| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#30 |
Drives: 2018 WRX STI
I can't comment on the trackability, but I have owned both Enkei and Gram Lights (technically the GLs were NISMO-branded wheels made by Rays GL) and I was delighted with the quality of both...from both a finish perspective, ease of upkeep, and the ability to withstand real-world road usage (MD roads suck right after winter) without bending.
The Gram Lights I had were similar to the 57DR. One thing I instantly fell in love with was how damned easy they were to clean, and just how nice of a convenience that it was. |
#31 | |
Rice King
Glorious Honda.
#32 |
Drives: 14 FRS Whiteout
I track GTF1's, AMA
#33 |
Wheels for Brains
Is there a reason why you need the absolute lightest? What other wheels would be in contention if you didn't have that constraint?
--- Also, I would prefer sticking with 17x9+35 to +40. I run this fitment on my car (Tein Flex A [Lowered ~1.5 inches, -1.7 deg front, -2.4 deg rear], Gram Light 57CR 17x9+38, 245/40-17 Pilot MPSS) You can fix front poke with camber. You gain camber from simply lowering the car, or adding camber adjustability (which may inevitably come if you're serious about HPDE). It's arguably less desirable to fix rear suck with spacers. The suck gets worse due to increase in rear camber as you lower the car (unless you add a rear LCA). This why my rear camber is so much higher than my front camber. My car is set-up for daily canyon rather than track; there's no way to significantly adjust the rear camber with the stock components. |
#34 | |
Rice King
I don't recall if I made mention to having the lightest possible wheels, but I did mention that I would like the wheel to be lighter than stock for it to be a competitive and worthy upgrade. Give or take two or three pounds within the same price bracket and black - darker grey colours, with the sizing 17x8 +35-+42. Sizing is the only thing I am not looking to change (but am open to change, don't be confused), 17x8 is the size I have decided on, now just finding the perfect wheel within above metrics drastically limits my options, especially when factoring in the price. Reason for sizing is to reuse the stock tires so they don't go to waste and I don't have to shell out immediately for another set of tires, and clearance/rub issues; I will be staying stock suspension for a while and am not really interested in having rubbing/clearance issues, unless of course proven to be not an issue for sizes like 17x8.5 or 17x9. I may be bumping the price up a bit so I have more competition between wheels, but when the price is higher than for my current choice, the GTF1, the style, weight and colour all have to be absolutely perfect.... and as I go and check the the wheels today.. the price went back up so, that leaves more room for contenders. Note: I am using https://www.ft86motorsports.com/ as a baseline for Canadian pricing, so if someone knows a better option I am open to suggestions.
Glorious Honda.
#35 | |
A Nobody
Drives: FRS
#36 | ||
Wheels for Brains
Always a trade-off between pay-now and pay-later with regard to getting all the components. I bought coilovers and wheels/tires all at once, so it was not an issue for me. Konig Ampliforms just released. A little outside of your $800 CAD mark, but I like them. https://www.ft86motorsports.com/whee...-graphite.html I'll browse around and let you know if I spot anything else. Quote:
If you want to see any other angles, let me know. My floor-to-fender height is approximately [24-3/4" Front, 25-15/16" Rear] |
#37 | |
Drives: 2015 Firestorm FRS
Gonna buy 17x9+38 57cr
Trd lowering springs in stock suspension. Whats the camber to avoid poke and rub in front and rear? Thanks Quote:
#38 | |
Wheels for Brains
You technically don't need any rear camber. |
#39 | |
Do i need camber bolts in front to adjust camber?
Whats the ideal camber for front and rear I think trd springs lowers 1” Quote:
#40 | |
Wheels for Brains
I don't know what the ideal for front is. You'll have to do your own calculations/research. Ideal for rear is zero. |
#41 |
Drives: 2014 GT86
Ideal can be differing depending on car and on use type (daily or track or some mix of those) and from tires used and from wished handling change. Even stock rear camber is not zero, i somewhat doubt on it being best choice.
Commonly i see mentioned -1.5dg front, -1dg rear camber for daily driving, -2.5dg to -3.5dg front camber for track, -2dg to -2.5dg rear, even more camber front like -4dg or -5dg for drift setups. Zero toe front, slight +0.1dg toe in rear. (stock is zero camber front, -1.2dg rear, zero toe front, 0.2dg rear toe in. Best way to dial "ideal" camber is with tire pyrometer with comparing tire inside/outside temps. |
#42 |
Rice King
bump See Edit2 in first post
Glorious Honda.
| Canadian in NZ | Cole | NEW ZEALAND | 4 | 02-03-2016 04:59 PM |
| Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) | boomslang | CANADA | 1 | 09-07-2014 11:24 PM |
| Any Canadian BRZ's out there? | BP1913 | BRZ First-Gen (2012+) — General Topics | 5 | 05-30-2012 11:14 AM |
| Canadian FRS vs. BRZ | Marloon | CANADA | 24 | 05-02-2012 04:40 PM |
| TO ALL MY CANADIAN FRIENDS - BRZ Canadian Pricing Released | zex | BRZ First-Gen (2012+) — General Topics | 7 | 04-24-2012 12:46 AM |
