27 PM
2017 BRZ vs 2015 BRZ calibration thambu19 Software Tuning 2 08-10-2016 02:36 AM
2015 key retrofit brzsubarusti13 BRZ First-Gen (2012+) — General Topics 0 04-16-2015 11:07 PM
2015 BRZ Limited key retrofit Turbowned BRZ First-Gen (2012+) — General Topics 6 09-17-2014 11:52 AM
