Old 03-06-2018, 11:42 AM   #1
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Don't you hate it when you're texting and girl and her reply is " k "
We're at it again! We acquired a wrecked car with a good front end and electronics system so that we can do a K swap from start to finish!
We are working on the following:
K Swap Plug and Play Wiring Kits
K Swap Mounts
K Swap Oil Pans
K Swap Transmission Options
K Swap Headers
K Swap Hose Kits
K Swap Intake
I will try to keep a detailed list of what we have spent parts wise on this swap as we go!
Parts Purchased Used:
K24 With 120k Miles $900
S2000 6 speed with 90k miles $600
Parts Purchased New:
K to S2K adapter kit $900
Skunk 2 Intake Manifold $770
6 Puck ACT Clutch $500
DBW Throttle Body $380
I'll keep it updated as we go!
Update Video!
[ame]http://youtu.be/VkWoTMNkE7I[/ame]
IMG_4438 by Brady Johnson, on Flickr
IMG_4462 by Brady Johnson, on Flickr
IMG_4458 by Brady Johnson, on Flickr
IMG_4461 by Brady Johnson, on Flickr
Final Resting Place! Our prototype engine and trans mounts are just about finished!
IMG_4602 by Brady Johnson, on Flickr
Why the S2K Trans? How does NO CUTTING, NO HAMMERING, NO WELDING sound????
IMG_4590 by Brady Johnson, on Flickr
Pure Automotive is offline   Reply With Quote
The Following 22 Users Say Thank You to Pure Automotive For This Useful Post:
-Phil (03-07-2018), 86Tony (03-06-2018), asdf (03-06-2018), DAEMANO (03-07-2018), DIY (03-07-2018), Draco_PR23 (03-07-2018), DustinS (03-06-2018), gtengr (03-12-2018), Iceman (07-28-2018), ichitaka05 (03-14-2018), ILLSMOQ (03-06-2018), Irace86.2.0 (03-06-2018), JBezugs (03-13-2018), kanundrum (03-13-2018), Kordless (03-06-2018), MJones_RB (05-17-2018), NoHaveMSG (03-06-2018), pitbull008 (04-27-2018), PR138 (04-05-2018), Sportsguy83 (03-06-2018), Spuds (03-12-2018), Tristor (04-07-2018)
Old 03-06-2018, 04:05 PM   #2
86Tony
Drives: 2015 AOZORA EDITION
Oh fuck yesss was losing hope for a sec LOL. Are we wble to find out what ecu we be using? Also will you be making a turbo manifold for the guys that want to boost?
86Tony is offline   Reply With Quote
The Following User Says Thank You to 86Tony For This Useful Post:
Old 03-06-2018, 10:52 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
$4k into it so far n looking good.
Old 03-07-2018, 02:40 PM   #4
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Yes!!!
Looking forward to do this swap
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following User Says Thank You to Draco_PR23 For This Useful Post:
Sportsguy83 (03-08-2018)
Old 03-07-2018, 04:25 PM   #5
Fred1
Fred1's Avatar
Drives: Scion Frs 2014
I had a RSX type-s back 2 years ago before buying the FRS, alway liked the K20Z1 way more then the Fa20... This kind of swap is an option I will consider most likely!
Keep up the good job guys!
Fred1 is offline   Reply With Quote
Old 03-10-2018, 03:43 PM   #6
Pure Automotive
The Following 8 Users Say Thank You to Pure Automotive For This Useful Post:
-Phil (03-10-2018), Dadhawk (03-12-2018), Draco_PR23 (03-15-2018), DustinS (03-12-2018), ILLSMOQ (03-12-2018), Irace86.2.0 (03-10-2018), Leonardo (03-10-2018), venturaII (03-12-2018)
Old 03-12-2018, 10:25 AM   #7
86Tony
When are the mount availible for purchase?
Old 03-12-2018, 11:27 AM   #8
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
OMG FINALLY!!! I love this. every. single. bit.
pgranberg11 is offline   Reply With Quote
Old 03-12-2018, 01:25 PM   #9
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I prefer it when they text back "JK LS". JK. Cool project!
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
MRS-Colin (03-13-2018), Sportsguy83 (03-12-2018)
Old 03-12-2018, 02:10 PM   #10
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
So, HASport says a K24 with axles, manifolds, accessories and transmission weighs 413lbs. Subtract the transmission, axles and p/s pump weight from the listed K motor weight and you're looking at an easy 100 pound reduction up front of the 86 compared to the FA20. Maybe more depending on manifolds used, etc. That's almost more appealing than the power bump.
http://www.superstreetonline.com/how...train-weights/
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Old 03-12-2018, 02:55 PM   #11
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
What is this insanity? A Hondubaru? Subhonda?
Interested to see how this works out! Always liked the K24!
Subaru STI :
Old 03-12-2018, 05:39 PM   #12
laextreme5
laextreme5's Avatar
Drives: 2014 BRZ
Is there still room for heater core hoses to connect?
Does front of motor sit any further back than stock motor?
No height clearance issues? Assume this is fixed by oil pan you referenced?
Also will you be doing a full dressed weight so as we can comapre to fa20 motor trans weight? Would imagine there is a a 60-80lb weight difference (which would be awesome)
laextreme5 is offline   Reply With Quote
Old 03-12-2018, 05:44 PM   #13
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
more room for heater core hoses then the LS or 2J swap actually. Need throw a hood on this car (shell didn't come with one) to get some pics, But it clears with a straight edge and the tallest point is further back than the tallest point of the 2J swap so it should be no problem. The modified oil pan is to set the motor back to clear the subframe and steering rack more than height. It is as low as it can get without cutting the subframe
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
laextreme5 (03-13-2018)
Old 03-13-2018, 09:55 AM   #14
Pure Automotive
We are almost done getting the design 100%, after that, we take them to our water jet guy and wait for them to cut a complete run of them, then we weld them up and powder coat them, so probably 3-4 weeks hopefully. I hate waiting on other people lol
The Following User Says Thank You to Pure Automotive For This Useful Post:
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports NvSnickers Wheels and Tires 2 04-04-2017 11:30 PM
Obnoxious "Blank" banner ad breaking quick reply Clipdat Site Announcements / Questions / Issues 16 03-09-2017 12:44 PM
Stock pistons "rate ore hate" ? Fricke Forced Induction 35 02-25-2016 11:59 AM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
My Adventures Aboard "Our Girl" Wes B. Other Vehicles & General Automotive Discussions 3 02-05-2013 12:44 AM
